My moretti elite 4.4kw a/c? How do I turn off the automatic setting as it shows the current room temperature but when I punch in 18degrees, it reverts back to the current room temp, ie not cold
Workshop manual for a moretti mypn15cn 4.4 kw portable a/c please or do you know of a web site that shows the remote with operating details ? Cheers thanks Mark Desreaux
  • 625 Answers
SOURCE: Can someone please tell me what is the lowest temperature setting a Fahrenheat 3000 Watt Large Room Fan-Forced Wall Heater Model FZL3004 will turn on at ?
about the only way I can figure is to let the room get very cool and adjust the thermostat to its lowest setting. now turn on the unit. monitor the heat until the stat just opens. the thermostat bimetal will be closed and will open when the bimetal expands and opens its contacts. another way is to hitch up a chart recorder to measure temperature with its output connected to the heater. [too expensive for you or the DIY to accomplish]
Posted on Dec 14, 2007
SOURCE: room temperature has not changed since hooking up new portable a/c
I bought mine last summer. Used it once or twice. Hooked up it today and it is a piece of ****. Been at 34celsius for the last 4 hours and still not even close to being cool .. and its in my bedroom
DON'T BUY DANBY portable a/c -----------
Posted on Jun 07, 2008
SOURCE: K-Mart Homemaker brand, 40 bottle wine cooler fridge
Are you sure you want frozen champagne? Or do you mean 7 degree C (not minus 7).
Posted on Jul 04, 2008
  • 10865 Answers
SOURCE: Cannot set a/c to operate automatically
Here is the sanyo link which will give you a manual once you enter the model number.
That being said, did you put new batteries in the remote? get back and let me know i want to help you.
Posted on May 23, 2009
SOURCE: need owner manual for POLAR water cooler with fridge
how do i set the thermostat on my polar water dispenser.model#PWD335-
Posted on May 12, 2010
What is the temperature that is displayed on the Mitsubishi Mr Slim remote?
The temperature you see on your remote is the setting temperature. It does not display the current room temperature. All ductless systems work the same way. They just don't show what the current room temperature is. Not sure why.
Aug 23, 2017 | Mitsubishi Heating & Cooling
Moretti heater manual > Household Appliance
Jul 03, 2014 | Heating & Cooling
Change the temperature readout from fahrenheit to celcius on moretti elite portable aircon
Hi just looking for the same thing. Guess what I tried and did it. On the remote press both the "+" and "-" buttons to change the readout from F to C. If no remote try the buttons on the machine, the up and down arrows.
Jan 28, 2014 | Cameras
Fan comes on; however, can't get the desired temperature to set. I select it and two seconds later it shows a higher temperature.
Hi Kate, When you press the button for your desired temperatre setting it will show this temp' say 17*c for a few seconds then it will revert back to showing the actual room temp' say 23*c, it should then cool the room down to what you set it at. hope this helps.
Sep 03, 2013 | DeLonghi CF210 Portable Air Conditioner
Although I set the desired temperature, it only reads that number for a brief minute then it changes to a much highter number. How can I set the thermometer?
What your seeing is normal. Anytime you change the temperature by pressing the up or down arrow to change the setpoint, it will show you what your current setpoint is. After the keys are idle, basically, your not touching the keypad for 5 to 8 seconds, it changes to the current temperature in the room. So, when you touch the keys, it gives you the temperature you want. When you don't touch the keys, it shows you what the actual temperature is in the room. Your unit is running normal and as designed.
Sep 27, 2010 | Genie Aire PACR9 Air Conditioner
I'm having a problem with my thermostat. It's a
Set Current Time and Day
1. Press TIME button once. The display will show the hour only.
2. Press and hold either or until you reach the correct
hour and AM/PM designation (AM begins at midnight; PM
begins at noon).
3. Press TIME once. The display window will show the minutes
only. 1F80-361 pdf
Mar 14, 2010 | Heating & Cooling
I have the problem of the airconditioner showing a temperature on the remote and increasing the temperature by itself on the actual unit. I don't have a book to check the error as it was a unit that was...
What might be happening is that when you set the temperature with the remote, the unit will display the setpoint. After a certain amount of time it will revert to displaying the room temperature rather than the set point. Does the unit still work after the temperature display increases? I would recommend setting it on 23 degrees.
Jan 16, 2010 | Heating & Cooling
I have lost my manual for a Simpson Appolo Atlas Stove
call manufactuerer and ask if you can order one or try to do so online
Dec 22, 2009 | Stoves EC500DOA Electric Kitchen Range
Housesitting. RTH111B model. I cannot keep the
That is a NONprogramable T-stat. There is no program to overide, therefore there is no need for a "hold" option. To set the temp, place the switch on the side marked
to the desired setting, and push the up down arrows on the front until the display shows 80.
The DISPLAY will revert back to the current room temperature within a few seconds, and will keep the unit on until it reaches the desired temp.
The set temperature remains at 80, it just shows the current room temp.
Aug 31, 2009 | Heating & Cooling
Error message and texture problems
I found I needed to change the user to a Power User and it solved the initial error problem.
Dec 08, 2006 | Punch Professional Home Design Platinum...
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
