Question about Mitsubishi Televison & Video
My Mitsubishi TV has an electrical smell? - Mitsubishi Televison & Video
Tv went dead then we smelled "electricity" smell like something blew. tv is completely dead. any options?
sounds like a blown internal fuse. unless you are savvy with a soldering iron you'll need to take it to a TV repair man. i assume its out of its warranty period?
Mar 24, 2014 | JVC LT-47X788 47 in. LCD HDTV
Screen is black
sounds like it was enough to pop something in the tv, smell the back of the tv smell if anything smells burnt or hot. unplug the tv and let stand for about a hour unplugged then trying it again but if it does smell chances are you will have to see if your still under warrenty and have the unit replaced.
Aug 09, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV popped, bad picture and vibrates
The pop was a high voltage arc of electricity that blew some vital components on the main circuit board. The unit is of no use now. Repairs are far more than replacing the TV.
Feb 27, 2014 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi lt 52149 52 hdtv will not come on. Like no power. Smell burnt smell at top. Is this something I can possibly repair myself if handy?
No,tv do not any indication of any LED lights that light up at all or any blinking LED lights at all wright?Yes?This tv have major components parts on in one board or could be any boards parts are completely fries and could spread all over the tv other boards too.That why u able to smell burn smell,minor problems don't have a deep smells like that.Best get a quotes from tv Techs from many tvs shops best prices u decide and get it fixed by a tv tech certified professinal.
Aug 22, 2011 | Mitsubishi LT-52149 52 in. LCD HDTV
When I turn on the TV it "pops a few times" then I turn it of and turn it on and it starts. Now today it seemed to go out and then I smelled burnt electrical smell.
It definitely sounds like it's time to have a TV repair man come check it out, or you will have to bring your TV into a TV repair shop. If you are familiar with working on TV's and have the proper equipment and electrical knowledge, you may be able to take apart the TV yourself and check for damaged capacitors, or boards that need to be replaced.
Aug 03, 2011 | Mitsubishi VS-50501 50" Rear Projection...
Have a 65inch Mitsubishi DLP. acouple years old, just heard a loud pop,smelled like it was burning,it turns on but just sound????
hi,
Check the lamp of you tv. The lam is burned. that's why you heared a pop up sound and burning smell. Just check it and replace it. you will get the picture back.
ok
Apr 16, 2011 | Mitsubishi WD65737 65" DLP TV
I have a 54" Mitsubishi tv that turned itself off
It depends what the fault is and the cure.
Get an engineer to give you an estimate for the repair.
Mar 22, 2011 | Mitsubishi VS-45609 TV
Starter and wiring
maybe burning smell is comes from the starter,i think the magnetic field of the starter is burned,check it
Feb 19, 2010 | 2003 Mitsubishi Eclipse Spyder
Is there supposed to be a cooling fan for the lamp ??
Mitsubishi had a problem with the power board in a lot of the DLP sets. The fans would not turn on when they were supposed to, and the lamp would create too much heat. Call mistubishi support, have your model and serial numbers handy. Sometimes they will warranty this problem een after the 1yr warranty has expired.
May 15, 2009 | Mitsubishi WD-57731 57" Projection HDTV
Engine runs rough, or dies when the defroster is turned on!
get your heater core checked out. the heater core is right by the blower motor and if its busted it will blow the smell into your car.
Nov 15, 2008 | 2002 Mitsubishi Eclipse
Open Questions:
Televison & Video Logo
29 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
