Question about Exercise & Fitness
The pedometer display screen got wet (i found my baby sucking on it, lol). and now some of the numbers are blank or partially blank is it possible to fix this? it happened over 2 weeks ago, so has been drying out since then, with no joy. is there somethig i can do myself, or should i just chuck it and get a new one? i thought you might be able to help with LED displays.
  • 63 Answers
SOURCE: Screen displays fine for a second, then goes blank
Dor, BenQ has a 3yr warranty on their monitors. I would contact their tech support and receive an RMA to return it for repair. It will cost you shipping out there but they will ship it back. I has a BenQ FP731 myself and it blew a capacitor inside that allowed the screen to stay on. Fixed it and had it back in 5-7 days. Good luck.
Posted on Aug 15, 2007
panilling9
  • 284 Answers
SOURCE: My Echo GT-200R will not start.
you need to make sure your plug is sparking
and if it is wet then the engine is flooded with fuel
press your primer bulb 5 or 6 times and use no choke and hold throttle open when trying to start it
Posted on May 26, 2009
fredtmccoyjr
  • 380 Answers
SOURCE: Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Posted on Jul 21, 2009
canbruce75
  • 1776 Answers
SOURCE: my son put soaking wet clothes in dryer....since
I would check for a blown thermal fuse or faulty heating element. These components can be tested using a multimeter. Check for continuity. A lack of continuity indicates a faulty component. The thermal fuse is about one inch long and is located in the rear of the dryer, usually attached to the exhaust duct. Hope this helped and best wishes.
Posted on Aug 05, 2009
sWatti
  • 188 Answers
SOURCE: Samsung SGH-a707 solid red screen and says download! PLEASE HELP!
mAn i've gOt dA same pRoblem.............mA sgh a707 wAs fallen in water n aftR tHat i hAd da sAm eRror.........i took out da battery....n aFtr 2dAys mA cell was wOrkin..........
Posted on Aug 17, 2009
Does evlipse mp3 have bluetooth?
The Essentials
  • 2.8" Touch Screen Display
  • 8GB Storage
  • Bluetooth® Enabled
  • Plays Music, Videos and Pictures
  • Pedometer
  • FM Radio
  • Built-in Rear-Facing Camera
  • Compatible with MP3 Downloads from iTunes
..this is what I found on the net.
Nov 08, 2016 | Audio Players & Recorders
Blank screen
Something tells me whatever cracked the screen may have caused internal damage. If your baby was sucking the cracked screen it's also possible some spit or other debris got inside.
Nov 28, 2013 | Samsung Galaxy Cell Phones
I have a new sportline belt clip pedometer. It has 3 buttons: mode,set and r/s. How can the length of stride be entered into it so an accurate mileage reading is possible?
I have an older Sportline pedometer with the same three button arrangement.
My pedometer is set as follows:
First press Mode to get the unit in the Distance mode. Note if the unit is in Kilometers or Miles. (Press and hold Reset for 5 seconds to switch the setting. This will reset the entire pedometer.) Press and hold Set for 2 seconds. The current (or default) step length will appear and flash. Press Set repeatedly until your step length is displayed. It changes by 1" or 1 cm at a time. Then release the Set button. (The pedometer will return to the normal operating mode if you do not press a button for 5 seconds.) When you reach the maximum step length, the unit will advance to the lowest step lenght when you press Set again. Since my step length is actually not a whole number, I rounded down.
A different Sportline step and distance pedometer (the 340) is set slightly differently. To switch from Miles to Kilometers, press and hold Mode when in the Step mode. Then switch to the distance mode and press and hold Set until the step length flashes. Press Reset to advance the current step length by 1" or 2 cm. Then release the button when you have the correct step length displayed. The pedometer will return to the normal mode after 5 seconds with no button presses.
Many Sportline pedometer manuals are available from the company's web site on the product site: http://www.sportline.com . You can look up the model number.
If you add your Sportline pedometer model, I'll be glad to give the specific setting procedure for you.
I hope this helps.
(on her third Sportline pedometer, two had the plastic spring clip fail. They all had similar programming details.)
Aug 18, 2011 | Sportline step and distance Pedometer New...
2000 mercedes c230 dashboard clock, drive and
If there are only partial images and some are blank, the unit itself is failing and requires replacement. There is no "fix" for this kind of display using LCDs. Try Silverstar recycling in CA and can be found on the internet. They carry all kinds of good stuff for Mercedes/Porsche at resonible prices and will ship.
May 16, 2010 | 2007 Mercedes-Benz C230 Sedan
My HJ720IT pedometer screen is blank. I thought the battery had died but got a new battery and it still won't work.
Mine has same problem. Died a week ago. Put in new battery and it worked for a week. Now it is dead again.
Dec 23, 2009 | Omron Hj 720ITC Advanced Pocket Pedometer
Acer 22W monitor goes blank after a couple of seconds. Please help.
tjpartners, Have you determined if your display is BLANK, or just BLACK!!! Yes, it can be both! But sometimes if you shine a brite flashlight about 1" from the screen you will be able to see if the screen is only BLACK, but not BLANK because you can still see a very faint image of the Win-Desktop if you look closely. If you see the image then that means the "switch-mode-power-supply" is only in partial shutdown mode and trying to save itself from a catastrophic, nonrecoverable failure! Do the flashlight trick and do a repost to your original message if possible. 12fixlouie
Nov 05, 2009 | Acer Computers & Internet
Blank screen
I actually had this same exact problem. I just got off the phone with the repair service. For me it was as simple as hitting the "disp" or display button on the bottom circular area on the back of the camera. It turns the display back off. I felt so dumb lol but i hope it is as easy for you!
Oct 14, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Reebok B 2 pedometer
1. Reset pedometer by pressing the reset button.
2. Find a long open place and take 20 steps with the pedometer
closed.
3. Check the number of steps the pedometer counted. It should be
between 19 and 21 steps.
4. If the count was not right, try to move the pedometer forward
(toward your belly button) or back (toward your hip) on your
waist.
5. Repeat this until you get the best count of your steps.
6. Once found, place your pedometer in this spot each day.
Apr 24, 2009 | RTO Reebok CS-1 Pedometer
When do I wear my pedometer?
Wear your pedometer all day. Attach it to your belt or waistband (in line with your kneecap) and wear it from the moment you get dressed in the morning until you go to bed. This will ensure that you are accurately tracking your activity for the entire day. Remember that your pedometer cannot get wet, so take it off when showering or swimming.
Dec 01, 2008 | Gaiam Walking Fit Kit Pedometer...
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
