Question about Sharp "MX-4100N Copier, Printer, Scanner MX4100, MX4100N"
My printer Sharp mx 4100n print separation black instead of printing colour, I mean when I send colour job it print out black in separation
SOURCE: prints black on test page, but not when a job is sent to the printer
I just posted and also fixed my problem. Try "deep cleaning" under the maintenance tab. Choose the black cartridge only. Mine only took once to fix but i'd try it 1-3 times before giving up on this solution. It now prints the test page with black and color
Posted on Nov 19, 2007
jyvibar
  • 148 Answers
SOURCE: sharp AJ1800 printer - won't print colour
the color cartrige is defective. replace only with original cartriges
Posted on Mar 23, 2008
SOURCE: HP Color Laserjet 5550 not printing duplex
Hi, Check that the printer driver has duplex (double sided) turned on.
That's if u hav not already solved it :-)
Posted on Sep 17, 2008
SOURCE: Possible to print only black when colour cartridges are empty?
I 've bought already 2 Magenta Cartiages but it always says X on it. whats the problem. Office Max don't replace it any more.
Posted on Oct 11, 2008
  • 118 Answers
SOURCE: We have a spooling problem. The sharp mx-2300n
Go into the Job review mode and highlight the pending print job (note: it may be stuck in processing). You should then get the option to delete the job.
Make sure that the pending print job is also cleared from the network print queue. They can sit in the queue and be persistent on processing, even after you've cleared the copier. Clear the queue prior to deleting the job on the copier.
If this doesn't, disconnect the copier from your network and try the above steps again, then reboot the copier and reconnect it to your network.
If you're trying to print out Adobe-based web pages from the internet, this may be what's causing your copier to jam up. There's known coding anomalies with Adobe-embedded documents on web pages. Trying to directly print from the web page can stall or lock up the print process.
Posted on Sep 10, 2009
Sharp mx 3100n
Sounds like PJL = Printer Job Language Set source Color Convert. whatever that means !!!!
Sounds basic but have you checked the Manual ? http://www.manualsprinter.com/sharp-mx-3100n
Go through sending test prints and go from there.
Aug 25, 2014 | Office Equipment & Supplies
Why can't I print PDF to my personal folder on our sharp MX4111N printer. We can print pdf files directly but we can't store them in our folders for later printing. When we try the print to the main...
You would have to create the folder in the web page that you wanted to print to, then tell your print driver that's where you want it to go.
under document operations in the web page, create a custom folder.
then in your print driver, go to the job handling tab, check the retention box, and where it says "stored to" choose the custom folder you created.
www.equipmybiz.com
Jul 30, 2014 | Sharp MX-4100N Copier, Printer, Scanner...
Sharp MX4100 maintenance code vk
Check out this little walkthrough I have put together. Adjusting the printer port settings on your computer should take care of it. Sharp Printer Offline Solution
Feb 20, 2014 | Sharp "MX-4100N Copier, Printer, Scanner...
Sharp MX4100n driver software freedownload
You can download Sharp print drivers directly from this link. Both 32-bit and 64-bit drivers are available for download here on this page along with instructions for getting them installed.
Sharp Print Driver Download 64bit and 32bit Free Printer Driver Download
Sep 23, 2013 | Sharp "MX-4100N Copier, Printer, Scanner...
My Mx-4501N Sharp copier whenever i send black it will print well but when i send colour it will jam
You need to have a service call, call a local sharp dealer. There is a dealer locator at www.sharpusa.com
Jun 04, 2013 | Office Equipment & Supplies
Sharp MX-2610N printer can't set-up the print job (for labels from by pass tray) from my desktop computer.
Some documents like word override the settings... you need to change/save within your document you are printing. page layout and then page set up
Sep 16, 2012 | Sharp MX-2300N Color Copier
I am connected to the sharp mx-3501n via a network and i have been printing in color for some time now, however, recently it only allows me to print in black and white while other people on the network are...
In the properties menu of the printer. Click on the tab of job handling. Make sure your user information and password for the copier has been entered. Without this you can only print black and white.
Jul 28, 2010 | Sharp MX-3501N All-In-One Printer
The Sharp MX2700 Colour machine has come up with an error code DK, what does this code refer to.?
This code means the Black Developer powder has reached the end of its life A service call will be needed to replace this for good black prints
Apr 26, 2010 | Sharp MX-2700N Color Copier
Network printing from a mac computer to sharp mx 2300n printer
HI,
Sounds like driver problem..
go to this site: Driver Update and make required updates.
wish you best of luck
cheers
Dec 17, 2008 | Sharp MX-2300N Color Copier
Sharp MX-4501N Mac drivers 1.1 will not hold black and white colour setting in printing profile (save as)
You are using Bonjour to print to the MX-4501N which uses a generic post script driver. To fix this, you must install the printer using the proper driver from Sharp. For a first time install, download the drivers, install the drivers, restart, and install the printer as an IP printer, specify the IP address, it should be using the LDP (Line Direct Printing) protocol, and specify any additional optonal accessories you have on your MX-4501N. Hope this helps :)
Oct 09, 2008 | Sharp Office Equipment & Supplies
Sharp "MX-4100N Copier, Printer, Scanner MX4100, MX4100N" Logo
53 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
