Question about Welding Tools
Airco pcs-40 plasma cutting system" owner's manual
Seeking Owner's manual
have you looked in the owner's manual ?
Support LED TV UN40H5203AF Samsung TVs
don't know if this the right one for your set, I think the 40" series all have the same manual. I couldn't download it myself. Also on that webpage you can 'chat' to a Samsung rep. who should be able to give you better directions to the correct instructions
Jan 15, 2016 | Universal 40-42 Inch Flat Screen Panel...
I need a manual for a airco welder. Stock number1341-0266. Serial number hk220507. Thank you.
This was made by Miller. It is the same as a Miller Dialarc 250 ac/dc.. Go to, then "service", then "owners manuals" then "search", and scroll down until you find the dialarc.
Apr 22, 2015 | Welding Tools
Where can I get consumables for a lotos LT5000D plasma cutter, and is there something else compatible.
You can order them through Lotus Technologies,
Or if you see a name on any of the components like Airco, Tweco, etc, you cold get through your current supplier or you could take them to a local welding supply and see if they can identify them. Chances are very good they simply used something readily available.
Jan 14, 2012 | Welding Tools
Thermal Dynamics Drag Gun Pac 10, Push Trigger, Labored Sound, Cuts Off and wont cut or flash arc. Cleaned Air Filter allways, All New Consummables, Allways kept clean, Has a rattle when trigger pressed...
Your plasma has a start arc pilot inside the machine, this one must be faulty, check your owner's manual and request the part to your nearest welding store. It is easy to replace.
Jun 21, 2011 | Welding Tools
Ford Taurus 2000 airco and fan works but no air comes inside the air.
have you cleaned or replaced your in cabin air filter? check your owners manual for directions.
Sep 19, 2010 | 2008 Ford Taurus Sedan
Cant get plasma cutter to arc
chek inner core of hand peace lead
Aug 07, 2009 | Welding Tools
Lotos cut 40 plasma cutter, not firing
Test all the mosfets, good chance one or more are failed.
Jul 28, 2009 | A & A Manufacturing Ramsond 40D Plasma...
No Arc on a Cut 40 Plasma cutter
Check your consumbales to be sure they are tight in the torch head. Check your ground be sure it's good and connected to the pc you are cutting. Make sure you are running air at 65 to 70 psi as it exits the torch. Email me if you have any other questions.
Jul 14, 2009 | A & A Manufacturing Ramsond 40D Plasma...
Welding Tools Logo
413 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
