Question about Coby Televison & Video
Coby tftv3227 turns on screen lightens but no picture no access to menu. After hard reset discovered is stuck in AV mode. Turned on dvd picture flashed and disappeared. Is this a ma inboard problem?
    Top Expert:
  • Coby Master
  • 74,118 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on May 19, 2017
SOURCE: DVD/VCR stuck in Progressive scan mode
With NO DISK in the DVD player PRESS PLAY, (display will say "no disk" or something similar) then PRESS STOP AND HOLD FOR 5-10 SECS. Our DVD was stuck on Progressive Scan Mode for over 1 year, this fixed it. I had tried the press stop, press stop and hold while playing a movie, but not while there was no disk. Try it & Good Luck!!!!!!!!
Posted on Nov 04, 2006
james klgr
  • 362 Answers
SOURCE: DVD player wont show picture
to turn it off select connection method 3 above and progressive scanning mode, to set the mode, set progressive to off in the display menu so that the p scan indicator light on the front panel goes out. do all of this in interface mode. you can also do this by pressing and holding PLAY > on the front of the unit for more than 5 seconds, still watch for the p scan indicator to go off. this works best when the unit is connected directly to the television.
Posted on Dec 09, 2007
SOURCE: Magnavox MDV560VR DVD Player Stuck in Progressive Scan
Trun the DVD player on till you see the "progressive scan" screan. Hold the "stop" botton down for 5 seconds and the unit should reset to standard DVD play.
Worked for me, good luck.
Bill
Posted on Apr 04, 2008
SOURCE: progressive scan mode
THis one should be easy--just read it in the manual--reset your video mode by removing any disks from the player, close the drawer, and then press and hold the "stop" button for five seconds. The green power button should flash red and back to green. Hope that solves it.
Posted on Sep 20, 2008
SOURCE: dvd player stuck in progressive mode
My brother came over to "help" me and we put on the progressive scan...then no picture and you can't see the menu to change. DO NOT use the solution noted here suggesting holding the stop button - this puts on the child lock.
Open the door on the front of the unit; push the DVD button; then push and hold pause button for 5 seconds or more. And progressive scan light will turn off and your picture will reappear!
Thank goodness...I was thinking my brother would be buying a DVD player - hahaha.
Posted on Dec 26, 2008
Coby TFTV3227 turns on screen lightens but no picture no access to menu. After hard reset discovered is stuck in AV mode. Is this a mainboard problem?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 01, 2017 | Coby Televison & Video
19 in. Coby TFT LCD TV with side-loading DVD player. How do I remove a stuck DVD?
Hi Joanne, The eject button ( micro switch ) on the TV is defective. Please get it changed and the stuck DVD will come out.
May 28, 2015 | Coby Televison & Video
Coby dvd-277 not responding
Here is how to unlock:
  1. Press SETUP
  2. Press VOL+, VOL-, VOL+, VOL-
  3. Current RC should be displayed
  4. Select the RC with RIGHT and LEFT (255=Codefree)
  5. Press SETUP
  6. Turn the player off
Nov 25, 2014 | Coby DVD-277
Screen flickers when turned on
There are many reasons for this fault. Check the voltages that comes out of its main power regulator board.
Jan 04, 2014 | Coby TFTV3227 32 in. LCD TV
My DVD 958 not showing with the hdmi cable through the television
You first should hook the device up with AV cables, after you uses AV cables , you will get a picture, once you get a picture, you need to go into the setup menu and turn on HDMI, once you do this, then you can switch to the HDMI cable.
Jan 29, 2013 | Coby DVD-958 Theater System
Coby 32 tftv3227 sound but no picture
Nothing you are likely to deal with in something other than a repair shop---most of The LCD type sets this size never get fixed from a cost point of view it usually is cheaper to buy a new set.
Inverters that drive the screen and or back lights if used are the common issues but there are others.
May 24, 2012 | Coby TFTV3227 32 in. LCD TV
Dvd stuck in tv
Someone is going to have to remove the entire DVD unit and open it to see if something (a second disc?) is jammed in the mechanism or if the mechanism is out of alignment.
Mar 20, 2012 | Coby TFTV3227 32 in. LCD TV
Getting sound but no picture when watching dvd and in can't get sound from tv when watching tv
Hi
Thanks for using FixYa. Make sure the Red and White wire is connected into your TV “AUDIO IN” and the Red and White wire is connected into the L & R. Also check that the DVD player Audio setting Analog Out is set to “2 Channel” and the TV is turned to the correct Video line (AV Input/Video Input 1,2,3.etc). Once your TV is turned to the correct video line, you should see the “COBY” logo and it will work normally. If still the issue persists, then you’ll need to reset the DVD Player for which you’ll need to follow these steps---
Using the DVD player remote control: Open the Tray and press the “PROG” button and then press the “ZOOM” button.
Once the above procedure is performed the tray will be closed which means the DVD player has been reset back to the factory default settings.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Oct 18, 2009 | Coby Televison & Video
JVC AV 32120
Sounds like your "CC" (closed captioning) is turned on and it is set to text mode.Go into the menu and turn the closed captioning "off". The default v-chip unlock code is "0000"
Sep 27, 2007 | JVC AV-32120 32" TV
My Screen Said "Are You Sure" and "Please Wait" and now, instead of "AV", i have "AV1" and "AV2" and my tv wont show picture from the dvd player OR vcr
You will need to go back into the menu and see what ia available in the video input mode. You may have switched the type of input you can use such as default or componts ect. If you have an isntruction manual, look in there or call the manufacturer, should also be in the instruction or user manual. Good Luck
Mar 28, 2007 | Spectra KT2114 Television
Televison & Video Logo
27 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
