Question about Health & Beauty
What is a low diastolic reading causes remedy
2 Suggested Answers
jonsnell4
  • 25346 Answers
SOURCE: Is a diastolic reading of 65 low for a person who is age 67?
No idea, ask at your pharmacy.
Posted on Aug 07, 2017
Is 99 / 128 a high or low blood pressure reading
That's highish, the diastolic (lower) reading being the most significant. However a single spot reading does not tell the whole story as BP does vary quite a bit throught the day. See your doctor for the next step, as exercise levels, weight, family history, and other factors all go into it.
Aug 14, 2017 | Health & Beauty
How low is to low with my blood pressure?
Mayo clinic says: Most doctors consider chronically low blood pressure too low only if it causes noticeable symptoms. (Such as dizziness, especially when first standing up). Some experts define low blood pressure as readings lower than 90 mm Hg systolic or 60 mm Hg diastolic - you need to have only one number in the low range for your blood pressure to be considered lower than normal. I hope this helps!
Mar 30, 2017 | Health & Beauty
Is 109/44 too low for blood pressure?
The diastolic reading, 44, is somewhat low. Go see a doctor to rule out any underlying causes needing treatment.
Jan 28, 2017 | Health & Beauty
Low diastolic pressure for what reason
That paper coined a new term, "isolated diastolic hypotension," which refers to a low diastolic blood pressure (less than 60 mm Hg) and a normal systolic pressure (above 100 mm Hg). Older adults who fit those conditions are at increased risk for developing new-onset heart failure, the researchers found.17 May 2015
UAB - The UAB Mix - Diastolic blood pressure: How low is too low?
https://www.uab.edu/mix/stories/diastolic-blood-pressure-how-low-is-too-low Low diastolic pressure for what reason Google Search
Dec 13, 2016 | Health & Beauty
What is a low diastolic reading considered to be for an 88 year old person?
First age is not a factor.
60 mm Hg or less is generally considered low blood pressure
This is usually caused by congestive heart failure, and as far as increasing the pressure it would be a question for your Cardiologist.
Nov 10, 2016 | Health & Beauty
Is a diastolic reading of 78 high or low?
Normal BP range is 120/80, although there are many factors to that must be considered. A diastolic of 78 would be within the normal range, Recommend consulting with your health care professional if you have concerns about your BP, and follow the treatment plan developed for you.
Oct 13, 2014 | Omron Health & Beauty
My blood pressure is 110/95 and my heart rate is 124/bpm. I am pregnant what does that mean?
110/95 Blood Pressure
Is 110/95 Good Blood Pressure or High Blood Pressure?
There are two parts or two separate numbers referred to as blood pressure: Systolic/Diastolic. If the blood pressure is 110/95 (110 over 95), it means that the systolic pressure is 110 and the diastolic pressure is 95.
110/95 blood pressure can also be read as 110/95 mm Hg, or 110/95 millimeters of mercury. The 110 mm Hg Systolic refers to the pressure in the arteries when the heart beats, and the 95 mm Hg Diastolic is the pressure in the arteries between heartbeats.
When determining if 110/95 is a good blood pressure, we looked at the American Heart Association's blood pressure chart.
Blood Pressure Systolic Diastolic Normal Less than 120 Less than 80 Prehypertension 120 - 139 80 - 89 High Blood Pressure
(Hypertension) Stage 1 140 - 159 90 - 99 High Blood Pressure
(Hypertension) Stage 2 160 or higher 100 or higher Hypertensive Crisis
(Emergency care needed) Higher than 180 Higher than 110
For 110/95 to be good, both numbers must fit into the "normal" category above. Otherwise, it will fall into other categories of High Blood Pressure.
Systolic reading of 110 is in the Normal range.
Diastolic reading of 95 is in High Blood Pressure (Hypertension) Stage 1 range.
Therefore, 110/95 is High Blood Pressure (Hypertension Stage 1).
Aug 05, 2014 | Veridian Healthcare 01-539 SmartHeart Arm...
What is the danger having pressure 130/100
Inasmuch as your heart is in the left side of your chest, this is not a good sign. Doctors treat blood pressures greater than 140/90. Your diastolic pressure of 100 is a bit too high. High blood pressure causes enlarged heart and other serious issues. Go read about it at wikipedia and start to become more informed. There are lifestyle changes that may help reduce blood pressure.
Nov 14, 2013 | Native Remedies Rite for Hypertension and...
My Walgreens Digital Blood Pressure Monitor pumps up to diastolic 118-122 then stops and deflates and the screen reads Err 2. Can you please tell me what the problem might be? Thank you.
Your Blood Pressure may be to high for the reading. Try to adjust the cuff and restart. Are you sure it is diastolic reading and not systolic?
Jan 13, 2011 | Health & Beauty
Digital wrist model # SR303S, shows error 3, has new batteries
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Jan 04, 2011 | Samsung Health & Beauty
Health & Beauty Logo
63 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
