Reversing camera is showing left & right on wrong sides
3 Suggested Answers
  • 148 Answers
SOURCE: film wound on wrong side of camera
It sounds like you have a jam.  When you have finished taking shots and have used all the film, you must press the film-rewind button on the underside of the camera; this does not rewind the film, but allows you to commence the next step.  Once you have done this, flip up the rewind-crank on the top left hand side of the camera. It is situated on top of the film speed dial. turn this clockwise until all the film is back in its cartridge.  You should now be able to open the back of the camera.
I hope you have fun with your t50!
Posted on Dec 11, 2008
SOURCE: Reversing doors on Roper Refrigerator
If the door is reversible you will see plugs on the opposite side and top . pull out the plugs and save . remove handles and hinges and move use plugs on other side
Posted on Aug 08, 2009
My Pyle backup camera says stop all the time I adjusted the eye no luck I cleaned the eye no luck Then I shut off all the power no luck Can you help
if you are talking reversing camera then you are paying attention to the wrong item
the camera just shows you what is there
it is the proximity sensors that tell you to stop or beep when approaching an object
have their operation checked
Dec 02, 2016 | Cameras
HAVE NIKON D40 THE LARGE MONITOR AT BACK OF CAMERA HAS BEEN TURNED OFF SOMEHOW HOW DO I TURN BAK ON????
turn on your camera
press the menu button on the back og the camera
using the switch to the left of the screen, hit the left side once to move the screen cursor to the small icon on the left of the menu screen that looks like a "penci".
now click the button to move the highlight back to the right side then move up or down to select "07" Image Review.
hit the 4 way button on the right side to show the two options, on or off.
move the highlight up or down to select the one you want (assuming you want "on"), then press the center of the 4way button, "OK". now when you shoot a picture it will show up on the back screen until you touch the shutter release button again.
Dec 27, 2010 | Nikon D40x Digital Camera
How do i use the front camera on my nokia 6288
turn on phone, ake sure that " Desktop " [the name of phone, e.i. METROPCS, etc. is showing on front screen. If not, press what looks like a arrow key facing left or " Back key ". until you see the name of the phone on screen. then on the bottom left or right corner of screen U should see "menu", press that and you should get a list or pix [pictures] of what U want to do. You should see a pix [picture] of a camera. Some were (usually in the center of [left side] pix of speaker, [right side] back key,are the up,down,left,right GO keys. 'tab' to or move to camera. and press center key. there U go.
Oct 09, 2010 | Nokia 6288 Cellular Phone
New feed belt will not track evenly. Belt is loose on left side & tight on right, but if I tighten the left side to pull it flat, it tracks off to the right immediately. I tried reversing the belt in...
Could be the belt, sometimes they get glued together wrong and they don't track, or its the tension wheel/ track wheel.
It looks like one of the stationary rollers might have a small adjustment
that you can do, hard to tell looking at the diagram,
but if you can adjust this tighter on the right side it should track the belt back to the left, so check and see if any of the rollers or holder of the rollers can be loosened and moved a hair to get the track to the left so the adjust track can make it track straight.
If you still have the old belt, put it on, if it works then there is a problem with the new one and it is not the machine.
Feb 12, 2010 | Delta 31 - 255X X5 18'' x 36'' Drum Sander
Aug 07, 2009 | Refrigerators
Change the door opening from left to right. Can it be done?
According to the owners manual for the HSB03, there are no instructions for reversing the door, therefore it is not reversible as by the companies instructions. I would not recommend reversing the door, even if it appears as though it could be done. There may be vital components within the unit that are not visible from the outside that could be damaged by the hinge screws in the wrong place.
This is the Haier web site if you need it. http://www.haier.com/index.htm
Please take the time to give this solution a fix ya rating
clarkco
Feb 16, 2009 | Haier HSB03 Compact Refrigerator
Film wound on wrong side of camera
Dec 11, 2008 | Canon EOS-AE-1 35mm SLR Camera
How to I hook up 5.1 surround no a 7.1 amp
Try reversing the Left and Right inputs if the problem follows the left input it's in the left cable or feed. if the problem stays in the left side it is in your surround sound or amp.
Dec 07, 2008 | Audio Players & Recorders
Speed cameras not showing when approached,camera on right,car on left
rang Co, told system warned of cameras same side of travel ,iff car on right& camera on left ,does not tell.
Aug 20, 2008 | Garmin GPS
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
