Heating & Cooling Logo
Valerie Thomas Posted on Dec 30, 2016
My Bonaire evap cooler won't turn on and is showing the code F1 11. Can anyone suggest what I do, please?
1 Related Answer
Anonymous
  • Posted on Jan 30, 2012
SOURCE: Our Bonaire Evap Cooler stopped after power failure
you need to turn off power supply to unit that works ok and leave other unit switched on and code it and test it then switch other unit back on
1helpful
How do I fix code E5 on Bonaire evap cooler
To fix code E5 on a Bonaire evaporative cooler, which typically indicates a water management issue, try the following steps:
  1. Check the water level in the unit to ensure it's sufficient.
  2. Inspect the water inlet valve for blockages or malfunction and clean or replace as necessary.
  3. Clean the filter and pump to ensure proper water flow.
  4. Reset the unit by turning it off at the power source, waiting a minute, and turning it back on.
If the problem persists, consult the user manual or contact Bonaire customer support for further assistance.
Evap cooler, misplaced the vulcan touchpad controller during reno, purchased a comfort control controller, i plugged in controller, its works but nothing activates evap unit to turn on.
You can check the wiring but this looks like an incompatible controller. Here are some alternatives:
If you're looking to purchase an Evaporative Cooler Vulcan Touchpad Controller, there are several options available. Here are some places where you can buy one:
The Home Depot: You can purchase a DIAL Evaporative Cooler Digital Controller from The Home Depot for $64.48.
Gasstop: Gasstop offers a refurbished wired Bonaire Comfort Control remote that works with Bonaire and Vulcan gas central heating systems for $150.
Bonaire Heating & Cooling: Bonaire offers a range of Navigator Remote Controls for Cooler and Heater, including My Climate® Wi-Fi® for ducted evaporative cooler, ducted gas heater, or dual-cycle air conditioner.
Navigator Remote Control for Cooler and Heater (bonaire.com.au)
Bonaire evap err02 - how do I fix it?
google Bonaire evap err02 for more info an the answer to your question. If you is under warranty call for service.
Error Code 2: Pressure switch inactive. Fan Running but pressure switch is still open or fan stopped but pressure switch is still closed
I have a Bonaire evap cooler . Bonaire comfort control. It turns itself on and off automatically.
Not sure you have an issue. These machines have built in time delays to protect themselves from power surges. You can’t turn the machine off and then right back on. Read the manual on sequence of operation and possibly get some answers.
1helpful
Bonaire vulcan evaporative air conditioner
check your filter for dirts, clean or change it, check your evaporator and condenser coil and clean....
2answers
Turn the power of to both the heater and the cooler. Turn the power back on to the heater and the cooler at the same time then reset codes on controller.
1helpful
Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Top Heating & Cooling Experts
Paul Carew
john h
