Question about Home
My soda stream lights are flashing and the machine is not working. I just replaced the co2 bottle for the first time e. This is a brand new machine
4 Suggested Answers
pierssy
  • 45 Answers
SOURCE: HAVE REPLACED CARTRIDGE STILLS SAYS RECOMMEND NEW CARTRIDGE
Canon use chipped cartridges, if you use a generic or a refilled one that uses the old chip (you have to move the chip yourself) then it will report it as empty, unless you re-set the chip with a chip re-setter that is made for those particular chips.
Posted on Nov 05, 2008
  • 1116 Answers
SOURCE: flashing lights
You have a warranty - take the machine back to your Bernina dealer for service.
Posted on Mar 29, 2010
SOURCE: how to set up pop bottles
You can download the Manual Here:
www.seagamfg.com/vs3800webman.pdf
Posted on Jun 29, 2010
Soda stream repair in Melbourne eastern suburbs pls. Soda stream pours out water when attempting to carbonate it. . New bottle installed and the same problem. Please assist to fix it.
Bernadette,
While I appreciate your wish to have cool refreshing drinks in this heat, you have inadvertently posted this query in a forum dealing exclusively with Cameras. Were you to post it in a forum concerning domestic appliances, I am sure you would receive a quicker response, and soon be enjoying that drink you so desperately require.
Dec 03, 2017 | Cameras
Soda stream
fit a new gas bulb as they are only good for a couple of bottles
Jan 11, 2016 | Home
I press the lever down on Soda Stream and no carbonating stream, the three levels of light come on. Machine is a year old and tried 2 new canisters with no luck.
Put a finger up into the hole the CO2 canister screws into while you repeatedly push down on the carbonation button and up against the seat of the CO2 socket. You should feel a plunger moving up and down against the pressures of your finger and the button. If you don't feel this plunger, the SodaStream valve is either stuck or faulty. Make sure the CO2 cylinders are screwed up at least finger tight against the top of the socket.
Jun 06, 2015 | Sodastream Soda Stream Home Soda Maker...
My brand new kitchen aid soda stream appliance leaks from the top of the bottle every time I use it! Help!
It sounds like the seal is coming off. I would first super clean it. Make sure nothing could be getting in the way of the seal. I would also check to see if any part of the top is warped. If that is the case, you should try and return it.
Elisa Jed ' http://www.jmappliance.com/Appliance-Repairs-Refrigerator-Repairs-Redlands-CA.html
Aug 05, 2014 | Kitchen Ranges
How do you make your own soda with sodasparkle?
You chill tap water in the SodaSparkle bottle. They give you a 1L soda bottle for strong sparkle and a 1.3L soda bottle for light sparkle.You fill the soda bottle to the marked line and then insert the disposable SodaSparkle carbonating cartridge into the soda making machine.Turn the cartridge and then bubbles form!
Apr 29, 2013 | Home
Soda stream won't carbonate
See our list of the best soda maker reviews for 2016. Read our best soda maker machine reviews and tips for maximum performance without wasting time. Top Ranked Home Soda Maker
Dec 26, 2011 | Kitchen Appliances - Others
Soda stream not carbonating
I called soda stream about the same thing. They said it could be a plugged valve or a broke machine. To unplug the valve, you take the washer out, then carefully put the canister in without the washer until you hear gas escape for 2 seconds.. then you take the canister back out and put the washer back in. If that doesn't work, it's a broken machine and they have to send you a new one.
Dec 26, 2011 | Refrigerators
Home Logo
3,197 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
