Question about Samsung Televison & Video
My Samsung TV is dark at the top of the screen .How can I fix this problem?
3 Suggested Answers
  • 11896 Answers
SOURCE: Dark burn in? at top and bottom of screen. TV is only 16m old.
PixelProtector is a tool for fixing stuck pixels, removing screen burn, correctly calibrating screens for optimal performance and gaining the best possible picture. Any large screen television is an investment. Poor set-up and calibration can degrade the quality of a television's image and severely threaten the life of the screen.
If you own a large plasma or LCD television with a DVD player and want to achieve optimum performance, PixelProtector is highly recommended.
3 ways to remove burn-in
1. PixelProtector for Removing Screen Burn.
2. downloading a free program called JScreenFix
Screen Burn Removal Using Your PC.
If you can hook your PC up to your screen burnt TV try this. Create a folder in 'My Documents' called 'Screen Burn'. I'm not joking keep reading. Now open up a picture editor like 'paint' available on all Windows PC's. When you run 'Paint' a blank white document is what you should have in front of you. That is exactly what you need. Select File – Save as and name your picture 'white'. Be sure to save it in the folder you just created.
Next you need to click on the 'black' section of the colour pallet at the bottom of the 'Paint' window. After you have selected black click on the 'Fill' icon (a tipped paint pot) on the left. Now simply click in the middle of your white picture and it should become totally black. Select File – Save as and name you picture 'black'. Again be sure to save it in the folder called 'Screen Burn'. You don't need paint any more so you can shut it down.
Now right click on the Windows desktop an select Properties – Screen Saver and using the drop down list select 'My Pictures Slide Show'. Now to configure the slide show. Click Settings and configure as follows. Slide the bar to 'More' so that pictures change frequently. Slide the next bar to 'Larger' so pictures fill the whole screen. Now click the 'browse' button and find the folder you made called 'Screen Burn'. In the next set of options:- Check 'Stretch Small Pictures', Un-check 'Show File Names', Check 'Use Screen Transitions' and finally un-check 'Allow Scrolling Through Pictures With The Keyboard'. Save the options.
Different versions of Windows might have slightly different configuration options but as long as the result is a completely filled (no borders), alternating white and black screen with no writing then it will probably help.
Now set your screen saver to 1 minute and leave the keyboard and mouse well alone.
As with the 'snow' and 'signal pattern' leave this for a while to see some results. If you use your TV for the PC then it might be a good idea to use this as your regular screen saver and run it frequently.
The only snag is the headache of connecting the PC up and the fact that removal technique will not be running at your screens native resolution.
Here are some more resources:- PixelProtector Screen Burn Removal and our old screen burn home page
Posted on Jan 17, 2009
  • 6694 Answers
SOURCE: My Samsung TV is dark at the top of the screen.How can I fix it?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Dec 30, 2016
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ... > Boards > Community Central > The Vestibule
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
Feb 03, 2016 | Televison & Video
I have a 75" Samsung LED TV, and the top position of the screen is going dark, is that a power supply issue?
Samsung TV half the screen goes black or dark - YouTube
? 0:38
Jan 28, 2012 - Uploaded by DaReal2Face
Samsung TV half the screen goes black or dark. ... My samsung 40" - 14 months old does this on the top half of the screen. .. ****** 12 month ...
Sep 28, 2015 | Samsung Televison & Video
Fix wet tv
Replace all ur vertical section condenser .
Apr 15, 2014 | Televison & Video
Half the screen isa dark, left side
Most likely you have a faulty LCD panel tabs. This can be verified sometimes by turning set on and tapping or squeezing the top left side of the TV. The only true fix is to replace the panel. I've been told that Samsung may offer to replace the panel or give you a discount on a new TV. Samsung is know to have LCD panels with premature tab failure. So it may be worth while to contact Samsung and see what they can do for you. There are videos on youtube that show case the problems and show you how to patch the problem. just type in "LCD panel tab" in the youtube search box.
Feb 17, 2013 | Samsung LN46A550 LCD TV
Samsung tv model UN40C5000 has a dark spot in the top center of screen. Can anyone tell me how to repair problem .
Dark spots might be due to energy recovery circuit board's fault. If you wish to get more details about these type of faults to Samsung TVs, check this link.
Feb 05, 2013 | Samsung UN40C5000 TV
One day old samsung 40LC530 LCD tv shows a dark patched screen
that is a factory defect you call the dealer for the warranty.the defective part of your tv is the inverter board.this board supplies high voltage supply to the backlight cold cathode flourescent lamp.This lamp is the one illuminating the screen of the tv..the lamp is installed at the top and bottom of the screen thats why the center of the tv is dark because the lamp does not lit well..tnx
hope i help you
please rate my help..
Jun 05, 2010 | Televison & Video
Dark vertical bar on right side of display
Please let me know if you find a fix. and what the problem was. Eddie.
May 28, 2009 | Samsung DLP HL-P5663W 56" TV
Dark shadow on lcd tv We have a Samsung LCD and it has a dark shadow near the top of the screen. It looks like a storm cloud on the TV. It looks like it may be starting to do the same thing at the...
u need to replace the tv backlight. it can be done by urself but its kinda complicated its better to just tak eit in to a repair man. shouldnt be that costly.
Apr 08, 2009 | Samsung LNT3242H Television
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
