On our tv that was on antenna we could get 4-2, 5-2,5-3,7-2, and etc. what can I do to find them. I am on direct tv now
    Top Expert:
  • Televison & ... Master
  • 74,473 Answers
Do an auto-search procedure. Refer its user manual for more details.
Posted on Dec 30, 2016
Ghosting on a Samsung ldc tv
check position on antenna, direction of antenna and height above roof
ghosting is s transmission problem and is normally associated with a reflected signal to the antenna ( roof, back wall other close buildings etc)
Dec 30, 2016 | Samsung Televison & Video
I have a new hdtv antenna and my hdtv gets all the local channels except 8. The direction from my house is 171 and that is also channel 4. I get 4 fine but not 8. what's up?
hello,
There would be weak signal reception at your antenna so it can't get the other channel. So change the antenna direction. If there's no result then increase your antennas hieght means keep your antenna at higher position.
Regards,
Laxman
Sep 28, 2008 | Televison & Video
Good afternoon, how can fix the double image in Sony KLV-32EX330 Please help me to learn to fix my tv, thanks for the answer,
double imaging or ghosting is normally a result of faulty tv antenna,cable or connections
check that the antenna is pointing in the direction of the transmitter or tower 9 change from strong winds etc)
raise it higher from the roof line to prevent signal reflection
ensure that the antenna in use is correct for the station signals
call in an antenna expert to check the antenna and signal strength
Jul 20, 2016 | Sony Televison & Video
The model # is: L42FHD37. I need to know how to set up an amplified indoor HDTV antenna. RCA multi directional serial # ANT1450BFW.
Attach the antenna to the antenna/TV input on the back of the TV. If you have a flat twin lead wire on your antenna, you'll need a co-ax converter. (Best buy, etc.) Power on the TV (and the amplified antenna) and use the Input button on the remote to select the TV input. Next use the menu button to select channels and then engage the auto-search option to memorize all of the available channels in your area.
Feb 29, 2016 | RCA Lg 42ls5700 42" 1080p Flat Panel...
Set top box
If you are using only an antenna (digital tv) with no other company involved (cable dish, etc) you do not need any additional boxes to get the digital signal as the tv has a DTV input. All you need is connect the antenna, switch the tv to that input number, then use the remote to go into the settings area, change the antenna type to digital, then run a scan to find all available digital signals in your area. You should be all ok now!
Good Luck!
Rich Lilja
Dec 20, 2013 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Hi, Can you hook up a dvd player to this model
This model does not have an AV input, just an antenna connector on the back. So you can't hook a DVD player directly to the set. You can, however, use an RF converter. The converter takes the audio and video outputs of the DVD player and converts them to an output on TV channel 3 or 4 which the set can tune in. It's not as sharp a picture or sound as hooking up directly, but it's the only option on your TV. You can find RF converters at large retailers (Best Buy, Radio Shack, Wal-Mart, etc.) and many online stores. They run around $20.
Dec 21, 2010 | RCA F25261 25" TV
Hi the coaxal for the tv antenna is missing? i never had it. I been searching for an atenna to work? only to find out that the tv should of had that equiped on it. what should i do or how can i get the...
The company probably will not send it.You can buy it at any store walmart,radio shack etc.Of course you need a tv antenna for uhf. The term "hdtv antenna" is not of use in this case,as all modern uhf antennas are desing for DTV. Sometimes depends on your needs:general receive,one direcition recive (yagi or directional)etc. In other worlds you need an antenna and a coax cable,nothing else.
Jan 18, 2010 | Proscan 37LC30S60 TV
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox, channel buttons cycle through sources
You need to reprogram your TV if you do not have a cable box or satellite box, otherwise those are going to be the only channels that the unit will pick up. If you do have a cable box or satellite box, just hit 0-3 or 0-4 if you are using a coaxial wire. If no box is present, you can just go into the menu and hit autoprogram - select cable for direct cable from wall, and antenna for antenna. Note: this particular TV is going to need a box in another 5 weeks due to the DTV transition, so my solution will only carry you for another few weeks.
-Tha Mp3 Doctor
Jan 11, 2009 | Philips Magnavox 20MS233S 20" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
