Turns on & off..but, no heat. electric furnace Is there a RESET button on a Nordyne electric furnace?
Changed batteries in thermostat Changed Carling switch toggle fan switch Turned all breakers off and back on...
    Problem Solver:
  • 12 Answers
Does the fan run normally? Or does it run all the time? If the fan operation is normal the problem may be a bad heat sequencers(relays) or the heat strip itself could be defective. Kill the high voltage grab a meter and disconnect the wires from the heat strip and ohm out the winding. If it's open then that's a problem. If it has a value ( probably low that's ok) then they should be good. Plug all wires back in. Move to the the heat sequencers look for any burnt wires. The low voltage should be blue and white wires maybe brown (second stage normally). This is the part that requires live testing of the system do not attempt if u are not familiar or comfortable with high voltage...be careful. With all wire plugged back in and the panels off turn on the high voltage. With the meter check for low voltage across the heat sequencers to should read 24+ volts across the blue and white. This would indicate a on switch. if on then check for the lead that come from the high voltage to the heat sequencers red wire usually. This wire is hot always. Check between the chassis and this lead for 120 vac. If u have the switch on and high voltage present there should be high voltage on the opposite terminal check with meter. In no voltage the sequencer is bad. Hope this helps. Oh if no low voltage check tstat wire (white) and then check the tstat for correct programming if digital.. you might do that step first btw
LUX TX500E thermostat flashing fan. Have installed batteries backwards and reset to factory settings installed new batteries as well. Still flashing fan. Furnace not working.
With this thermostat, it may be flashing FAN because the HVAC (any heating or cooling unit) unit isn't working. In the winter, the pilot light for the heat may not be lit or the air intake/exhaust could be blocked. In the summer, the AC coils could be frozen or there may be another problem. Go to the HVAC unit and look for any lights at or near the control board. Check the outside unit for problems as well.
If there is no problem with the HVAC, try resetting the software in the thermostat. Use a bent paperclip to press the reset button above the Next button; the reset button is inside a small recessed spot. If the problem persists, try a different thermostat. If a different thermostat doesn't work, the HVAC system needs to be serviced.
I hope this helps. Please add a comment with the type of furnace you have (electric, gas, oil). That might help determine what issue you need to look for on the main unit.
Jul 03, 2015 | Heating & Cooling
I have a Nordyne furnance when the temp is reached and the heat turns off the fan keeps running
On my thermostat for the furnace there is a switch for FAN - Auto On. When switched to On it runs constantly.
Feb 11, 2015 | Heating & Cooling
Nordyne furnace FEH017HA-04 the fan runs full force when the ac is on but half speed when the furnace kicks in
That is probably normal if it is electric heat to slow the air over the heating elements. Even some gas units do this. Check to see if the unit blower motor has wires for multiple speeds.
Oct 24, 2013 | Coleman Intertherm Nordyne Miller Furnace...
Auto fan does not start electric furnace
see this causes and fix it. God bless you
If the furnace won't run, check the electrical service panel for a blown fuse or tripped breaker. Also make sure the power switch on or near the furnace is turned on. Check the unit for a reset button and try it. Some units have a built-in breaker or fuse panel.
If there is not enough heat, raise the thermostat setting five degrees to see if it turns the unit on. If the unit still does not generate enough heat, check the comfort controls . Clean or replace a dirty filter, clean the blower assembly (see the Forced-Air Distribution Fix-It Guide), and make sure that all registers are open and not blocked.
If the furnace turns on and off repeatedly (cycles), clean or replace the filter; and clean the blower assembly (see Forced-Air Distribution Fix-It Guide).
If the furnace is noisy, make sure access panels are mounted and fastened securely; spray squeaking belts with fan-belt dressing and replace worn or damaged belts; adjust the blower belt; lubricate motor and blower oil ports.
If the element does not heat, refer to the Heating Element Fix-It Guide for guidance.
Oct 08, 2012 | Coleman Mobile Modular Home Electric...
I have a Honeywell programmable thermostat with a York high efficiency furnace. To turn the heat on, the thermostat "clicks" and cycles the furnace through startup (warm the fire starter, turn on gas,...
Well, it is a computer, and they all glitch, now & then, you say it clears with a power off, and thus resets it, It maybe a thermostat, flaking out, they do that, but the 6'o'clock, thing being the "Or" that sets it apart, I wonder if it isn't just a faulty control unit, as two together is too many, for a single cause, now, it sort of points there, but also, may sound silly but first, of there is any, Check your backup battery..
Feb 26, 2010 | Honeywell Programmable Thermostat Heater
Nordyne LP Furnace wont fire
might be the flame sensor need replacing.
Apr 15, 2009 | Kitchen Appliances - Others
Furnace blowing cold air
Nordyne Furnace, pilot is lit, thermostat is reset, Heater is on but blowing cold air.
Mar 28, 2009 | York Furnace Draft Inducer Blower Fasco #...
I have a intertherm model feh-017h electric
It's the heat kit in the unit that is causing the problem. You need to do a continuity test on it to eleminate that they have shorted. This is the only thing in an electric furnace that will blow a fuse on it. Intertherm is a Nordyne product for manufactured homes. Of coarse they still sell them! I am a Nordyne dealer. Also a sequencer can not cause a fuse to blow. The service guy just wants to make money from you by installing a new unit. You can either re-wire the heat kit or you can purchase a new one and have it installed. If you are referring to the heat kit for 159.00, then that's a fair price for it if you are a non licensed person.
Mar 17, 2009 | Heating & Cooling
Nordyne electric furnace heats up but fan won't come on when set to auto. Is it a relay switch. Have installed a new thermostat.
If the fan runs in the ON setting then you have a bad fan relay for the heat mode.
Did you install the t-stat before or after the problem?
If after, you have a bad fan relay.
Feb 21, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
