Question about Samsung Televison & Video
My 2008, Samsung TV, Model # LNT5271FX/XAA. When I turn on TV, everythings fine. After about 15 minutes, the lower right side picture becomes jittery and distorted.
Soon the distortion propagates until the total right side picture is un-viewable. Is this a possible DIY fix?
  • 1153 Answers
SOURCE: Loewe TV with pin cushion distortion
Yes if you could give me a model #, it is probably a diode shorted in pincushion area, or a capacitor.
Posted on Oct 05, 2007
SOURCE: Problems with TV
Our 37 inch Sanyo LCD HDTV has a problem with the picture distorted by being too wide. This has beenia problem for the duration since we bought the TV about three months ago. The PIX Shape button on he remote does not adjust this problem. We need help in solving the problem. Thank you.
fred_story@cpmcast.net
Posted on Jan 09, 2008
  • 286 Answers
SOURCE: Picture full of lines and flicker
Zdenko did an excellent job. Voltage regulators and the capacitors on the main boards and in the power supplies are always suspect. Some times you can narrow down the culprit buy purchasing a can of freeze spray. Let the TV warm up and try freezing suspect components to see if this causes a reaction. Thermal problems can often be found in this way.
Of course, if you're not able or willing to replace components on the circuit boards, you can always replace the main board or power supply board after determining which is causing the problem. These parts should be available at your local Viewsonic service provider at a reasonable price.
Posted on Feb 14, 2008
  • 122 Answers
SOURCE: 40 samsung lcd picture problem
first check the power supply board for puffy capacitors. then change the t-con board on lcd panel
Posted on Mar 09, 2010
eagle338
  • 4889 Answers
SOURCE: My Samsung LCD TV has
Can you please get me a picture so that I can see for myself. It sounds like an issue with A/V processing circuits but I would like to be sure.
Posted on Apr 12, 2011
Samsung hls4266wx xaa
my lg p999 cell phone is not working
Feb 24, 2014 | Televison & Video
Samsung LNT5271FX/XAA can not be turned on, keep cliking. I tried to replug in and change power outlet, never worked
I had the same problem. It is the capacitors. You can fix this yourself if you have a saudering gun. It is very easy and costs about $10 or less. You can even buy a cheap saudering gun. You just have to replace the bad ones and it will work fine after.
Nov 13, 2010 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
Lcd jerking in all motion flow settings to include off
Did this just start happening? What setting changed? Do you have the manual?
try looking here first: It is specific for your TV
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=02010100&prd_mdl_cd=&prd_mdl_name=LN-T5271F&prd_ia_sub_class_cd=P
If that doesn't help. Unplug everything and "start over" with your set up. Go back and reset the TV to the orig defaults. Then start with your satellite connection first. If that works, connect the DVD player, etc. good luck
Dec 19, 2009 | Samsung Digimax S500 Digital Camera
My samsung tv hlr5067wx/xaa screen turns black, sounds is fine. if i turn it off for awhile i can get picture for a few minutes, but it goes back to black screen
I suspect the lamp is failing on your TV. The lamp replacement code is listed on the side of the TV on a sticker that is orange and white. It will start with BP96-. The lamp code is crucial on these older Samsung DLP's because they used quite a few different styles. Please take a few moments to rate my answer. Thank you...
Nov 19, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
Problems with Samsung TV
try to soldering back your tv ic board first
Jun 25, 2008 | Televison & Video
I have the LNT5271FX/XAA television. Is there a way to have a different picture in picture input other than the television tuner?
the right lower quarter of my Samsung LNT 5271 has lines and blurry when you first turn it on for about 5 minutes before it clears up. Is one of the boards going out?
Jun 04, 2008 | Samsung Televison & Video
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
