The batteries came out of the remote and I put them back in and it says to rest the time but I don't know how to?
My TV keep flicking channels as if buttons r stuck but there not and not had a remote for years how could I fix it
It may be the remote. Remove the batteries and see if the problem stops, if so it is the remote, if not it is the TV. This is the best I can do since I do not know the make and model.
  1. Clean the area around the buttons. Use a cotton swab dipped in rubbing alcohol to gently clean the crevices surrounding the buttons on your remote control. ...
  2. Wipe the rest of the remote. ...
  3. Put the batteries back in.
Try these links for cleaning the remote if that does not solve the problem:
The Remote Control Keypad Silicone Oil Problem
Cleaning Remote Control
How to Clean Remote Control
How to Fix and Clean Your Remote Control Buttons
May 29, 2016 | Televison & Video
I changed battery in the remote with a cr2032. The remote lights up but the doors still don't unlock. any suggestions ?
read qowners manual for exact number of times... but put key in ignition turn on and off between 7 and ten times..... locks will actuate! hit lock button on remote... remote is then set
Jan 29, 2013 | 2005 Chevrolet Equinox LS
Why doesn't trunk open with remote
If you have never replaced the remote's battery, it may be time. The 'coin' type batteries do live long but not forever and mfr.s typically suggest that the lithium cells have a 'shelf life' (unused) of more than five years.
I don't know the construction of your remote so don't know if the battery is user-replaceable or not and if not, the dealers usually take advantage of customers when they can. The batteries alone are cheap costing a few dollars at worst.
If you have the 2nd remote stashed somewhere, you might try it if it has not been in use. Even then, the battery may quickly be depleted in the spare too.
May 27, 2012 | 1999 Buick Century
I bought a RCA remote and i don`t know how to used
Google the name and model of the remote and put instructions behind it....If you don't know the model, it may be under the battery lid (either inside or on the lid itself). If its not there, you can go to google images and type in rca universal remote and find one that looks like yours and it will tell you the model. I have done it before.....
Mar 13, 2012 | RCA RCR815 Remote Control
I have a Toyota Corolla with a Valet remote car starter and the car keeps starting on it's on without us using the remote.
Does it only do it in one location, or wherever you are? If it's one location, it's likely one of the neighbors has a similarly coded remote that is triggering your start. If it happens randomly, and everywhere, the main unit has issues and should be repaired/replaced. I don't know if they still do, but DEI used to have a lifetime warranty on everything but their remotes.
There is a remote possibility that it's one of the remotes, as well. You could try pulling the battery out of a remote and wait to see if it happens again. If it does, put that battery back and do the same on the next. If all the remotes check out, and you don't have kids/dogs/cats playing with the remotes, it's back to the top of this reply.
Good luck.
Jul 06, 2011 | Directed Dei Valet 561r Remote...
Toshiba 32a33. I'll be watching tv and the volume bar shows goes down to 0 (no sound) when it is in this mode the remote control will not work on the volume, you can get up and manually up the volume...
1st check to see if your remote volume down button is stuck. 2nd do you have wireless internet (router) or any other wireless devices phones,ceiling fans, another Toshiba remote, if so try unplugging them (or remove the batteries if it's a remote) while it's changing the volume one at a time. If a different device makes it stop try changing the channel on it. Also make sure the t.v doesn't have a mind of its own and remove the batteries out of the t.v remote, let it ride for a couple days if it happens without the remote being in play then you know your t.v is acting strange, if it stops then starts back up when you start using the remote again then you know your dealing with a remote issue. Sometimes Freq.'s merge causing remotes/wireless devices to conflict with each other.
May 18, 2011 | Toshiba 32A33 32" TV
I have a ViewSonic RC00136P remote control. It
Okay here's the fix.
Remove batteries. Re-install them wrong side in! Don't panic.
Reverse the direction of both the battery cells and install. Press "Power" button a couple of times and a few other buttons a few times. Then remove batteries and re-install the right side in.
Voila.
Mar 29, 2010 | ViewSonic Televison & Video
Doors won't lock with remote on my 2002 Lexus GS 300.
are you sure the battery is good in the remote? if so try putting the key in the driver door lock and locking and unlocking the doors three times in a row. if this dosent work i suggest taking it to an experienced lexus shop.
Oct 06, 2009 | 2002 Lexus Gs 300
Frozen LCD on Harmony 880 Remote
Ah, the 'blue screen of death'. Before you give up on this try one more thing -
Sometimes putting the remote in 'safe mode' and doing a firmware update will bring the screen back to life. Here's how:
Launch the Logitech Remote software on your computer and click on "Downloads" (on the top menu bar). Then, take the battery out of your remote and at the same time you connect the USB cable to your remote (it should be already connected on the computer end) press and hold down the Off button at the top of the remote. This will put the remote in "safe mode". Continue to hold down the Off button until you see the message "safe mode requested" on the remote's screen and the screen starts blinking. Now, since your screen is not behaving properly, you may or may not see this message, but after about 5 seconds you can release the Off button. Now, go back to your computer and click on "Firmware". If the software is able to communicate with the remote, an update to the remote's firmware should be executed. This has solved many a 'blue screen of death' problem. Good luck!
Sep 26, 2009 | Logitech Harmony 880 LCD Remote Control
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
