Question about Dishwashers
Nobel dishwasher model NBFSD/EM seems timer isnt working as its stuck in one position. Is there a fix-it for this?
4 Suggested Answers
  • 3247 Answers
SOURCE: I have a Nobel Dishwasher
Not sure how far you want to work on this Nobel dishwasher. Most likely the heater or the timer itself is the problem (unless you are supposed to use hot water connection). The detergent door problem could be due to dispenser relay getting stuck sometimes. I believe the company does not exist any more and you will have trouble getting parts.
It might help if you provide the model no. so that I can try to check it out better.
Posted on Oct 24, 2010
  • 48532 Answers
SOURCE: If a dishwasher continues to wash and seems to be stuck on wash cycle...do you think its the timer or the wash pump model # SHE 43F02UC/50
One would assume the timer .
Posted on Sep 12, 2015
  • 2276 Answers
SOURCE: I wish to purchase a cutlery basket for a nobel dishwasher model NBFSDEC IP21 WHERE
search appliance parts online
Posted on Sep 10, 2016
Where can i get a bottom tray for a nobel dishwasher NBFS4 S/S model
nobel dishwasher cutlery tray - Compare Cheap ... - GetPrice
www.getprice.com.au/buy-best-nobel-dishwasher-cutlery-tray_pn9.htm
Results 321 - 342 of 342 - Compare Nobel dishwasher cutlery tray price and readNobel dishwasher cutlery tray reviews before you buy. ... Bottom... more info.
I have a Nobel Dishwasher, model NBFSDEC. I have ... - Fixya
www.fixya.com/support/t24625480-nobel_dishwasher_model_nbfsdec
Jun 13, 2014 - I have a Nobel Dishwasher, model NBFSDEC. I have cleaned the filters ... Dirt left on dishes on top tray; bottom tray washes fine. Apr 03, 2009 ' ...
Household Cleaning Urban Myths: Do They Actually Work ...
www.apartmenttherapy.com/household-cleaning-urb...
Apartment TherapyJan 31, 2011 - com1Line the bottom of a pan with aluminum foil with the shiny side up. .... To get baked-on crud off of broiler pans, oven racks, roasting pans, glass baking .... Burnt pans, if you don't believe in Easy Off (a Nobel Prize for the ...
dishwasher in Scarborough, WA ' Dishwashers ' Gumtree ...
www.gumtree.com.au > Home & Garden
Jan 04, 2016 | Dishwashers
Nobel all in 1 cooktop/oven. Cooktop works fine but the oven doesn't seem to work. Light comes on in the oven. I've been told its something to do with the timer. Can you help?
If the top works and the bottom doesn't I would say either your igniter is bad, if it's gas and if it's an electric it could be the timer that turns the coils on and off.
Nov 13, 2013 | LN903 Akzo Nobel Paints 10 Oz Heavy-Duty
My kenmore elite model # 665.15934000 quit working in mid cycle. Now I do not have any lights on the control panel. The breaker is on. What could be the problem? Doug
Hi
Thanks for using FixYa. If the cycle doesn't complete, then the first thing that should be checked is the Timer and then the heating element. Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 06, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
S5N27B keeps stopping mid cycle
If the cycle doesn't complete, check these:---
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 28, 2009 | Bosch Dishwashers
The dial on my model#DU8016XB-1 is frequently VERY difficult to turn, causing me to think I will break it. Once I am able to force the dial to the START position, the dishwasher cycle seems to work just...
HI. Unfortunately, this damaged timer control module will need to be replaced. This type of device is not designed to be repaired. The timer motor mechanism is damaged, thus, causing theses issues you are experiencing. Apparently, part of the timer dial plate has become fused, or the cogs are damaged.
Have the timer control module replaced, asap. It is not repairable.
Dec 11, 2009 | Dishwashers
The cycle timer gets stuck
The timer probably will have to be replaced.
Oct 29, 2017 | Kenmore 24 in. 15149 Built-in Dishwasher
Dishwasher stalls
Water-heating cycle
Timer
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
May 31, 2009 | Bosch SHU4006 Dishwasher
DISHWASHER
this is a sign of a defective timer mechanism. replacing the timer will fix this issue. Replace the timer/control model asap.
Nov 03, 2008 | Roper 24 in. RUD3000 Built-in Dishwasher
Dishwasher will not finish cycle
Oct 19, 2008 | Dishwashers
Indesit D61D getting stuck
hi yes, well done! you fixed the problem by yourself now all you got to do is change the element buy a new 1 for this specific model and switch them a little more work then a light bulb switch good luck
Mar 26, 2006 | Indesit 24 in. D61 Free-standing...
Dishwashers Logo
Top Dishwashers Experts
