Question about Samsung Washing Machines
My Samsung front loader gets stuck on the 11 minutes spin cycle I have a vrt front loader Samsung washer.
  • 4 Answers
SOURCE: my bosch wfk2401 front loader is stuck on spin
Hi
There is a door bottom right of the system which has a screw out (by hand) plug.
Remove this and ensure there are no foreign objects such as coins, bobby pins etc stuck.
I have found this to be a problem with the Bosch systems and cost me $150 the first time.
Ensure you have some towels as when you open the plug, water will escape
Mark
Posted on Jun 16, 2009
SOURCE: samsung vrt washer will begin cycle but get so far
You might have an object jammed in the pump housing. First thing you must do is to unplug the machine from the power outlet.You will then need to remove the back panel of the washer to access the pump. Disconnect the wiring from the pump and remove the two hoses by compressing the two clamps. ( Be ready for water to pour out of the hoses) Remove the three mounting bolts that hold the pump to the frame of the washer and remove the pump assembly. It is easier to work on the pump if you remove it from the mounting plate. Remove the three screws that hold the impeller housing to the pump motor. Seperate the two parts being careful not to damage the rubber o-ring that seals the unit. Inspect the impeller housing for any debris. (I found a nickle blocking the outlet port in mine). Remove anything you may find and reassemble in reverse order. The machine should reset itself and run as normal.
Posted on Jan 23, 2010
heatman101
  • 43501 Answers
SOURCE: my samsung vrt front loader
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Aug 28, 2010
tunde007
  • 2382 Answers
SOURCE: clicking noise in spin cycle,
Hi, open the door and with your hand (glove on if preferred), feel around the interior of the drum for perhaps nails, bra wire, hair clip or something in the spin basket holes or in the pump....
Posted on Nov 05, 2010
t_d_hofstett
  • 1406 Answers
SOURCE: My Samsung vrt washer when on spin cycle is
It sounds like you're putting too much clothing in the washer. It can only wash a certain amount at one time. Try washing less in one load.
Posted on Aug 02, 2014
Samsung vrt front load washer WF218ANB/XA Burned up the drain pump. Installed a new one, now washer will work until the spin cycle. In spin cycle the door lock clicks and it will not drain or spin
Make sure the drain filter is not clogged. Most Samsung have an access door in the lower right hand corner to access and clean out this filter. If this is clogged or the drain hose is clogged, you will have these spin and drain problems.
Nov 10, 2016 | Samsung Washing Machines
I get the nf halfway through the cycle. ALWAYS with 26 minutes remaining after opening and shutting the door several times and can get it to resume the cycle.
SAMSUNG WF331ANW/XAA TROUBLE SHOOTING GUIDE ...
www.manualslib.com > ... > Washer > WF331ANW/XAA
View and Download Samsung WF331ANW/XAA Trouble Shooting Guide technical information online. 3.7 cu. ft. High Efficiency VRT Steam Front Load Washer (Neat White). ... DC68-02834A-03_EN. 2011-09-28. 4:00:29. Previous page ... SamsungWF337AAG · Samsung WF338AAB · Samsung WF331ANR/XAA · Samsung ...
Support - Washers WF431ABP/XAA ' Samsung Washers ...
www.samsung.com > ... > Washers
Samsung Electronics
Dec 08, 2015 | Samsung WF338AAB 4.0 cu. ft. Front Load...
Samsung front loader smokes
Please do not run machine with smoke coming from washer. You could create a fire. Unplug power cord, and call a qualified service person.
May 12, 2015 | Samsung 3.5 cu. ft. High Efficiency VRT...
What does LE mean on display panel of my Samsung vrt front load washer?
Le means there's a problem with filling. Check to be sure inlet hoses aren't kinked, and no blockage at the inlet, as well as water turned on.
Feb 23, 2015 | Samsung 3.7 CuFT VRT Front Load Washer
Samsung front loader not spinning at high speed
Yes ! this is related to fabric and hair accumulation and so it will be best to check the drain filter when you experience this issue.
Dec 30, 2012 | Samsung 3.5 cu. ft. High Efficiency VRT...
My samsung vrt front loader will not drain or spin and showing nd code
heatman101
Aug 28, 2010 | Samsung Washing Machines
I have an LG front loader, gets stuck on spin cycle at 9 min
The timer is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | LG Washing Machines
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
