Question about Sony Playstation 3 (PS3) Console
Trouble loading games and crashes when i press ps button.Also wont play dvd films but will play films from hard drive and music discs
  • 3 Answers
You need to buy a mod chip
Posted on Jul 21, 2009
Tip
Xbox help for "Can read CD but NOT DVD."
Step 1: Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc 1. Hold the disc by the edges without touching the top or bottom surfaces. 2. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward. Note Do not use solvents to clean the disc. 3. Once the disc is clean, load the disc into your console and see if the disc plays. If the disc still does not play, try step 2. Step 2: Try other discs Try other discs to determine whether the problem happens with any disc or only with this particular disc. If multiple game discs, DVDs, or CDs will not play: 1. Make sure the media type and the disc region code are compatible with the console. 2. If the problem happens with several discs of different types (games, DVDs, and CDs), skip to “Step 7: Request a repair” below. If a specific game disc will not play: 1. Search the Microsoft Knowledge Base to determine if the game title has any known problems. 2. Make sure the media type and the disc region code are compatible with the console. If the disc you are using has a region code that is compatible with your console but you still cannot play the disc, try step 3. Step 3: Clear your system cache If your Xbox 360 console can’t play multiple game discs, try clearing your system cache. Here’s how: 1. On the console, go to My Xbox, and then select System Settings. 2. Select Memory. 3. Highlight any storage device, and then press Y on your controller. 4. Select Clear System Cache.
Note If Clear System Cache is not available, use the button sequence described in the following article: 971755 How to clear the Xbox 360 console cache 5. Try to play a game disc. If you still can’t play a game disc, try step 4. Step 4: Remove the hard drive If the problem only happens with game discs, let’s try temporarily removing your hard drive. If your Xbox 360 console does not have a hard drive, skip to step 5. 1. Turn off your console. 2. Locate the hard drive on your console. 3. Press the release button on the hard drive and lift the hard drive from the console. 4. Turn on your console. 5. Try to play a game disc.If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If you still can’t play game discs, try step 5. Step 5: Disconnect memory units 1. Turn off your console. 2. Unplug any memory units attached to your console. 3. Turn on your console. 4. Try playing a game. If this step resolves the problem, reattach the memory units and contact Xbox support to order a replacement memory unit.
on Feb 15, 2010 | Video Game Consoles & Games
My playstation 3 wont read any discs, films, games, or music. The machine just stopped whilst playing a dvd and now refuses to work
Dear,
you may try to use the PS3 recovery options.
The PS3 stores a copy of firmware drivers on the hard-drive and will reload any corrupt files. To access the recovery menu, do this:
  1. Make sure the PS3 is turned off
  2. Press and hold the power button on the PS3 it will power on then power off.
  3. When it's off press and hold the power button again until you hear two consecutive beeps. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
  4. It will ask for the controller to be connected via the USB cable,
  5. Turn on the controller and you will have access to the menu.
Be aware that you may lose all your data previously saved. Good luck, Peter
Aug 02, 2010 | Sony Playstation 3 (PS3) Console
My 360 only plays cds or dvd s wont play games please advise
Feb 15, 2010 | Microsoft Xbox 360 Console
Ps3 wont read any game/dvd
ur disc reader is faulty/broke a quick way 2 get you back on games/ dvds go onto a demo or if you dont have download 1 via ps store and go onto it 1s ur on it press the ps button on your controller and the disc icon should be there now click onit and say yes 2 quit demo and ur sorted u will have 2 do this every time
May 31, 2009 | Sony Playstation 3 (PS3) Console
It just wont work
If you have 3 red lights on the ring you have what they call RROD or red ring of death. Bottom right would be hardware failure.
DVD Drive failure most common problem, this ranges from dirty disk error (DDE) message to inoperable drive door, skipping in movies, slow load time or no load or the call customer service errors 10, 11, and 12. To replace the drive it will have to be reflashed.
Feb 18, 2009 | Microsoft Xbox 360 Console
Ps3 was playing movies i had burned to disk now it wont
The best way to play burned movies is to copy them onto a memory stick or external hard drive then copy them onto the ps3 i use this method and find the movies play in much higher quality than dvd-r or+r or whatever discs you use
Jan 25, 2009 | Sony Playstation 3 (PS3) Console
Inserted disc press play grinding sound and disc left scrapped
If your xbox box it's new I would take it back and get another one, becase you do probable have problems with your dvd drive and it will keep scratching the games. the laser on the drive doesn't work as hard when playing a music cd than when it plays a game or a dvd.
If you don't want to take it back, then play a couple dvds and if it reads then fine then you could try again. it shiudn't take more than ten second to read a game so if its taking longer just get it out.
Dec 27, 2008 | Microsoft Xbox 360 Console
Console freezes
hey there, I would open the Xbox 360 dashboard, then go to memory, and press Y on the hard drive to open the "Device Options" menu. Then press the following sequence of buttons: X, X, LB, RB, X, X. You will be asked if you want to perform maintenance on your hard drive and delete all patches.select yes I hope this helps
Dec 07, 2008 | Microsoft Xbox 360 Console
Final Fantasy 11 Online (360) - Unreadable Disc
Sfabian answered the solution: If you are having trouble with your online disc and it is saying disc is unreadable, just follow theses directions:
Step 1: Put the disc on the disc tray, but do not close the disc tray.
Step 2: Connect a mp3 player, or a cell phone through a usb cord and listen to the music.
Step 3: close the tray but let the music play and then the game will load and don't reinstall anything, just select the first option.
This solution was fixed on final fantasy XI ultimate colletion.
Nov 22, 2008 | Microsoft Xbox 360 Console
Sony Playstation 3 (PS3) Console Logo
79 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
