Question about Kitchen Appliances - Others
Foodsaver V3440 wont vacumn all air out - Kitchen Appliances - Others
My rival seal a meal does not vacumn the air out when it is sealing. what is the problem and how do I fix it
There is air leaking in somewhere. Make sure there are no wrinkles in the bag at the sealer location. Also, make sure the seal on the bottom of the bag is complete or the machine will simply suck air from the bottom and out the top. Make sure there are no food particles stuck in or to the sealer mechanism.
I don't have a Rival but have a Foodsaver vacuum sealer. If I have trouble getting the air to vacuum out, I remove the black foam seal from the machine, run it under water for a minute, shake off the excess, and reseat the seal. For some reason, the water helps create a seal. It also helps remove food that may have leaked onto the foam seal.
If the wire that heats and melts the bag is damaged, it may not be sealing the bag completely.
Jun 06, 2016 | Rival Kitchen Appliances - Others
Foodsaver V3840 Won't vacuum air out and wont go to seal. A label states the seals are not removable. Do you know how to fix?
you are not using a "good" bag. Make sure there are no holes and that the bottom and sides of the bag are properly sealed. It will run all day and not pull the air out if the seal is broken anywhere.
Sep 11, 2014 | FoodSaver V3840 Vacuum Packaging System
V3840 Food Saver won't vacumn
Hi valkenwil798
Go to the following webpage for parts to repair the vacuum part of the sealer
Please take time to rate me
Sep 30, 2012 | Tilia FoodSaver V2240
Foodsaver wont vacuum v3230
Make sure you put the bag in as it's designed to go in, I s**t you not I tried to use a wider foodsaver bag and cut it down but I inserted it the opposite way than it was intended to go in and it would NOT vacuum the air out. So I cut another bag to test if inserting it the correct way would matter....and it TOTALLY worked fine! Crazy how I couldn't get it to work the other way.
Jun 30, 2012 | Kitchen Appliances - Others
Doesnt vacuum all the air out
Your Product Manual for the Tilia Foodsaver Food Sealer Vacuum V2240 is available here:
Please review all the Tips for Successful Vacuum Packaging. You may find some pointers that will you remove all the air.
Mar 26, 2011 | Tilia FoodSaver V2240
The tray full light stays on even though the tray is empty.this prevent the foodsaver from operating.I have tried unplugging,recleaning the tray but nothing works
I had the save problem with my 3400 series.
The first time i was able to let it dry and it worked alright (48 hours).
The second time even this did not work.
If you remove the screws on the bottom of the unit. There are about 10 and pull it down, you will see the sealer assembly and a small circuit board in the middle.
Trace the wires from the drip tray, there are three of them, red white and brown, to the small white plastic JST connector on the small circuit board. Pull said connector gently to disconnect it.
The unit will function perfectly now, although it will no longer have a drip tray sensor of any sort it will function every time all the time.
All in all this took me about 10 minutes.
Sep 09, 2010 | Vacuums
I have a foodsaver tilia,,and don't know how to use it...I can make it seal but don't get it to pull a vacumn..
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit.
The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Nov 05, 2009 | Tilia FoodSaver V2240
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
