Question about Kenmore Washing Machines
F20 on kenmore washer he2 plus , runs through the rinse program fine, only does it in the normal wash and other wash cycles and only when it goes to rinse cycle.
  • Kenmore Master
  • 5,323 Answers
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you may have selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
The item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board. You can also do a live volt test to see if it is getting the full 120 current, but be sure to unplug unit before testing as this is a live test.
Another test u can do to check the water inlet valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
By the way my advice is free cuz God is good!
Posted on Jan 05, 2017
Kenmore he2 plus stops during wash cycle
What is the maximum capacity (laundry weight load) of your washer? And how much weight do you consider a large load, that you are placing in the washer?
Dec 31, 2013 | Kenmore HE2 Plus Front Load Washer
My washer stops in the middle of the cycle and displays F-1 and after I have to set it on the rinse / drain cycle to complete. Today for the first time it also displayed 5d at the end of the cycle.
5d or Sd means too much detergent was used. Try the following
Run the unit through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
Jun 29, 2010 | Kenmore HE2 Plus Front Load Washer
My washer does not seem to be going through the rinse cycle.It doesnt drain all wash water out. When it FINALLY stops the letters Sd are lit............WHY
overdose of detergent during wash cycle try running the unit in a rinse spin here is also a tehnical sheet that u can get from this site as a pdf sd stands or suds lock
hope this helps
Jul 15, 2010 | Kenmore HE2 Plus Front Load Washer
Our Kenmore HE2 keeps giving f20 error. Water pressure is fine. No kinks in hose. Cleaned out junk in trap behind the bottom panel. Ordered new pressure switch. Works fine on clean washer cycle, but with...
This code is tricky to troubleshoot, so jsrock516 advises to eliminate the easy common sense items first
Dec 02, 2009 | Kenmore Elite 45986 Front Load Washer
How do you clean the inside of your Front Loading washer?
This can be accomplished by running the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Oct 09, 2009 | Kenmore HE2 Plus Front Load Washer
Code F20 is appearing on me washing machine
May 27, 2009 | Kenmore HE2 Plus Front Load Washer
Front load kenmore washer giving error f20 messsage.
take the kick panel off and find the tech sheet. i believe you have3 either a bad pressure switch or something stuck in your pump. let me know how it goes
Apr 04, 2009 | Kenmore HE2 Plus Front Load Washer
Open Questions:
Washing Machines Logo
48 people viewed this question
Sal De
 Brian Main
Brian Main
