Not emptying properly
Hear water after spin though no water visible
    Habit-Forming:
  • 13 Answers
There is a balance ring in all washers. The sound is the liquid that is in the balance ring. Normal nothing wrong.
Posted on Dec 30, 2016
GE Washer Mod# wcsr2090d5ww
It's normal for some water to stand in bottom of outer tub. It shouldn't be visible in the inner tub though.
Oct 31, 2017 | Washing Machines
Hotpoint WD61 - I have taken back off, emptied blocked filter but having reasssembled the water does not drain and therefore does not spin. If I empty water via a bucket from drain hose the machine does...
hello, is sound like the pump not energizing the pump needs testing with a multimeter. fill it up again then empty it you should hear the pump kick in also check the hoses make sure there not kinked good luck
regards
shaun
Dec 05, 2010 | Washing Machines
You can hear water behind the drum when you spin
I don't believe you have a problem with your washer. It is NORMAL to have residual water in the drain lines and drain pump following a wash cycle. You will be able to hear the water sloshing around if you move the drum or drain lines. This is the lowest point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket inside the drum, and the washer is properly draining during the wash and rinse cycles, you have nothing to worry about.
If you have any questions, please post back and let me know. I hope this is helpful to you.
May 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Washing machine is retaining water in the bottom or back of the washer which is visible sometimes. It has mildewed and SMELLS! I have run the washer through the spin cycle several times and this empties...
Sounds like your drain hose is pluged with something. Try and check for small idem into drain on bottom of washer ( chain, braclet etc ) or soap buildup. Once you have determined wheather or not there is a plug to be removed, you can run cider vinegar through your wash cycle which will help reduce the mold. Plus it helps with soap clog buildups. Powered soaps tend to build up faster then liquid soaps do.
Feb 25, 2010 | Whirlpool Washing Machines
Washer will fill up lid switch clicks hear timer running and advances but will not aggitate spin or empty water
sound as though you have a wiring problem around the motor harness..Or you may have to cheak for current across the switch when you click it on and off.Hope i helped:)
Jan 24, 2010 | Maytag LAT3600A Top Load Washer
Washes but won't spin...seems to empty water though
Could be the programmer, if its a clockwork one then its common problem, if its a electronic one then your really out of your depth unless you can find another to donate the bits! Good Luck the Yeti
May 19, 2009 | Kenmore Washing Machines
Fills washes rinses but wont spin properly or empty out washer, ends cycle half done, wont pump water out or spin out. i can hear the machine hum while trying to do so. Please any ideas. THanks
its likely the pump is blocked (hence the humming) with a coin or some foreign object. To check, lower the outlet hose to ground level to allow the water to empty. Tip machine back & lean against a wall, remove the pump & remove object if there is one! Reassemble & try machine again
Oct 19, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Incomplete water emptying following spin cycle
your pump is on its way out inside they have a small fan which pushers the water out if that is lose than the pump has to be replaced common fault
Dec 25, 2006 | GE WJRR4170E Top Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
