The arm to my turntable slides across the record after playing instead of lifting and automatically going back to place.
    Top Expert:
  • Audio Player... Master
  • 44,073 Answers
Defective velocity switch
Posted on Dec 30, 2016
The tone arm drops onto the record, but then continues moving across the record without playing the record. Anyone know what's going on?
Does the needle actually contact the record? If not, you may be missing a "pad" under the record, or you may be simply missing the needle that needs to be there to follow the grooves.
Nov 02, 2014 | Audio Players & Recorders
Record player repair
The top arm that swings over the spindle will control the automatic return. Leave the unit off. Swing the overhead holding top arm over and manually load a record. Now switch the top arm over the niddle spindle. Make sure that the switch is set for 7", 10" or 12" (45, 78, or 33). Manually place the tonearm at the start of the record and flip switch to 'play' (not reject or auto). It should play the whole record and automatically eject at the end and then shut off. Leave the arm swung over the middle after you loaded the record. Good luck. Let me know if you have any more questions.
Aug 18, 2014 | Audio Players & Recorders
Needle slides across record
It could be 3 different things. The first is check the needle make sure its not dirty. the second is make sure the weight is set correctly. And the third is did you take the tone arm off the protective part that holds the tone arm in place when moving or travelling .
May 19, 2012 | Numark ttUSB Turntable
The arm will automatically return without playing the record
Hi Lisa, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
Nov 28, 2011 | Audio Players & Recorders
Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Nov 09, 2011 | Crosley 0187SST Turntable
Aiwa turntable px-e860: Hi, I've inherited this timetable from a friend and it's worked fine until recently but now here's the problem: if I push start, the arm lifts up, moves to the record...
Hi, I;m not familiar with that exact model however the problem you are describing is commonly caused by the automatic operation at some point not being allowed to complete its full operation. Ie the tonearm has been returned manually to its rest position before reaching the end of the record. Try this. With the player not powered up lift the tonearm across to the record run off groove and sit it there. You may feel some resistance which is normal as the mech has to eswt itself. Now turn on the power and turntable. The arm should automatically return from there to its rest. Try auto operation after that. Let me know how you go. Cheers John. styluscity@gmail.com
Oct 10, 2011 | Aiwa PX-E860 Turntable
I have a JVC AL-A158 turntable, just got it from a thrift store for $13. Cosmetically, it's brand new. No scratches, no scuffs, no nothing it's even still got the plastic on the 45 record adjustment, and I...
2 things, make sure the back arm weight is adjusted correctly,, allowing enough pressure to be placed on the record, if that doesn't help, you have a chip in the needle thats not visible to the naked eye,
Apr 30, 2011 | Audio Players & Recorders
The stylus just slides across the vinyl records - I have adjusted the weight on the arm but still does this
Make sure the turntable is level.
Make sure the stylus is mounted correctly on the arm. With no record on the turntable, and placing a soft cloth under it, lift the arm and see if it slowly settles down or falls quickly. Depending on the make, arms can become sticky and lose their ability to "float." Re-adjust the weight dial if possible.
Jan 11, 2010 | Audio Players & Recorders
Tone Arm skips past first song
Hello, A. Do not try to close the case when there is a record inside!! The fact that the turntable cannot do this is not a design flaw--you'll be hard pressed to find a portable turntable that can close with a record inside because if you were to pick up the player with one inside, it could easily slip off of the spindle and scratch against the sides of the player.
B. Are you using the cueing lever to lift the tone arm before you place it on the record? Read the instructions to see where the cuing lever is (it's a little switch on the right side of the tone arm). When you lift it, the tone arm will lift up and allow you to position it wherever you want on a record, then you depress the lever to make the tone arm touch the record and being playing.
I hope that helps!
Jan 04, 2009 | Crosley CR249TA Turntable
KD-67F fully automatic turntable--servo mechanism has suddenly stopped
I wish to help but I "NEED MORE INPUT". mgfr, model, type,ect.
Sep 08, 2008 | Kenwood KD-291RC Turntable
29 people viewed this question
 Grubhead
Grubhead
