Question about Sanyo Televison & Video
My electricity went off while my Sanyo Vizon was on now it's channel searching and won't do anything else?
    Top Expert:
  • Sanyo Master
  • 75,178 Answers
Try a hard reset to this set, and then check. If it do not help, check and replace its main system control memory IC. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Dec 30, 2016
shivam4529
  • 150 Answers
SOURCE: sanyo vizon tv black screen
hiiiiiii here shivam
i want to tell you that that same problem is occuring my computer but now it is fixed
but your problem is of tv don't worry is this is help full to you--
this problem is common on this model. your vertical output circuit has gone bad. but i am sorry to say that a repair cost is to much for a tv this age. a cost would range 100-150. i say invest this into a newer tv. this model was good for 10-12 years and you have got better than that.
good luck :)
let me know if you need more info?
Posted on May 24, 2008
SOURCE: sanyo vizon dp42746 problem
me too i bought mine like 11/2 years ago
Posted on Jul 20, 2008
  • 222 Answers
SOURCE: im losing channels on my tv. because i cant do a channel search
It's only thru your remote. try fixing your remote control.
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
Posted on Jun 15, 2010
SD Tech
  • 14553 Answers
SOURCE: SANYO VIZON cable problem? how to fix?
look in menu to make sure set is not in antenna mode, it should be in cable mode.
Posted on Mar 13, 2012
gopakumarg43
  • 75178 Answers
SOURCE: I accidentally hit the reset button on my remote for my sanyo vizon TV and now it just keeps searching for channels and won't let me do anything. I don't have cable. How do I fix it?
Try a hard reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Mar 11, 2016
My Sanyo Vizon 32 inch flat panel has times when part of the picture becomes a "white ghost". How do I adjust?
Actually that is quite a rare case on today's modern digital flat panel TV's. You're not saying where you live, and you're not saying if you have previous issues on older TV you had before digital, and (again) you're not even saying whether you're on a hill or deep into a gorge. No TV has ghosting these days, but if you're living in an area as above, go see the TV people and they will probably recommend a set top box. But that isn't really necessary if you have a modern flat screen TV because most of these TV do two things, they give you a crystal clear picture or they don't. Digital TVs have a channel searching system that does the searching for you, and, as the case may be, these only pick up the best channels that give the sharpest picture. Anything that is of poor reception they ignore, so you're actually missing all the channels available because of this ghosting issue. AN there is nothing to adjust on the ghosting, snowing and vertical or horizontal bars, etc. These issues are things from the past, e.g. old analog TV's.
Dec 28, 2014 | Sanyo Televison & Video
Mar 13, 2012 | Televison & Video
Stuck on search for channels and I can't access the menu. All I can do is press the channel up button
Hello
Replace its Memory IC. This is a common fault to Sany Vizon. Memory IC; otherwise called as system memory, is a small IC, with 8 solder terminals. It can be located very near to the main system IC. Its number is the most important to note. It should be same as the present one, otherwise won't work. If you have some technical skill in electronics, you can do it by youreself. OK.
Jun 20, 2011 | Sanyo HT28745 28" TV
No channels after 13 no reception
if you are running off a antenna try to go under your menu and search for channels. You can move your antenna around. try to go to antennaweb.org
you can look up what angles you need to set up your antenna with to get certain stations.
reply if you need any further help.
Mar 17, 2010 | Sanyo Vizon LCD-15A2 Television
How to get digital and analog channels together?
Since the entire world has gone digital for the most part see no reason to hook up analog anymore
Jan 03, 2018 | Sanyo Vizon LCD-15A2 Television
Lost the remote & Sanyo Vizon is stuck on a "D" screen
If you use a tv dish or cable box you could program the cable or dish remote to control your tv. Look up the codes online
Jan 20, 2009 | Sanyo Vizon LCD-15A2 Television
Digital tuner
Try this!
The manual states the TV is designed to search for channels.
turn the power on
then hit menu
(if it doesn't start searching for channels)
then hit channel up -let it run a complete channel search
hit menu again
hit channel up- let it run a second channel search
hit menu again after it finishes it's 2nd search cycle
if it doesn't go to a channel, hit the input button.
it worked for me!
hope it helps
Dec 08, 2007 | Sanyo Vizon LCD-15A2 Television
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
