Question about Sewing Machines
I'm getting a designer Topaz 40 and was wondering what embroidery thread I use??
  • 192 Answers
SOURCE: Satin Stitch Problems - Designer SE (similar to the Designer 1)
You should take your machine to a Husqvarna authorized repairman. Suggest checking the grounding of the tension unit stepper motor. Earliest models weren't properly grounded and tension could vary. An authorized repairman should know where to go from there. I don't know of anything that you should attempt on your own.
Posted on Nov 14, 2007
kent581
  • 87 Answers
SOURCE: Designer 1 Embroidery Bobbin problem
Designer 1 bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Posted on Mar 18, 2009
  • 46 Answers
SOURCE: bobbin thread shows on top of machine embroidery
You are not getting bobbin tension somehow. Either not threaded correctly in the assembly or it needs to be adjusted tighter.
Posted on Jul 25, 2009
  • 201 Answers
SOURCE: designer 1 breaks thread when doing embroidery
There could be many reasons for this. Here are some things to check:
Keep an eye on the thread as it spools off the reel when you are embroidering. It's always tempting to watch the embroidery - which is incredible and fascinating and mesmerising - but that won't help you discover if the problem is how the thread is unwinding. Thread breakage is often caused by the thread not reeling of cleanly - it gets caught on a rough bit of the spool, or loops and gets caught in the tension discs or it flips out of the first thread guide straight after the thread spool. Some of the softer rayon emb. threads tend to fall off their reel and this can cause problems too. Check all those things. There are ways of dealing with any of these problems, just ask.
If it is polyester embroidery thread- when you are threading, pass the thread through the take-up lever (the hook bit above the needle that goes up and down) from left-to-right instead of right-to-left.
Put in a new needle. Make sure the needle is the right size for the thread you are using. There are special Embroidery needles, but I generally have no problems using a Universal 80/12 provided I am using regular embroidery threads (rayon or polyester, 40 or 35 wt).
Check that the bobbin thread is "clicked" into its tension slot.
Take off the needle plate and check that there is not a rough bit on the needle hole. There should be a nick at the front - that's normal - but any other roughness needs to be smoothed away with a crocus cloth (which I don't have, but find the rough side of a nail file followed by the smooth side does a reasonable job instead). While you've got the needle plate off, take out the bobbin case and clean all the fluff out of the area below the bobbin case.
Tip the machine back or lay it on its back and look up the needle shaft. Is there a pile of broken thread up there? It is really hard to get a good look up there, but you might be lucky. If there is some thread caught there, use long-nosed tweezers to get it out - or any other long, thin thing you can think of. Make sure your machine is turned OFF while you do this. Use a torch to help you see.
When you finish with one colour thread, cut it just after the reel and pull the thread end through from the needle. That way you are never pulling the furry ends of thread back through the tension discs.
Use a length of UNWAXED dental floss and clean out the top tension discs by running in several times from right to left through both top discs. Floss out the bobbin tension slot too while you are at it.
Is it just one particular thread that keeps breaking or any thread you use? Sometimes one thread is a rogue and you are never going to tame it. Cut your losses, save yourself some grief and throw it away.
Hope something here helps you.
Posted on Feb 02, 2010
  • 48 Answers
SOURCE: My Singer Embroidery machine works wonderfully on
HI,
Did you make sure that you raised the feed dogs? There is a sliding button on the front that you have to move sideways to let the feedogs come up. If not the fabric is not being move right and that may be the reason of the wrong stitching.
Also, are you oiling your machine appropriate?
Posted on Feb 24, 2010
What system is on my viking topaz 40 the husqvarna system 5 or system VIP?
Hello
The Husqvarna Topaz 40 can use many embroidery file formats as being shown in this Husqvarna YouTube video: https://www.youtube.com/watch?v=bFMzwLg8emQ
Also refer to your manual page 9:2 which can be downloaded for free at: https://www.youtube.com/watch?v=bFMzwLg8emQ
Happy Stitching
Sewingirl/
Mar 14, 2017 | Husqvarna Sewing Machines
How do i remove the embroidery unit from the topaz 40
Do you mean the Husqvarna Designer Topaz 40? If so, first make sure that the unit is in Park. You need the sewing machine on to do this. Select the Park Position on the Embroidery Stitch-Out menu. This screen is accessed after you choose a design and press Go (at the bottom of the touch screen on the left). Then press the release button on the bottom of the left hand side of the embroidery unit.
The directions to remove the embroidery unit are in the manual on page 6:3 (page 69 of the PDF). The manual is available from the product page: http://www.husqvarnaviking.com/en-US/Machines/DESIGNER-TOPAZ-40 . Scroll down and look on the left side of the page. The direct link to the manual is http://www.husqvarnaviking.com/SiteMedia/Products/Machines/DESIGNER-TOPAZ-40/Manual/Topaz40-manual-EN.pdf .
I hope this helps.
Dec 31, 2016 | Sewing Machines
Poor tension on a Viking Topaz 20
Is the thread coming off the Thread Take Up? That will cause issues. Another thing would be to take apart the bobbin area and clean it thoroughly. If you have one of the sewing machine vacuum attachments that would be the best way to clean it. Good luck.
Apr 16, 2014 | Sewing Machines
Hi. I have a commercial one head tajima embroidery machine. I was sewing and realized I had no thread on one bobbin so I stopped the machine. Instead of continuing on, I decided to start all over with a...
Your new embroidery program has to be loaded first. The 2b7 is referring to needing instructions or in other words the embroidery program has to be loaded. Shut the machine down and turn the machine back on and load just as before.
Jul 06, 2017 | Sewing Machines
Husqvarna Rose Embroidery Unit problem
Call Viking direct
440-808-6550
800-358-0001
Aug 20, 2009 | Husqvarna Rose
Once I set up my design card and select design, the needle moves
Hi, and welcome to FixYa. If I understand your problem, the needle goes in and out of your fabric, and the embroidery hoop moves, but the machine does not actually start embroidering your design right away....did I get it right? If have time to answer a few questions, I can give more accurate instructions.
  1. How long have you had your machine?
  2. How long have you been doing machine embroidery?
  3. Do you have a manual for your machine?
  4. Look at the back side of your design - do you see lots of bobbin thread, or hardly any?
  5. Have you taken lessons for your machine or for embroidery?
  6. When your design is finished, can you where the machine skipped stitches?
Here a couple of things you can try (if you have already):
  • Make sure you use an embroidery needle, not a universal. In most cases, you should use a size 90. Change your needle after each project. A blunt need can cause your machine to skip embroidery stitches anywhere in the design.
  • Rewind or replace your bobbin. Make sure you use bobbin thread in your bobbin when you embroider - it is thinner and gives you better tension. If pre-wound embroidery bobbins are compatible with your machine, I recommend that you try one and compare the result with designs sewn using the bobbin thread you've been using.
  • Normally, you should loosen your tension a little bit when you embroider. When you look at the back side of your embroidery, you should see more bobbin thread than embroidery thread.
I owned an embroidery business for several years, and I have six different embroidery machines of my own - so with a little more info from you, I think I can help.
Feb 03, 2009 | PfaFF Creative 7570
Pfaff creative half-speed and thread breaks
YIKES - what a nightmare! We can approach your problem two ways, but to determine whether the problem is your machine or your design, I need to know if you have been using one design, or if you've tried to embroidery several different designs and are getting threadbreaks about every 10,000 stitches, no matter what design, needle, thread, and bobbin you use.
Here are some rules you should following whenever you embroider on your machine:
  • Change your needle and insert a newly wound bobbin every time you start a new project
  • Use a size Embroidery Needle - size 90 for most projects
  • Check the backside of your design - you should see alot more bobbin thread than embroidery thread. If you don't see enough bobbin thread, loosen your top tension. If the tension is set automatically, change it manually.
  • Your design might be the problem. Some designs have WAY to many stitches. If you haven't already, choose several different designs with different styles - for example, a monogram, a design that is mostly satin stitches, a design that is mostly straight stitches, and so on. Sew one or all over and over so you determine whether your thread will continue to break about every 10,000 stitches.
I hope this helps. Machine embroidery is so much fun once you've learned and practiced. I hope to hear from you - machine embroidery is not hard to learn, but there is a lot to learn. Thanks.
If you want to get right to work, skip the troubleshooting and answer as many questions as you can or have time for. It is possible that your problem is the design and not the machine. Try one suggestion at time so you what helps and what doesn't. Questions first:
  1. Is the machine brand new, or new to you?
  2. Do you have your manual?
  3. Do you been embroidering by machine for a while, or are you just learning?
  4. Does this problem occur with every design you sew, or is it one particular design that you are having trouble with?
  5. How many total stitches are in the design you are trying ot sew?
  6. What kind of thread are you using (rayon, poly, sewing?)
  7. Did you buy the machine from a dealer, and if so, does it have a warranty?
  8. Have you taken lessons on how to use your machine for both sewing and embroidery?
  9. Are you familiar with embroidery backings, needles, and threads and how to choose which to use for a particular project?
Feb 01, 2009 | PfaFF Creative 7570
Sewing Machines Logo
23 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
