Where is the fuse for a Clarion HH1500 heater?
The heater stopped suddenly! I see nothing unusual inside the heater!
Kenmore elite microwave
Was it just the exhaust fan that came on? If so this is normal when cooking on the stove for long period of time without the fan running. The heat builds up under the microwave and eventually activates the fan.
Sep 05, 2014 | Microwave Ovens
Car amplifier just shut off and goes on and off when it wants
Driving the amplifier too hard causes it to go into protect mode to prevent damage. The amp periodically recovers and operates normally until the next overdrive peak hits it.
Apr 21, 2014 | Clarion Car Audio & Video
Basically I have a 1990 chevy 4x4 and the heater controls suddenly stopped working as you can see they lights for the controls light up but there is nothing on the display and it's not turning the blo
Although i cannot play video, i will try to help.....Have you noticed any problems with the speed options for the fan? Did you hear any noises with the fan prior to stopping altogether. If so, you may need a new resistor for the blower motor or a new motor itself.
Jan 26, 2013 | Heating & Cooling
I have a 2000 Acura 3.2TL the a/c suddenly stopped
Check your fuses, sounds like the HVAC or AC fuse may be blown.
Apr 27, 2010 | 2000 Acura TL
Hi, My dryer suddenly stopped drying. No power to
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting...
Sep 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Heater stopped working suddenly
In the past I have nothing but problems with DeLonghi heaters. I replaced them with Pelonis heaters and have had no problems since. Pelonis heaters are availible from Home Depot at a very reasonable price. This is based on my experience only. Hope it helps.
Ray
Dec 05, 2008 | DeLonghi Heating & Cooling
1998 Jetta my heater won't work, fan or nothing works on it
Try and giggle the switch, wears out sometimes, if not its probably the blower-engine thats done;)
Nov 28, 2008 | 1998 Volkswagen Jetta
The fan and the heater do now work !
check for a tripped overload. reset or replace it.
Nov 22, 2007 | Clairion Convection Heater - HC-1500
Clarion dxz545mp doesn't power, does not work.
Check the fuses in the fuse block under the hood. Your clock fuse and radio constant power fuse are combined in this vehicle.
Jun 11, 2007 | Clarion DXZ545MP CD Player
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
