Question about Gateway Computers & Internet
Gateway Monitor MOdel GTW-L13M103 Built in 2003. Can I connect to internet with this monitor?
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hello
YEs you can !
you inly need a analog converter, or conector for your particular PC. and that's all. or you can use a box that connect analog for example an Internet ready box, attach to analog or coaxial cable to your monitor.
Posted on Jan 30, 2017
  • 4 Answers
SOURCE: Gateway 19 in flat monitor Model 900G
I need the power cord. Please sell/give to me?
Posted on Oct 12, 2008
Bappa170873
  • 505 Answers
SOURCE: monitor doesnt work
You can check the fuse on the monitor and replace it. In case the fuse is OK check the cable connector, display card on the motherboard.
Thanks
Posted on Oct 17, 2008
nadine36
SOURCE: No audio from lcd monitor (viewsonic) after disconnecting my speakers. (New monitor has built-in speakers)
iv no sound coming from my monitor speakers but if the child plus a earphone into the back of my pc he can hear sound can u help me plz nadine1 :)
Posted on Jan 02, 2009
rjwharris
  • 102 Answers
SOURCE: Installing monitor problem
The Gateway FPD1530 is plug and play and should be automatically detected by the Operating System. In your display properties it will say plug and play monitor as Monitor type.
Posted on Jan 08, 2009
  • 555 Answers
SOURCE: Gateway Monitor goes blank after a few seconds after startup.
Sounds like the inverter is broken or have a short circuit. This is a common failure on TFT displays.
Here is a website explaining this kind of failure:
http://josepino.com/?howto-repair-dell
Posted on Oct 09, 2009
Gateway GT5040 Graphics Card
This model Gateway desktop computer has a built-in video card.
Connect the monitor to the Gateway motherboard video port and the boot up and go into the BIOS and select disable the built-in video.
Shut down then connect the monitor to the 8800GTX video card and boot up the Gateway computer. The video should then appear in the monitor.
Feb 14, 2013 | Gateway GT5040 PC Desktop
Where is the microphone
That model does not have a built in microphone, you will need to get an external mic and connect it to your computer.
May 08, 2012 | Gateway FPD1975W 19" LCD Monitor
I have 2 gateway t series laptops..... they both have a black sreen ...have to use external moniters
If you are able to use an external monitor then the video card in the laptop is working perfectly. The monitors built in however have failed. The most common situation is that the lamps burnt out, but it is possible that the wire that connects to the main board has been damaged from opening and closing the lid.
You could search the internet for a replacement monitor, but I would recommend one that has the casing and everything. It is extremely troublesome to remove the casing and change out just the panel.
Often you can find an identical model laptop on ebay that has a working monitor but other component failure and then you can either swap your components or just the monitors, whichever is easiest.
Aug 16, 2011 | Gateway FPD2275W LCD Monitor
I have a compaq presario computer using a compaq monitor. I have a Gateway HX2000 LCD flat screen monitor (year 2009) that I want to us instead of my compaq monitor. I have disconnected the compaq monitor...
I'm guessing the different monitors are different sizes? The only thing a driver for a monitor will do will tell the computer the max resolution that the monitor will be able to go up to. However most 90% of monitors can use the built in windows driver without issues. Your best bet is going to be to change the resolution on the monitor. To do this you can either hook up the old monitor, lower the resolution, and then plug in the other monitor. Or you can boot the computer into VGA low resolution mode by pressing F8 as the computer starts up and selecting that option. From there you can lower the resolution, and then put it at something more desirable with the new monitor.
The other possibility being your Gateway monitor is actually malfunctioning and you just happened to hook up a bad monitor.
Mar 27, 2011 | Computers & Internet
No image just sound
Inspect the power supply board, Z-SUSTAIN board, Y-sustain board for blown fuses, caps, IC, Transistors.
Boards: http://www.shopjimmy.com/catalogsearch/result/?q=Gateway+GTW-P42M303
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 19, 2011 | Gateway GTW-P42M303 42 in. Plasma...
My Gateway GT5465E cannot obtain an IP to connect to internet. The network card is built. All network drives are loaded and DSL modem is working.
Go to network sharing center. You can do this by right clicking the icon on lower right. Left click the internet connection once and then select repair. Am I being clear here?
Jan 04, 2011 | Gateway FPD1975W 19" LCD Monitor
A Gateway GTW-L17M103 will not power on, no power lights/menus.
Have you read the manual for trouble shooting? Is there a reset button on the unit?
Screen brightness is diminished?Video display devices experience degradation of brightness over the life ofthe device. Normal brightness degradation is not covered by your warranty.
You cannot see a picture?Make sure that the power cord is plugged into a grounded electrical outlet.?Make sure that the power button is turned on.?Make sure that the selected input source is connected to a working inputsource.?Press thecorrect input source.?If your LCD TV is connected to your computer in RGB or DVI mode, pressany key on your keyboard to "wake" your computer.You see a distorted picture or hear unusual sound?You may be getting interference from electrical appliances, cars,motorcycles, or fluorescent lights. Try moving your LCD TV to anotherlocation.The color is abnormal?Make sure that the input source cable is connected securely and correctlyto the back of your LCD TV.
Get schematics and look for fuse and voltage points
Feb 28, 2017 | Gateway LCD17TV 17 in. Television
GTW-L17M103 LCD TV
perhaps a computer repair shop .
Dec 11, 2017 | Gateway LCD17TV 17 in. Television
Solve GSM CMS Errors......
I'm using also smslib and nokia 6020 phone for sending and receiving SMS, but i've some trouble with reading messages, would you please tell me the configuration for the modem, i used this one :
ModemGateway gateway = new ModemGateway("modem.com4", "COM4", 4800, "Nokia", "Nokia 6020", srv.getLogger());
Oct 01, 2007 | Microsoft Office Outlook 2003 for PC
Computers & Internet Logo
47 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
