Question about Emerson Audio Players & Recorders
I need to add an external AM antenna to boost my reception. Where should the external wires from the antenna be connected inside my Emerson CKS1850?
SOURCE: Internal Antenna not working anymore
if you do a search at pdaphonehome.com a guy has replaced his antenna and provided step by step instructions for how to do it yourself with pictures. I don't know if frying it can make sure getting a new antenna will fix that but thats something you can try before replacing.
Posted on Sep 04, 2007
sapperj
  • 70 Answers
SOURCE: better fm reception
Is it just a single wire?
If so, purchase a cheap FM antena. It looks like a "T" when spread out (4' to 5'). That should help.
You can purchase an "amplified" antenna, but if your area reception is really bad (such as in a valley) the antenna would just amplify the noise as well. Look for web based radio in this case or if you have cable there are stations on it.
Jeff
Posted on Jan 11, 2008
  • 319 Answers
SOURCE: radio reception
Use a dedicated FM T-strip antenna avialable from Radio Shack or even Wal-Mart
Posted on May 07, 2008
  • 814 Answers
SOURCE: Radio/tuner reception
You will need to buy a signal amplifier antenna. One that doe not have to be connected to the Clock/Radio. It will provide the amplified signal and the radio antenna (the a/c line cord and the back of the clock/radio) will be able to pick up the signal from the amplified antenna.[http://www.radiolabs.com/products/antennas/am-antenna.php] this web link will show you one type of these antenna's. Copy the web link and paste it into the address bar in your browser. It will take you to the website. There maybe other types of these antenna's but this one had the best price. Call the store and talk to them before you buy the antenna to make sure it will work in your situation. I hope this information helps you with your antenna problems.
Posted on Jun 12, 2009
Grubhead
  • 5444 Answers
SOURCE: Kenwood RV7030 audio-video stereo has static without antenna
OK I am going to suggest two aerials for you. I would also NOT use the old cable as it will cause a lot of problems. It is best to replace it with the stuff they use for satellite dishes (see image).
The FM aerial will pick up signals from all sides. The TV aerial should give high quality signals and output for at least 5 sets.
Posted on Apr 08, 2010
I'm having trouble getting a signal using a boost waves TV remote controlled rotating antenna. No signal
It may be too weak to receive and re-adjust external signals. Return it for refund.
Jan 04, 2015 | Toshiba Televison & Video
My Saturn factory AM/FM radio on my 1996 SL gets some FM reception but no AM reception. I am trying to determine whether I need to repair the antenna or the radio.
You will need to pull the radio out of the dash and make sure the antenna is still pluged into the unit. If the antenna is in the windshield make sure the glass is not broken, and the wire broken. If there is an external antenn, you need to check the connection at the bottom of the antenna, and the wire is good between the antenna and the radio. Has any new items been mounted recently, the screws could have damaged the coax.
Rian
Aug 31, 2011 | 1996 Saturn SC
FM radio reception is poor. User manual suggests connecting an external antenna. Where do I connect it?
Hi, I think your units model number is AJ6111. According to the owners manual, the FM antenna is integrated to AC Power Cord. So you can not add antenna. But you can try to re arrange the cord and perhaps add an extension cord to see if reception gets better.
If this is not the unit you have, please try to provide the model number so I can look up the right owners manual and try to help you.
Good luck.
Mar 21, 2011 | Philips Under-Cabinet Alarm Clock Radio...
Am fm reception bad
FM reception is weak
What to do
• Extend the power cord as much as possible. The FM antenna is in the power cord.
• Move the power cord to adjust the FM antenna
• If you still have problems with FM reception, you may need an external antenna.
* Call Bose®Customer Service to request one.
The external antenna on your radio is a coax (round) design It needs an adaptor and an antenna which are cheap.
Easy to make, radio shack "F" connector 90 degrees or straight, to 300 ohm wire connections. Attatch a 300 ohm flat ribbon antenna cable to those two screws and plug into radio and see how your reception is. You will need to position the antenna wires to get best reception. I have hid them in back of paintings and so on.
Cheapest solution next to putting an extension cord on radio power cord.
Jan 03, 2011 | Bose Wave Radio
How to add external antenna to a GE 75300 GE Slim Spacemaker
the antenna is internal (I couldnt find an external adapter) - u need to open the top (20 or so screws). Theres a "pipe" thru the back that leads pretty straight into the antennae. Hook ur metal to the closest bundle and out the pipe.
My reception still isn't perfect, but you can listen to it. I moved the ac power code to the far side and gain some improvement as well.
Dec 03, 2009 | GE Spacemaker 75300 Shelf System
Awful AM reception on Sony ICF-CD513 kitchen radio
You may have to use foil or other metal to extend the antenna artificially. I found years ago that even wrapping my hand around the end of it boosted the signal (though I'm sure you're not willing to listen to a radio while holding the antenna the whole time). I once sat a TV antenna on top of a portable CRT with its own internal ferrite antenna, and the video signal was about 80% there, audio 100%. This may be an inconvenient method, but it will guarantee at least most of the audio quality you want.
Jan 30, 2018 | Sony ICF-CD555TV 7 in. Portable Television
Poor antenna reception
That's a problem with the digital broadcasting. Signal strength is critical, and the frequencies used are more directional. Some people are finding they get no reception at all. Your antenna may not need to be higher, but aimed in a different direction. Did you have a rotator installed as well? An outside antenna really should be pointed toward the station. You might also be able to add an amplifier to the antenna to boost the signal. But get a mast-mounted version that mounts right at the antenna, not the kind that goes at the TV set.
Apr 09, 2009 | Televison & Video
Feb 21, 2009 | Emerson Smartset Clock Radio
Radio reception
May 01, 2008 | Audio Players & Recorders
Better fm reception
Jeff
Jan 11, 2008 | GPX HM3817DT Shelf System
27 people viewed this question
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
