Question about Epson Office Equipment & Supplies
Epson 3640 won't copy. Only scans. This just happened? Also new a message insert cassette 1 correctly. Haven't touched cassette??
  • Epson Master
  • 21,011 Answers
You have to comply with error messages.
Remove the wall plug.
Remove the cassettes all the way out, most have two. Check inside for paper, or any bits of paper covering the cassette drawer open sensors. Replace the cassettes.
Plug the machine back in.
Posted on Dec 30, 2016
Epson wf 3640 can't recognize cartridge
Remove the cartridge and carefully clean the chip contacts, using a cotton bud dampened in Isopropyl Alcohol. Also clean the contacts in the machine.Allow to dry after removing any excess, with a DRY cotton bud. Then replace the cartridge firmly and securely. Do NOT touch the chip or machine contacts with your fingers.
Dec 10, 2017 | Epson Office Equipment & Supplies
Have error message Time for maintenance cassette 1. The machine is fairly new, why am I receiving this and what do we do?
I'd first try to make sure that the Cassette 1 is inserted/seated correctly. Depending on what equipment this is, the cassette that came with it may not have been as full or you have simply used the cassette up sooner than you anticipated.
May 17, 2017 | The Office Equipment & Supplies
Epson 3640 WF. I cannot send a fax unless i add the fax number to my contacts. I do not want to save every fax number I fax to. How do I stop this?
read your user manual as to how to stop that request
normally you insert the document to be faxed , enter the fax number and press start
Dec 21, 2016 | Epson WorkForce WF-3640 Wireless Color...
How do I use top feeder on Epson WF-3640?
Download manual from link http://failiem.lv/u/oqcbkkq It will be available 1 month. In pdf. file see page 86 and 228 how to print more than 1 page.
Sep 24, 2015 | Epson WorkForce WF-3640 Wireless Color...
How to resolve error 0x97 on Epson WF-3640?
Error code number 0x97 is most common error in Epson printer, well there is lots of way to get rid of this issue i suggest you to watch this video n get rid of this error hopefully it will work
Jul 03, 2015 | Epson WorkForce WF-3640 Wireless Color...
My epson black ink wont print??
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
Oct 10, 2012 | Epson Stylus Sx235w Inkjet Copy Print Scan...
Keeps saying paper cassette no set correctly or objects blocking path
I was also stuck with this error message for a while. It turned out to be a 4x6 photo paper got stuck in back in a place that was not easily visible. I had to detach the double-sided paper module from the back, tilt the printer on its side and reach in with fingers and pliers to pull it out. The error message was correct, that something was blocking the cassette tray even though you could push the tray all the way in!
Jan 31, 2012 | Epson Artisan 800 All-In-One InkJet...
Trying to print - got Warning message THe paper cassette is no set correctly. Check for any objects in the cassett of block the cassett path and insert correctly
This can also be caused when the upper cassette tray (for small paper stock / photo paper) becomes detached from the lower tray. There is a gear attached to the lower paper tray which handles movement of the upper paper tray. Make sure that moving this gear causes the upper paper tray to move. If it doesn't, then you need to snap the upper paper try on a little better.
Jun 26, 2011 | Epson Stylus Photo 810 InkJet Printer
71 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
