Question about VIZIO P552ui B2 55 Inch Ultra Smart
I have a Vizio 55" 4000HD tv model P552ui-B2 and there is no picture but the light on the bottom corner of the tv comes on when plugged in
Worked fine turned it off to go to bed and next day the picture never came back on. When it is plugged in the white light on the bottom of the tv goes on showing its been plugged in I assume but when the power is pushed the screen never comes on and that light goes out after a min. Any idea what the problem could be or how I could figure out what it is?
    Top Expert:
  • Vizio Master
  • 74,666 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Dec 31, 2016
  • 155 Answers
SOURCE: Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Posted on Oct 26, 2008
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
stonephoenix
  • 563 Answers
SOURCE: Vizio VX32L The screen goes white,no response from buttons
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 28, 2009
SOURCE: We have a Vizio model # GV47LFHDTV10A. When we
For the cheap guy like me who will probably do more harm than good:
Also check for the F3 Fuse on that same main input board. It is located in the upper right corner. Hard wired fuses; very small. You will see F1-F4 (F4 is empty). You can solder a replacement fuse right over it. I would recommend piggybacking the fuse with a fuse you can replace. Will need the holder and a new fuse. 6 bucks.
Doesn't solve problem, but I can go another 2 1/2 years and the wife won't blame me for screwing up the TV in the first place.
Posted on Feb 14, 2010
My VIzio E550i-B2 TV has no picture and no sound. Do I need a new power supply board?
What does the power indicator on the front of the set do when the on button is pushed?
Nov 29, 2017 | Vizio Televison & Video
Vizio E550i-b2 has no picture
Could be an open internal fuse or power supply failure
Aug 16, 2016 | Vizio Televison & Video
Vizio Customer Service said that I have a Partial backlight failure and unrepairable. My question is how do I repair this?
Hi Chad,
Partial backlight failure in LED TVs means some of the LED bulbs in the backlight array have gone bad. It is repairable by replacing the bad strip. Some times when the strip is not available, the defective LED alone can be replaced. But, the job is risky, and delicate. There are chances of damaging the panel if you are not in practice of doing it regularly. Your set being 55" means you have to be extra careful while doing this.
Good luck.
May 26, 2016 | Vizio Televison & Video
My vizio model# E480-B2 was working fine one day and the next when I turned it on I have no picture.. Perfect sound ! Does anyone have any ideas?
Hi , The link below is a YouTube page full of videos showing how to fix a Vizio television NO picture GOOD sound, I hope this helps....... CHEERS..
Vizio Tv With No Picture Good Sound YouTube
May 09, 2016 | Vizio Televison & Video
When I exit out of Netflix the TV stops responding. the remove will not change anything. I have to unplug the tv and after it powers up all is fine.
This will happen if the input on the TV is not switched back to cable or TV. Did you check that (you will have to use your TV remote)
Dec 28, 2015 | VIZIO P552ui B2 55 Inch Ultra Smart
Vizio TV has sound but no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Dec 02, 2015 | Vizio Brand Original Remote for E320i-B0...
Vizio e420vse
If your TV is under warranty you have to contact the store where you brought it..
Jan 17, 2013 | Vizio E420VSE 42" 1080p 60Hz LED LCD 2.4"...
VIZIO P552ui B2 55 Inch Ultra Smart Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
