Question about Patton Heating & Cooling
How to jumper the high low switch on patton space heater
SOURCE: Patton space Heater Model # prh-5
check that the rocker switch inside isn't stuck, when the rocker swings it shuts the unit off. if it is full of dust it may be stuck. may just be bad.
Posted on Dec 22, 2008
  • 56 Answers
SOURCE: looking for a phone number to contact PATTON SPACE
Patton at l-800-528-6600 ext. 1722 (Arizona: l-800-352-0458 ext. 1722; Alaska l-800-528-0470 ext. 1722)
Posted on Apr 01, 2009
co7196
  • 3433 Answers
SOURCE: HF 8 Space heater with a bad switch
If you locate and procure a switch, you can more than likely replace it yourself. Get a switch of like and you can see what you have to deal with, Always disconnect the electricity before you work on it Good Luck. It really isn't a big deal to do.If you can take and send pics by e-mail I can walk you through. Co7196@yahoo.com
Posted on Aug 23, 2009
SOURCE: Patton PRH11 Buzzer Sounds on HIGH after 2 minutes
There is a round sensor under the heating elements which sets off the alarm when it thinks it is overheating on the PRH11. Unfortunately, a dirty sensor will fool it into reacting like it is overheated. I cleaned the sensor which was dark and revealed it to be a lighter goldish maybe brass in its original color. If your sensor is dark, it will continue to trip the alarm for overheating and will need to be replaced. If you were lucky like I was and can clean it, the problem should be resolved and it will operate like normal until it gets dirty again. This procedure lasted for 3 days and I had to clean it again. I believe I left the dirt on too long and now my sensor has tarnished plus I live in a rural area with significant dust requiring this recleaning every few days. I only used a damp paper towel with water to clean. Cleaning may work better with alcohol or a tarnish removal solution.
Posted on Dec 11, 2009
heatman101
  • 43501 Answers
SOURCE: my Patton PUH680 space heater is not working. Do
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Posted on Jan 16, 2011
Patton space heater power knob isn't working
First thing check see if you have power going to switch with a multimeter if you have one if there's power going in it switch need new switch probly you can us your multimeter to test switch on ohms
Mar 01, 2013 | Heating & Cooling
Will the patton electric heater significantly raise my electric bill
1500 watts is 1.5 kilowatts. Run it for 1 hour and you have 1.5 kilowatt hours. My electricity costs .08 per kilowatt hour so, when I run my 1500 watt space heater, it costs me a whopping .12 per hour to operate. I can afford 12 cents per hour, compared to oil at $3.50 per gallon and a burner that burns up to 3 gallons per hour.
Dec 23, 2012 | Patton Electric Patton PUH680-U Electric...
I purchased the Patton PUH9000 heater last year. I puts out a lot of heat at first, but shuts itself off after about 5 minutes, then cycles back on after a couple of minutes. Is this normal operation? I...
These have poor quality safety parts that fail in about 1 season or less, the failure rate for these little cheaper units is high, go Honeywell next time!
Jan 11, 2011 | Patton PUH9000-U Heater
My Patton PUH680 space heater is not working. Do you offer replacement coils?
heatman101
Dec 06, 2010 | Patton PUH680-U Utility Heater
Aug 23, 2009 | Heating & Cooling
Looking for a phone number to contact PATTON SPACE HEATER COMPANY
Apr 01, 2009 | Patton Electric Patton PUH680-U Electric...
Nov 12, 2007 | Patton PUH680-U Utility Heater
Space heater will power up, but not start,
These fans have a safey feature (sensor) that shuts the heater off if it is tipped over. It sounds like this component is not functioning correctly - may be set wrong and will not allow the heater to turn on unless you shake it to reset the sensor. If it is still under warranty return heater, if not call Patton and ask for help.
Mar 28, 2007 | Patton PUH9000-U Heater
Heating & Cooling Logo
Top Patton Heating & Cooling Experts
Mack Baxter
tractorman44
tractorman44
Jay Finke
Jay Finke
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
