Question about Refrigerators
We bought used fridge Inglis/Niagara Model ICT85000 Mfg06/93 when we close fridge door freezer door opens. When we close freeze door fridge door opens. This is a top freezer. Is there a repair
  • Refrigerators Master
  • 19,019 Answers
Inglis are a budget make. The cold for the fridge comes from a vent from the freezer. Don't let the door slam. You must close them gently.
Posted on Dec 30, 2016
I can't get a regular temperature in my old brown Danby Inglis frig . It is freezing every item in the frig even at the lowest ajustement. Can you help me?
Most likely temperature control thermostat needs replacing. Also check damper between fridge and freezer. If mechanical, adjust where less air is going in fridge section. If not mechanical, but electric, damper door may not be closing.
Sep 23, 2017 | Danby Refrigerators
I have a 23' free standimg dispensing side by side ref. my ref is not cooling but the freeze part is working
when you open the freezer door do you hear the fan blowing?all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer and into the fridge side,there are ducts on the bottom left side where the air return sto the freezer,if that's blocked the fridge will get warm,also if the fan is blowing depending on your model you could have a damper,it's in the fridge section up top where the cold air blows into,all it is is a door that opens and closes to let the air in when the fridge section gets warm and then it closes when it's cold enough,if the damper is bad it won't open and let the air in,sometimes it gets stuck in the open position and things start to freeze in the fridge section.if you can't figure it out send the model number and i can see what model you have,open the fridge door,look up on the right side near the ceiling and you should see a tag with the model number.good luck and have a great weekend.also from the bottom up in the freezer,remove the second bin of food and touch the back inside wall of the freezer,if there's frost or like snow on the back inside wall of the freezer you have a defrost problem,let me know what you find.
Aug 07, 2012 | Kenmore Refrigerators
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent holes.so let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
Jun 12, 2011 | Maytag Refrigerators
Hi,I bought a fisher and paykel refrigerator E450r model for over 2 yrs now. Once you open the door, you can hear a beep sound. You can also hear this sound while the door is open and even when the door is...
I unfortunately bought the F & P 450R upright fridge with the matching freezer, recommended to us by Winnings. Expensive and possibly the worst ever appliance purchase I have made. The door handle design is pathetic and once again today, has come apart. The fridge constantly freezes up which then affects the fan, which in turn stops the fridge getting cold. To date, we have had the F & P service out, he first said he needed to get it back to the factory and we'd be up for about $900. After we advised that wasn't happening, he replaced the control unit, which had didn't clear the problem (although still cost me $300). Having no confidence in F & P, we contacted a fridge mechanic with a good name. He closed his eyes when he saw the brand and mumbled, Kiwi's revenge. Long story short, over 3 visits he, adjusted the inadequate door sensor, refitted a temp sensor which had broken from its poorly designed plastic holder, replaced all the sensors and in the end said sorry, but you have bought a lemon. I now have a choice of buying a new fridge which wont match the freezer, buy a new fridge and freezer, even though the freezer is fine, or continue with what we do now, turn the fridge off every other day for 4 or 5 hours to defrost it. My solution, do not go near Fisher and Paykel, the service and machines are just not up to it.
May 31, 2011 | Fisher and Paykel Refrigerators
After you open and close the refrigerator on top, the freezer drawer pops open. it is now leaking water.
check to see if the fridge is tilted back a little so the top door closes with just a little shove,also if there isn't any weight on the freezer door it will pop open,put something on the door,a bottle of water that will freeze or whatever you want,it could be leaking from stuff melting from the door being open, is the water dripping from the door?the door does freeze up and will melt out if door is left open, hopefully your air ducts didin't freeze up,make sure you can feel cold air blowing into the fridge section,if not heat up the back wall where the evap fan motor is with a hair dryer the air ducts are near there and check the freezer ceiling for frozen water droplets,hopefully everything will freeze back up with the door closed.
Jan 28, 2010 | Amana ABB1927DE Bottom Freezer...
Frigidaire refrigerator model #FRS26R4AW7 is freezing up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 03, 2009 | Frigidaire Refrigerators
6 yr old side by side inglis fridge/freezer. water
can be from an obstruction (i.e. food or debris) or incomplete defrost. water forms around the drain during defrost cycle and ices up when cooling cycle comes on. defrost the drain and try installing a heat probe part#819043 made by whirlpool.its a metal rod that wraps around the heater and goes into the drain opening to prevent the drain from icing up. hope this helps.
Oct 21, 2009 | Kenmore Refrigerators
Buyers Beware!
go to sears
Aug 14, 2009 | Refrigerators
Can't find the adjustment for the freezer on my Inglis fridge. Model-IRT184300 Ser.VST3315228
hi thanks for the question i looked at your model no and your control is as you open the fridge door its right there on the roof of the fridge in the middle thanks for the question the appliance doc
Sep 13, 2008 | Refrigerators
Maytag fridge
Without knowing the type of fridge(side by side, freezer on top etc.) all I can offer is this: Somewhere between the freezer and the fridge there's an opening thermostatically controlled to transfer cold air from freezer to the fridge. Most have a fan to move the air. So either the fan (if so equipped) stopped, and need to replace, or opening is stuck closed, or plugged.
If freezer is working fine, this is the only problem I can think of.
Hope this helps
Dec 15, 2007 | Maytag MTB1504A Top Freezer Refrigerator
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
