Dosn' t work the power supply on KV29C3D SONY
I have this tv set and i have a problem with power suply. i turn it on and nothing haped just the relay 602 works. also the StBy +5volt works and i have 304 dc volt on diode d601. where is my problem because all resistance are ok.
  • babis4444 Jul 21, 2009
    I have a circuit diagram for this set but i can't understad where is the problem. for example the stby led flash one time when the power turned on and nothing alse. why i can't measure ac voltage on sonverter;
  • 431 Answers
Hi I am vortash sounds like you really need a circuit diagram for this set to check all nominal voltage out put on the smpsu , check this site out and they may be able to download one to you free .. if not a recent set . http://www.eserviceinfo.com/index.php?what=search
Have you considered it may be a remote or swirtch processor fault not turning the set on ? just a thought difficult when the set is not in front of you lol, regards Vortash
Posted on Jul 21, 2009
After a lightning stike, the TV will not turn on at all. No lights. Is it the power supply? Is it worth fixing?
is 30% chances that only the power suply is broke, and after a lightning ...is beter to go to a profesional repair shop and check it there.
if the power suply is external before u go to a serice u can try whit a power suply that got same V and A
best regards.
P.S.
i dont wana upsad u but prepare for worst
Sep 22, 2011 | Sony KP-57HW40 57" Rear Projection...
Hi. Sony KDL46WE5 purchased aug. 2009 here in moscow , left in it's own box until ~ june 12th 2010 and then installed / switched on first time. To our amazement , yesterday 23rd november 2010 - it just...
U check the power source?Yes,than tries the tv unplug,replug it back like about an hour later,the tv now it resetting itself back to the factory setting.The tv should work now.If not,the tv have the same problems it complete dead.Than the tv power supply board is problems and the causes.That the board,where the tv power a/c cord plug into it.Ur tv is design for Eroupean and PAL frequencies signal broadcasting used.The refurbish power supply board u going to buy for this tv for the replacement,make sure it for a PAL tv.Tries websites like Shopjimmy.com,Ebay.com Europe side,buy a refurbish power suply board for the replacement.
Nov 24, 2010 | Sony Televison & Video
Turn on and few seconds goes off
The fan is cooling the power suply and geting power from it the power suply is going bad the relay is turning the tv off to proteckt it's self.
Nov 24, 2009 | Televison & Video
SANYO DP26647 blank screen, please help
U have LED front power tv light come on and bliking?Than ur power suply it dead.Power supply board must be replaced.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board.
Sep 21, 2009 | Sanyo DP26647 26 in. LCD TV
No sound or vision set tripping power supply ?
no, you need the main board
if the tv turn on you need the main board if your
tv do not turn on you need the power suply
Aug 13, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Sony Trinitron does not turn on
first of all, check the ac cord if broken, then go to power suply section, checked for burned fuse (if positive) replaced the power regulator I.C. and checked also the other parts (resisitors, diodes, etc)
Jul 30, 2009 | Sony KV-13M10 13" TV
No picture, TV dead and the relay on the power suply cliks once
Did you replace these Items?
IC1509(V out) i
Q1505(V Pulse Buffer)
Jun 18, 2009 | Sony KP-53S75 53" Rear Projection...
Sony 52inch projection nothing happens,timer light blinks all the
check powr suply for a sony wite ceramic fuse 0.01 ohm
if open rebuild or replace power suply befor turning on the unit check the H.O.T high v transistor if shorted replace and also replace vdr610 602 and 603, depending on set flyback should be changed also due to a know internal arking problem with sony fly backs.
25% of the time its just the power suply that goes bad.
Jan 09, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony tv wont turn on, standby light just flashes
check for an open resistor on the power supply, it is actually a fusible resistor, (white) if open, then check the converter, some sets have two separate and some have it as one. it will be on a heat sink on the power supply. if shorted then check for a shorted horizontal output transistor and repair cold solder joints on the horizintal drive transformer which is the real cause of this problem
Jan 07, 2009 | Sony KV-27S46 27" TV
Tv no go
the circuit board will be damage as well , new tv is needed
Apr 12, 2008 | Sony KV-27S20 27" TV
Televison & Video Logo
171 people viewed this question
Top Televison & Video Experts
Electro Med Services...
