Question about Refrigerators
Refrig is leaking a white/ creamy substance from bottom right door above the grill
  • 1673 Answers
SOURCE: air leak
Check the seal that is in place between the top and bottom sections. If it came out of place even a little, it will leak and you lose suction. Part number 03611180, it is called a buffer.
Posted on Jan 15, 2008
  • 43501 Answers
SOURCE: MDB9600A Jetclean II Built-in Dishwasher: leaking around door right side bottom...
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
Posted on Sep 29, 2010
  • 183 Answers
SOURCE: what is the oily substance leaking from beneath
The compressor uses oil for its lubrication and part of the oil is entrained with the freon in the condenser/evaporator circuit. Could it be a leak in the system? If the system is still working properly, that is very puzzling. You may need to have it checked by a repairman who can help you locate and verify the source of the oil.
Posted on Dec 12, 2010
  • 100 Answers
SOURCE: there is a white creamy substance around the oil
that substance is conensation
this isusually caused by a mixtur of oil and water condesating from the heat of the engine
with engine off, pull oi; dipstick and check color of oil
if oil is same color as condensation, u have water in oil and there is a problem
if oil is proper color or black if its dirty,then the condensation is just normal
some engines get it,some dont
Posted on Dec 14, 2010
  • 472 Answers
SOURCE: I have a side by
couple of things to check if you have a dispenser on this model there is a hose that goes up into the bottom of the freezer door you need to remove bottom kick plate and take a look at this...also if no water from that hose and its actually coming from the door you could have a ruptured line in the door itself.... next make sure the water is not actually coming from the freezer compartment as the drain in the freezer could be clooged and leaking over on defrost mode and out door...
hope this helps good luck...
Posted on Jan 05, 2011
Refrigator icing at bottom then leaking
bad door seals causing condensation and water accumilates in fridge
Aug 25, 2014 | Whirlpool Refrigerators
My 97 Neon has white oily substance in radiator
Hi it sounds your head gasket need's replaced ,,,As for the water creamy white that means that oil is getting in to your water .
The head gasket has gone water can get into oil
but it also oil can get into water can also
water can be lost down the exhaust.
Replace head gasket clean out radiator
Jul 30, 2013 | 1997 Dodge Neon
The display show service and blinks, i Kent cleared
A leading cause of so many problems with Sub-Zero refrig's is the coil behind the top grill above the doors is clogged with dust. You can use a vacuum with a hose to clean that coil by removing the grill and cleaning it. To clean it remove the grill by removing the screws that hold that grill to the upper door frame where the grill attaches to the door frame and unhook springs from back side of the grill so it can be taken off to clean the coil.
Aug 11, 2011 | Sub-Zero 661/F Side by Side Refrigerator
When the weather is hot and humid, our sub-zero seems to barely work. Freezer works fine, but the upper part is a joke.
the leading thing causing that is a dusty condenser coil. to clean that remove the grill above the refrig, and the white painted plate behind that and vacuum the coil on right side ,typically the grill is held on by springs and a either 1 screw in the center or 2 screws on the corners of the rim above the door,remove grill by opening refrig. door and remove screw tilt grill down and disattact springs
Good luck, i hope this helps
Jul 31, 2011 | Sub-Zero 650 / O Bottom Freezer...
There is a white creamy substance around the oil cap what would cause this
The white creamy solution is oil mixed with water. Take out your dipstick and check for the same substance, if so, you have a blown head gasket. If not, it's just condensed water in your valve cover that mixes with the oil, witch isn't really a problem. Have a nice day!
Dec 14, 2010 | 1999 Volkswagen Beetle
Leaking from under front. no water inside. removed front grill, can't see drip pan, where is it, want to check if over flowing.
you are looking in the right place it should be right under the bottom front of the refrigerator behind the grille. are you missing the condensate tray? (drip pan)
Jul 22, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
A GE Profile Model, double door refrigerator with a water leak
If the leak is on the refrig water valve where the wall water line connects to , then use a 1/2" wrench and tighten the fitting on the water valve itself . If the leak is on the plastic tubing at the bottom of the refrig water valve , pull up on the small white ring while pushing down on the plastic tube to remove it from the valve . Cut off about 1 " of the tubing and reinsert it into the valve with pretty good pressure to be sure it is inserted completely .
Mar 27, 2010 | GE Refrigerators
My car started smelling funny...pulled over lifted hood and it was steaming...white smoke came from under hood and tail pipe, car would not start again. Some say it may be a head gasket? How would I know?
You can tell by looking at dip stick if the oil has a creamy white substance there is antifreeze getting in oil (blown head gasket) or if ther is excessive white smoke coming from exhaust pipe upon acceleration. steam from under hood may be a coolant leak from a rubber hose or it may be leaking from the cylinder head onto the exhaust manifold also the car will be using up antifreeze.
Jan 05, 2010 | Ford Escort Cars & Trucks
Oil cap
Yes this is a potential problem,
1.) moisture from not changing your oil often or car was sitting.
2.) Head gasket is blown causing coolant to blow through into oil.
When you pull dip stick is there white creamy substance on the dipstick
Jan 14, 2009 | 2003 Toyota Sequoia
Water leaking from bottom of unit
For original poster: Check all milky white colored (polyethelne) plastic water lines. These lines tend to get brittle and can crack over a period of time. They extend from the water valve to the ice maker, and from the water valve to the inside of the refrig to a "radiator" so the water can chill, before it runs back out the refrig, past the left side of the refrig behind the bottom grill, through a coupler, and up through the bottom hinge of the freezer door. I'd also advise putting in a separate shut off for the water supply to the refrig so you can have water to the rest of your house when you have a problem with the refrig.
For next user with similar problem: you can check the above, but it may be that the defrost drain is plugged. (on a S x S unit, it is located at the bottom of the freezer compartment, behind the back wall.) If you have a layer of ice on the floor of the freezer, that's a dead give away of a blocked defrost drain tube, Use a turkey baster with hot (not boiling) water to flush it out.
Aug 31, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
