Question about Microwave Ovens
I need a ceramic oblong insert model # 161943 listed 9H06 E195659 120 VAC 60HZ260 WATTS
  • Microwave Ovens Master
  • 3,094 Answers
Hello Mel Saenz,
While true...
We don't SELL parts... but often we can be of assistance
getting you pointed in the right direction...
FINDING THEM.
Unfortunately your "model" is NOT resolving into any "MICROWAVE"
Neither your wattage is not matching any "microwave"
I know of...
If you repost your question with the MAKE & MODEL
perhaps we will all have better luck...
Search Over 2 1 Million Appliance Parts
partsselect.com
PartSelect Appliance Parts and Repair Help
searspartsdirect.com
http://searspartsdirect.com/
Posted on Dec 30, 2016
GE Model # JVM7195SFSS microwave.
Check the internal ceramic fuse on the circuit board. Sometimes one section will work while another won't. I'm not sure if this model has a rear mounted thermal fuse, but the models with the inline thermal fuse will cause a similar issue.
Jul 04, 2014 | GE XL1800 1100 Watts Microwave Oven
No power
i had the same problem and did what this fella suggested and worked just fine. There is usually a 125V, 20 AMP line fuse inside the microwave, mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. If the model number you listed this question under is correct, the line fuse is connected in line with the power cord inside the unit and is listed as part of item 4 in the parts listing (part number STD384200).
If the line fuse is blown, you can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended.
Feb 06, 2012 | Emerson MW8102SS 1100 Watts Microwave Oven
What is the wattage on the sharp microwave model r-2a48?
http://www.sharpusa.com doesn't have your manual. But you can find it yourself on the
back of the unit - the wattage should be listed.
If only the amperage is given (you know the voltage is 120 VAC RMS), so using Ohm's Law, you can calculate wattage:
Watts = 120 Volts X Amps
May 13, 2011 | Sharp R-2A48 Microwave Oven
I have a JVM1850 1100 watts. It's not heating. Shortly after we got it I think a fuse blew because we always had to turn the vent on and then the cooking time which worked. Now, it stopped heating all...
There is usually a 125V, 20 AMP line fuse inside the microwave, mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacturer and model. Parts are available at any of the following webistes: searspartsdirect.com pcappliancerepair.com appliancepartspros.com repairclinic.com The first three sites include illustrated parts listings that can help you locate and properly identify any parts you may need. If the model number you listed this question under is correct, the line fuse is connected in line with the power cord inside the unit and is listed as part of item 47 in the parts listing (part number WB27X10388). This microwave oven is also equipped with various thermostats that (if blown) can cause similar symptoms to that of a blown line fuse. So, if the line fuse is NOT blown, you may want to check all the thermostats to see if they are still good. You will need to remove each one and measure across the terminals with a multimeter. A good reading is 0 ohms. NOTE: The various thermostats are listed as items 27, 61, 74, and 77 in the parts illustration. The thermostats typically will trip if the oven cavity has been overheated. Cooking items that are high heat producers such as popcorn or baked potatoes in rapid succession can often cause this problem. Allowing the oven cavity to cool a few minutes with the door open between cooking can prevent this from occurring.
If you have any questions, or need additional assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit. These ovens can blow a fuse by simply sitting idle. This can occur from any power fluctuations, brown outs, voltage spikes, etc. Or, it could be the symptom of a component that may have failed. If you find the internal fuse blown and replace it, only to have it blow again, you have a more significant problem than a simple blown fuse.
Sep 08, 2010 | GE JVM1850 1000 Watts Microwave Oven
This model just stopped working while heating food up. Now cannot get even the power to register when you plug it in. Is this doen for?
Jul 22, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
No power to microwave
There is usually a 125V, 20 AMP line fuse inside the microwave. Its usually mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
http://pcappliancerepair.com/model-display.php
The line fuse is listed as item 28 in the drawing. Keep in mind, there are also a couple of thermostats listed that may also cause no power problems if blown.
One is listed as item 29 (part number 8183703) under the same drawing. The other is listed under the "Airflow" section as item 5 (part number 8183697). The humdity sensor can also be a source of problems when it becomes old. If you managed to overheat the oven any time recently, you may want to check these thermostats and sensors to see if they are still good. They should read 0 ohms when measured out of the circuit.
If the line fuse is blown, you can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended. If you wish to order on line, use the part numbers to search by comparison as the model number you listed this question under may not be available at all the websites I have provided. The parts, however, ARE listed.
May 22, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Need wattage of model #721.80602500 microwave
The microwave is rated at 1100 watts (cooking power) and is required to have a 120 VAC, 60HZ power source protected with either a 15 or 20 amp breaker. It is also recommended that the outlet servcing this appliance be a dedicated circuit (meaning the oven is the only appliance on the circuit). I hope this helps you.
Aug 25, 2009 | Microwave Ovens
Plug it in, does nothing. . .main fuse is fine
I had one that got zapped during a thunderstorm. Deep inside there was a ceramic fuse, looked like the old glass kind in cars except it was ceramic. Bought a replacement through Digi-key, it's worked fine ever since. Point is, there may be a separate 'main fuse' that you can't get to without opening it up.
Aug 03, 2009 | Panasonic NN-S634 1250 Watts Microwave...
My microwave panel key no work Shaph Model R-230EWA 120 VAC 60Hz
take it back apart and look for a ceramic fuse it may have gone bad
Apr 11, 2009 | LG LMV1630 Convection/Microwave Oven
Replacement part for microwave
That would have been # ANE06012L0APbut it is listed as no longer available from normal distributors.
It looks like you can still order it here.
Dec 04, 2008 | Microwave Ovens
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
