Question about Winter Sports
2009 skidoo gtx550 fan stalls after about 10 min riding starts again and stalls after a few feet
  • 682 Answers
Is it getting hot?
Posted on Jan 03, 2017
My lawn tractor craftsman 14.5hp IC OHV B&S stalls approx. 5 mins after starting so I restart and it can stall in another 10-15 min again and so on.
you may have some debris in your gas tank blocking the pickup tube. It will float away when the mower dies, then block the tube after it runs again.
Jan 03, 2017 | Craftsman Garden
Tractor runs fine stalls like its out of diesel, 10 min. starts again runs awile, does same thing
Sounds like you have a fuel restriction, change out the fuel filter
it probablly is plugged up.
May 31, 2014 | Peg Perego John Deere Turf Tractor
Rider...stalls after running a few min.. plug
maybe need to put a full kit through carb. and replace few worn parts ie. float needle and seat. throttle needle and seat etc
Sep 06, 2013 | Garden
I was driving then temp. gauge went hot and it stalled checked by coolant fine now it starts but when you put in gear it goes 10 feet then stalls and wont restart for about 20 min.
Check if the fan turns on a few minutes after a cold start. It may be a problem with the fuse or the relay. Check if you loose coolant, there may be a leak somewhere, the hose, bad fuel pump, radiator leaks or a bad radiator cap.
Apr 26, 2011 | 1994 Dodge Intrepid
Stalling after one hour run time
Sounds to me like you need to replace the ignition coil,they will go open when they get hot and when this happens the plugs will stop fireing.
Apr 22, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Car stalls out, after a few min. it starts back up, then stops running again after 10 min.
Sounds like it is heat soaking. I would check the coil for voltage. Possibly the ignition module or crank sensor.
Apr 08, 2010 | 1992 Mercury Topaz
Suburban stalls while driving after running for 15-30 minutes. After letting it sit for 5-10 min it runs fine for another 5-10 minutes, then starts doing it all over again.
a bad crank sensor can cause this. shuts off while going down road, and will start about 10 min, later with no problems runs fine until it quits again. hope this helps,
Oct 07, 2009 | Chevrolet Suburban 1500 Cars & Trucks
Winter Sports Logo
767 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
vtrktrmn
Are you a Winter Sport Expert? Answer questions, earn points and help others
