Question about Samsung Televison & Video
My Samsung plasma screen PN51430A3DXZA tv all functions work but have no sound.
I have tried changing the sound settings to internal and external speaker using a digital optical connection to a sound bar but still no sound.
  • Samsung Master
  • 6,694 Answers
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Dec 30, 2016
I have a LG TV 47LD650 that has picture but no sound out of tv speakers. If I connect an optical cable into the output and use a sound bar, will it still produce sound?
You have to go to setting and change the audio output to TV speakers for the TV speakers to work,, but, if you use a sound bar with optical have to set it also .. mine works the same way,,
Jun 19, 2017 | LG Televison & Video
No sound coming from internal speakers Toshiba Projection television Model 50h82.
Some TVs have a set up option to disconnect internal speakers when an external audio amplifier will be used.
Dec 29, 2016 | Samsung Audio Players & Recorders
I have a ZVOX 580 soundbar. Using the digital optic cable I have no sound. I have sound through RCA cables. Can you help?
They to check the menu of the TV is there is any option to activate the Digital out or is there is any setting which allow you make a selection between internal speaker or external speaker. if its there the make the setting as external speaker .
Jun 15, 2016 | ZVOX ZBase 580
HOW DO I SET UP panasonic th-l37310a to phillips htl2101a sound bar
The optical cable should work. It's possible your set requires you to select external speaker in menu for optical out to function. Hope this helps.
Feb 02, 2015 | Panasonic Televison & Video
I do not get sound coming from the sound bar when I connect to the tv
In the audio menu of your TV, you will find a menu item that says, external or internal speakers. Make sure it's set to external.
Jan 09, 2015 | iLive ITP280B 37" Sound Bar with Built-in...
I connect my I live soundbar to my Samsung plasma TV and I'm not getting no sound from the TV to soundbar please help
Check the TV's audio menu to make sure there will be signal available at the RCA outputs
Some sets won't allow both internal & external speakers/sound bar to both be on.
Jan 07, 2015 | Samsung Televison & Video
I have 50"plasma tv with picture but no sound. It shut itself off a number of times before this happened. I have the back of the tv off. the model number is PN50A400C2DXZA version SM12
Well, it could be something inside, but it could also be a setting.
In SETUP, there's the option of using the internal speakers or external speakers. If it's set on external speakers and you don't have any connected, then you get no sound.
Dec 01, 2014 | Samsung 50 in. Plasma TV
How do I get audio out of 32lc2d to go to the external surround sound system
Depends on your external sound system... If it supports HDMI, then just connect an HDMI lead between the TV and the external amp. If you don't have HDMI, look for two RCA/Phono connectors (small circular connectors) on the back of the TV (should be coloured red & white) and connect these to the external sound system. Finally, if you don't have either of these look for a 32 pin scart socket (rectangular with a bit sticking out) and get a scart to phone cable. Plug the scart plug into the TV and connect the Red & White output leads to your external system - hope that helps :-)
Aug 18, 2014 | LG 32LC2D Television
How do you turn off the sound that is on regular TV to watch a Netflix movie
In the user manual on page 66 there is a setting for internal/external speakers. Set the TV to external speakers which will turn off the TV audio.
Dec 07, 2013 | Samsung Pn64d8000 64-inch 1080p 600hz 3d...
Televison & Video Logo
27 people viewed this question
Jerry Greenberg
Jerry Greenberg
