Question about Refrigerators
The fridge or freezer arent on but lights are on
4 Suggested Answers
SOURCE: Whirlpool Gold Black on Black 21.9 cu
I had the same problem. The light would dimly flicker and make a sort of clicking noise. It was still under warranty and the repair man had to replace a circuit board in the back. Not sure of what the cost would be if not under warranty. Hope this helps.
Posted on Nov 01, 2008
SOURCE: fridge freezer isnt cold as normal
I have a Servis Fridge Freezer but the fridge is not as cold as it should be I think it just seems cool because the Freezer compartment is working
Posted on Jul 05, 2010
walterkunesk
  • 683 Answers
SOURCE: my fridge and freezer arent
When you refrigerator is making a clicking sound every few seconds this can be caused by a couple of reasons.
1. The pressures are not equilized enought to start the compressor. This can be caused by the head pressure getting to high and not coming down far enought in the off cycle so that the compressor can start.
(things that you can do at home is to make sure that the condensor coils are clean. the condensor is either located on the back or on the bottom of the refrigerator. Make sure that the fan on the bottom is clean and blade clean and that the fan is operating.) When you clean everything let the refrigerator stand for 1/2 hour unplugged before you plug it in this will allow the compressor to cool down and also allow the pressures to equilize. If after doing this it does the same thing and you dont know what else to do and are not mechanically inclined, call a service man.
2. This can be caused by weak or bad start componants. When and if you change any start parts it is good practice to change all start parts. (start capacitor, run capacitor, start relay, and overload. To many times one start part will go bad and the short cycling will take a toll on the other parts. If you know how to read a volt ohm meter I have phone support and can talk you thru it. If you do not, call a service man.
3. Other reasons are in the refrigeration system and this will require a service man.
I hope this was helpful to you. Have a great day and good luck.
If this tip helps you, please give me a rating. thanks.
Posted on Jul 05, 2011
I have a GE GSH25JFTA CC refrigerator and it is not cooling properly. What should I check or replace?
Depending how long the power was off you may have an ice blockage in the freezer. Normal cooling causes the freezer coils to build up frost and snow coating all over the coils. A normal defrost cycle melts that frost/snow off and keeps the coils clear so the fans can move air through the coils.During the power outage the frost may have started to melt wetting the snow. If the refrigerator then came on and re-froze the wet frost/snow into a solid block of ice, the normal defrost cycle would not be able to clear that solid ice out. So it may be blocking the air flow. Remove freezer back panel and see if there is ice back there. If yes--use something like a hair dryer to melt everything out until it is completely clear. Make sure the fans are running also.
Apr 14, 2015 | GE Refrigerators
Freezer and fridge arent cooling
Is the compressor running? Do the lights and the fan work inside the unit?
Dec 11, 2011 | Maytag MFX2571XEM
Fridge freezer isnt cold as normal
May 24, 2010 | Refrigerators
Fridge freezer not keeping temp
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 11, 2010 | AEG Santo 3888 KG8 Bottom Freezer...
The freezer part keeps popping open whenever you close the fridge part. How can I fix this?
The magnets in the freezer door arent making good contact, try adjusting the front legs up to make the fridge lean back slightly
Nov 25, 2009 | GE Profile Arctica Stainless Steel Top...
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
Whirlpool gold refridgerator light not working and is making funny noise
switch of your refrigerator then try replacing the light that doesn't work then try to switch it back on. the light might be the cause of the noise. it might be grounded. replacing the light might reduce the noise then observed the noise for a week then if it still making noise that's the time for you to get a technician that could fix your refrigerator.hope it helped... send us a message for more concerns thank you...
Jun 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Oct 23, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Red light on Hotpoint Iced Diamond freezer
got a hot point iced diamond fridge/freezer, just got back off hols and red light on, all food defrosted with water running out of bottom. whats wrong?
Aug 27, 2008 | Refrigerators
Refrigerators Logo
20 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
