Ihave a sonie 42in tv the green light come on then in about 5 sec it goes off
  • yadayada
    yadayada Dec 30, 2016
    Sonie?? do you mean a "SONY", if so what model and is it a LCD TV?
  • 43 Answers
SOURCE: Sony KDF-E55A20 55 in. LCD... Problem red light flashes 5 times
A 5 blink error indicates a bad lamp driver. However a lamp may possibly cause this too. I suggest putting a new lamp in if you have one just to verify the lamp is not the problem. If it still fails with a new lamp then the lamp driver is the problem. This part should be replaced by a Sony authorized servicer. The lamp can be replaced easily by you. The lamp replacement instructions are in the TV's owners manual. Good Luck
Posted on Jan 06, 2008
SOURCE: tv comes on and goes right back off
IT GAVE OUT A LOUD BANG AND NOW I HAVE NO PICTURE OR... Mosfet Transistor blow out.  Transistor K3316 or replace the Power unit supply. This problem was caused by a low power voltage. SONY SONY KE-42TS2U
Posted on May 29, 2009
  • 1884 Answers
SOURCE: sony kp-46tw520 standby light blinking
Most obvious Power Supply Unit problem. While it is working you have everything and then it heats up and you loose all. Needs a change.
Posted on Oct 23, 2009
SOURCE: sony kdfe50a10 blinking green light
did you find out the answer to this problem as we have the exact same issue? thanks
Posted on Oct 29, 2009
SD Tech
  • 14553 Answers
SOURCE: TV won't turn on.
Do the self check this set has:
when the power light goes off---on the front of the set press and hold both the MENU and INPUT (or Device) buttons for 5 seconds and then release both.
Power light will blink a two digit error code--most common is 2 blinks a pause and 2 blinks--it will repeat the code several times.
Let me know what the error code is and I will tell you what it means.
2,2 is most common and the most easy to fix.
If this information helped you rate this solution as I do this here for free.
Posted on Dec 28, 2009
Testimonial: "SD tech, I pushed the menu and device buttons and received the 2,2 code.....what's next?"
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
Sony lcd projection tv (kdf-60wf655) Tv lamp turns off after 30 secs then come back on over and over ,Green light is solid when lamp is on and blinks green when the lamp goes off. Only when I turn off the...
The board that call the Ballast board might dead,require replacing.This Ballast board only job are to ignite the tv projection lamp.The tv projection lamp been inside the tv like 1 1/2 or 2 years already?Yes.Tv used it everyday like 4 or 5 hrs daily?Yes,the tv should be replacing it projection lamp too.Tv projection lamp life are ending too.
Jun 10, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Every so often ithe screen just goes blank and you can't change channels or input devices when it does this. There are no blinking lights or no codes being shown, the green power indicator light stays...
It sounds lamp is reaching to end of its working life and causing that problem due to its weak result.
Replace lamp in tv to solve this issue. Lamp replacement procedure is easy and written in user manual of tv, please buy Sony original lamp for good picture in tv.
Feb 01, 2011 | Sony KDF-E502000 50" HDTV
Tonight my Sony Wega KDF-42WE655 screen went black and the audio stopped, the standby light (green) blinked on and off for about 30 sec. then the screen came back on and the green light blinked 5 sec or so...
Replace its lamp as existing lamp has been reached at end of its working hours life and need to replace to solve this issue. Please note lamp is not not broken or dead yet so you do not see lamp light on tv front.
Lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for god picture in tv.
Dec 31, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a sony wega kdf 60x5955 about 5 years old. while watching it the screen goes black and sound goes out the green light blinks once a sec. for about 30 sec. then the screen and sound comes back. dose...
There is about 2 or 3 things Lamp, Lamp Fan if Fan stops runinng then TV will shut off to protect Lamp and the Ballast Board is what turns Lamp on.Go to this website online Encompass Parts type in your Model number which is KDF60XS955 They list everything you need Service manual you can download for FREE These are the part number for (Lamp- A-1085-447-A) & (Ballast Board 1-468-875-11) Call them at 1-800-638-3328
Dec 08, 2009 | Televison & Video
I have 42in Kdf42e2000 and it keeps cycling on and off. it stays on for 45 sec and the shuts off power light blinks for 42 times then it goes back on and the cycle starts again. Does anyone know what could...
Its symptom of weak lamp in TV, please replace lamp.
Lamp replacement procedure is easy and mentioned in instruction manual, if you need copy of manual, click Sony Support.
Please buy Sony original lamp for TV safety and avoid aftermarket/ cheap lamp.
You can buy replacement lamp from Sony Accessories Store under following part number..
F93087500 Lamp Block Assy XL-2400
Jul 09, 2009 | Sony KDF42E2000 42" HDTV
Tv comes on and goes right back off
Apr 01, 2009 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Lcd projection tv 42in
Lamp is available HERE and cost approx 175
Jan 13, 2009 | Televison & Video
Sony 42in- No picture or sound
You need to replace the bulb...very easy. You can do it yourself.
Dec 23, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
