Question about Sonic Technology Sonic SuperEar TV SE1900 - Sonic SuperEar TV
My sonic tv will not turn on the green light come on for about 10 sec then goes off then you wate for a while it will do the same
The light come on for about 10 sec
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Toshiba 37RV635DB Regza 37-inch Widescreen...
TV won't stay on
One of two things can be the problem...one the bulb is bad...two the ballast is bad. If the bulb is not bad then the ballast is...it can usually be fixed by replacing a resistor on the board itself...it is labeled R3 and is a 1000 ohm resistor
Jul 25, 2010 | Toshiba TheaterWide 46HM84 46" Rear...
Have an old view sonic vx900 (~5yrs old). When you
Check the fuse on the inverter board and also verify it does have have 12vdc feeding the fuse. Worst case will be the lamps, power supply caps look OK?
Jan 18, 2010 | ViewSonic VX900 19" LCD Monitor
My green ligght comes on for about 10 sec then it
may the battery of your psp is damaged or its your psp that drain the electricity out your batttery
Jan 02, 2010 | Sony PlayStation Portable (PSP) Console
View Sonic VA720 monitor goes out after power goes
replace the logic board, not the power supply board. you can find logic board on ebay as low as $29...
Nov 15, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
37PF5320/10
Hello, I would advise as I do not know all the specifics to try to give the T.V. a signal from a cable box or dvd player. Then I would unplug the T.V. for about 5 minutes and then plug it back in and try to turn it on. Most newer televisions will have a One Year warranty included at the time of purchase so if all else fails, you maybe able to get a warranty replacement.
Jun 02, 2009 | Philips 32PF7320A 32 in. LCD Television
Panasonic TH42PZ70B
Flashing RED lights in Panasonic TVs means a fatal error code. Unplug the TV, wait 1 minute and replug. If the LED still flashes it needs professional service.
Sep 04, 2008 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Powering on
needs a new flyback
Jan 01, 2008 | RCA HD52W58 52" TV
PSP won't start
i think your PSP is bricked... try to have it unbricked...
Nov 25, 2007 | Sony PlayStation Portable (PSP) Console
Sonic Technology Sonic SuperEar TV SE1900 - Sonic SuperEar TV Logo
Top Sonic Technology Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Sonic Technology Health and Beauty Expert? Answer questions, earn points and help others
