Question about Sewing Machines
I want my embroidery to start at a certain point. How do I do that? Husqvarna Epic embroidery machine
dupina
  • 110 Answers
SOURCE: Will a Husqvarna #1 Plus embroidery unit work on a Husqvarna Rose machine?
I am sorry to inform you that Husqvarna # 1 embroidery unit does not fit onto the Rose machine. The terminals on the Rose is upright, while on the H # 1 it is flat. If you want to do embroidery on the Rose, you will have to purchase the embroidery unit.
Sad but true
Posted on Jan 22, 2008
pgmadhav
  • 145 Answers
SOURCE: Husqvarna 1 Embroidery software
Use program compatibility wizard and you'll be able to use the same program in Windows XP also.
  • To start the Program Compatibility Wizard, click Start, click Help and Support, click Find compatible hardware and software for Windows XP, and then, under See Also in the navigation pane, click Program Compatibility Wizard.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Posted on Dec 20, 2008
SOURCE: can't update my new husqvarna diamond embroidery machine
Thanks for the response. The problem turned out to be my fault. I had my Diamond connected to my computer when I tried to install the drivers. As soon as I disconnected it, the drivers all installed and everything is fine.
Posted on Feb 27, 2009
  • 201 Answers
SOURCE: Husqvarna Viking Designer I breaking needles
Dls8864's suggestion was a very good suggestion - make sure the metal stitch plate is pushed all the way to the back. Also make sure that the thread is feeding freely - if it is catching on something it can cause the needle to be pulled aside and make it break. Does the design fit properly inside the hoop you are using? If the foot and/or needle strike against the side of the hoop, that will cause a breakage. Is the bobbin thread okay - not making a bird's nest underneath?
Posted on Feb 01, 2010
  • 3 Answers
SOURCE: I need a copy of the Husqvarna Rose sewing
You can get a free copy here:
http://s2.vsmgroup.com/VSM/Husqvarna%20Viking/HVManual.nsf/1fd5659e6f37141041256697003e64c0/8569fb0aa78ab071852575ed00723d7a?OpenDocument
Posted on May 23, 2010
My sewing machine will not make decorative stitches?
Is it an embroidery only machine. Typically embroidery is done with the needle in a fixed position while the hoop is moved around.
Jan 05, 2017 | Husqvarna Sewing Machines
My Husqvarna Viking diamond series embroidery machine does not recognize a formatted disc
perhaps the machines company sells formatted ones . tho the brothers embroidery machine I have will only accept factory originals
Apr 08, 2015 | Husqvarna Sewing Machines
My Husqvarna designer SE embroidery unit keeps giving an error message "install hoop correctly". I've checked everything but can't get around the message. can anybody help ,?
You have probably got the machine set to use a different size hoop. Click on the hoop icon and change it to the size you are using. Hope this helps you.
Aug 04, 2013 | Husqvarna Sewing Machines
On the infodisplay, I have a blinking icon. I start to embroider and it stops blinking E with a loop around it. It is beside the pressure foot letter.
I think it indicates that the embroidery has reached as far as it can go within the hoop limits. If you have your user guide (I have a Scandinavia 400), in the embroidery section under the function buttons heading (mine has a worm embroidery on display), it talks about the "check size" button (a single button with arrows pointing to all four corners). The explanation is in there.
Feb 22, 2011 | Husqvarna Rose
Husqvarna Rose Embroidery Unit problem
Call Viking direct
440-808-6550
800-358-0001
Aug 20, 2009 | Husqvarna Rose
Fix button won't work in embroidery mode
Just to make sure you know what "Fix" does in Embroidery Mode - you press it before you start your embroidery then when you press Start, the machine will baste a square or rectangle the size of your embroidery before moving back to the centre ready to start the actual embroidery. It is not used to Fix stitches in embroidery mode (like it does in regular sewing mode) and it must be used before the embroidery is begun if you want the basting. Is this problem you have? It will not do the baste stitch?
Jul 11, 2009 | Husqvarna Designer I
My designer 1 keeps saying "No floppy Disk Inserted" and of course there is.
Do you have this problem with only one floppy, or have you tried several? Make sure the floppy is pressed into the slot fully. It should sort of "click" in.
Is the floppy properly formatted for the Designer1? You cannot just drop embroidery files onto it and put it in the machine - the designs need to be in .shv format and in a certain file hierarchy. Only genuine Husqvarna embroidery disks, or ones created in Husqvarna or Embird software can be used.
Of course it may be a sign that your Des1's floppy drive is not working, in which case you will have to take the machine in to be fixed.
Post more detail on your problem and I will try to offer more specific advice.
Pamsquilt
Oct 08, 2008 | Husqvarna Designer I
Misalignment when embroidering with husqvarna designer 1
Sorry that I did not see this sooner.
It sounds like you should have your embroidery unit serviced. Sometimes they will accumulate lint on the slide rods and it inhibits the movement of the mechanism as if you were to bump into it while it is trying to move.
Quite often, this will happen repeatedly in the same point in the design and make people think that there may be something wrong with the design. But, usually it is just that the embroidery unit can't move freely.
Aug 22, 2008 | Husqvarna Designer I
Sad but true
Jan 20, 2008 | Husqvarna Rose
Sewing Machines Logo
23 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
