Question about Home
Why does gas fire place fire goes out and comes back on after a few minutes ,until i turn it up higher.
  • 19,071 Answers
Your thermostat has gone and is not telling the unit to switch back on when the temperature drops below the threshold. You are doing the job manually.
Posted on Dec 30, 2016
My car stalls and will not start back up until after it sits for a few minutes?
Year make and model? it could be the fuel pump.. Could be other things also. How long does it run until it stalls? At what speeds? Does it act up at higher speeds?
Sep 15, 2016 | Cars & Trucks
Display says "CFH" but heatert wont fire up. Just makes a clicking sound
You don't have gas supplied to the heater. It sounds like you have a gas powered unit and the clicking you're hearing is the sparker sparking.
Jun 07, 2015 | Pool & Spa
My hayward swimpro abg100 powers on but nothing happens. I can hear a buzz coming from it but it does not ignite or anything. What can I do?
Warranty status? Probably gas control valve and its connections to the "buzz" ignitor system. Gas is not a DIY thing!
Jun 07, 2015 | Hayward Pool & Spa
Paragon symphony fire goes off after a while.
Have it serviced by a competent gas safe engineer for safety.
Nov 10, 2014 | Dryers
Cuts off shortly after turning it on
Sounds like you have a short some place, and it needs to be replaced.
Dec 25, 2012 | Hamilton Beach 33966 6-Quart Slow Cooker
The pilot light is out on my valor gas fire place. When I go to light it the flame comes on but if you let the button up to turn on the burners it goes out.
Keep the pilot gas control pressed down for 30 seconds to a minute after it lights to allow the thermopile in the pilot light to heat up. If you are already doing this the thermopile needs replacing
Dec 22, 2012 | Kitchen Ranges
Gas cooktop starter continues firing
Turn your gas valve on, but leave your unit unplugged for a few days. You can light your burners in the meantime with a lighter so you can cook. Usually this problem is caused by moisture getting into one of your ignitor switches which are under your burner knobs. Most of the time the switch dries out and you can plug your unit back in after a few days. If it still keeps firing then you will have to replace one or more of your ignitor switches. Usually a very difficult job as most gas cooktops are now sealed burner units which means the top of your cooktop is bolted down to the burners with several screws or nuts that heat up with usage and become almost impossible to remove, without having to drill out the screws, or chiseling off the nuts. Be careful of boilovers or cleaning around the knobs with too much water to prevent this from happening again. Also get a surge protector at least 2000 joules or higher to prevent damage to you spark module. Good Luck, Appliance Specialists
Dec 16, 2009 | GE 30 in. JGP336 Gas Cooktop
My york diamond 80 can be fired up, but it is shut off automaticaly after approx. 20sec. This can be repeated 3 times. I beleive the fun and borad panel are working fine.
The flame sensor might have dust build up on it. The flame sensor makes sure that the system has ignited before it starts the main blower. If it ignite and burns for 15-20 seconds then goes out that is most likely your problem. Identify a probe that is in the direct path of the flame(usually in the last burner tube from the gas source), it will have one wire coming off of it and usually has one screw holding it in place. As time goes by the sensor will get a build up on it and stop functioning. Turn the power to your furnace off, then remove the screw and then gently pull the flame sensor out. Using a MILD abrasive like panty hose of paper towel (DO NOT USE sand paper) clean the sensor and then put it back into place. Tighten the screw and then turn your furnace back on. That should fix your problem.
Oct 18, 2009 | York Furnace Draft Inducer Blower Fasco #...
AUTO warning light comes on - 2004 Renault Scenic Petrol Auto
Auto warning light comes on but goes off when car stopped and restarted. Temp also goes higher
Aug 17, 2009 | 2005 Renault R5
White smoke coming out of lawnmower my son was cleaning garage and thought he would save space so he tilted the lawnmower on its side my brother said that gas and oil may have mixed together and thats...
The oil is drained by removing the drain plug on the underside of the mower, where the blade is. The gas can be drained by removing the gas line from the carburetor and letting the gas drain into a container. Remove the spark plug wire from the spark plug before any work is done to the mower. But, really depending on just how long the mower was on its side, the mower should be OK after running for a few minutes. Have you let it run for several minutes? The oil in the combustion chamber should burn off. The one thing to check is the spark plug. It may have some carbon buildup on it from the oil. It can be cleaned with some spray carburetor cleaner, or you can just replace it for a few dollars.
Aug 12, 2009 | Garden
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
