Question about Keurig Coffee Makers & Espresso Machines
What's going on with this Keurig B200 - Keurig Coffee Makers & Espresso Machines
Is there a website where I can get component parts for my keurig without spending a fortune
No there is no economy site for spare parts . they are what they are . sadly like it or not
Feb 13, 2016 | Keurig B200 Brewing System
How do i disassemble
Power surges can damage the power supply portion of electric appliances, gadgets.
Follow the line cord and remove the screws to get into the innards of unit and check the components in the power supply. Look and smell for anything discolored, swollen. burnt.
Feb 12, 2016 | Keurig B200 Brewing System
Keurig B200...multiple issues
Too many problems with the B200 and they stopped selling it.
Jan 04, 2013 | Keurig Coffee Makers & Espresso Machines
Keurig b200 does not always fill cup
You need to "descale" the unit.
here is a link to a youtube video from keurig:
Oct 18, 2012 | Keurig B100 Coffee Maker
I have a direct water feed B200 Keurig. I have developed a problem with grounds being pushed up to the top of the K Kups. I have cleaned, air blown all orifices and needles but the problem persists
If that is happening then the water is going in, but is not getting out...
This would seem to be a problem with the bottom needle..
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
Jul 07, 2011 | Keurig B60 Coffee Maker
B200 stuck. says "brewing" but
Hi.You may try this steps.
took the reservoir off,
siphon water from a hose, blow it off
Maybe that is what has happened in
all of these instances
cup of coffee.Hope this helps.
Jun 21, 2011 | Keurig B60 Coffee Maker
The Keurig B200 primes several times a day and the process takes between 3 and 4 minutes to complete. Is this normal and if not, what do I do about it?
This absolutely not normal. Are you directly hooked up to the water? One possibility is if the machine is shut off when it is turned back on it asks if it has been emptied...if you answer yes by pressing the large cup then it will go through the priming process.
Oct 27, 2010 | Keurig B60 Coffee Maker
My keurig b200 is stuck in the mode saying that is "heating please wait" nothing seems to be happening i dont have the user maual. is there a way to reset the machine?
It is most likely the 12v air pump not working. It doesn't provide the air pressure to pump the water into the heating canister and, thus, the unit will try to heat the water indefinitely. See the following forum; it's about the B70 but much useful info, including sources for the air pump that you most likely need:
May 06, 2009 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
26 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
