How do I make an original dunes of war 2 cd set run on my computer I have tried every op system since win 98 but still get error message want help
  • Barrissimo Jan 10, 2017
    Hi Larry Houghton, I want to help you with your question, but I need more information from you. What's your current OS? What is the error message? Does the game start at all? Are you choosing different compatibility layers?
  • 883 Answers
SOURCE: Original setup was interrupted
press F8 key (just after BIOS screen) at the next cold reboot and you will see a DOS screen with 3 or more options. Read each of them and I think you will see one option is to resume setup. This option places the system at a safe entry point to continue the setup. Another option may read "cancel setup and restore previous system"...this one may be used if you cannot get the "resume setup" option after repeated tries.
Posted on Aug 03, 2007
sandrew
  • 2961 Answers
SOURCE: Crashed Widows XP on my sahara laptop
it sounds as if you the system as you say has failed, you can use a friends copy of XP but use your product key number on the underside of your laptop. Secondly, the vista CD may be an upgrade cd but you will probably find that it will do a complete install as they are normally the same cd, just set your cd drive as first boot device and then run the cd,select new installation and not upgrade; i have an upgrade Vista cd but installed a full operating system on another partition, therefore it wasnt an upgrade but it still worked.
Posted on Sep 25, 2007
iqbal_del
  • 655 Answers
SOURCE: Installed Fontographer 4.1.5 WIN from
shalomodoo,
This product is designed to run on the following operating systems:
  • Windows NT 4
  • Windows 98
  • Windows 95
If you are using other than these OS it might cause problem.
  1. Try to uninstall then re-boot
  2. Make re-install.
  3. if the above steps does not fix problem, then call the vender for your OS support.
Thanks
Iqbal
Posted on Apr 16, 2008
maxicube
  • 51 Answers
SOURCE: Hi, I received an error
REINSTALL WINDOWS AGAIN! i know... its like annoying.
Posted on Dec 22, 2008
early1234
  • 871 Answers
SOURCE: Windows XP Home Edition Crashed After Loading Service Pack 2
hey coco
nothing happens when you try to use the recovery console right by pressing "r".
try this again and again , sometimes it idles but its still running, if the error appears, restat again.
some corruptions maybe beyond our control and sometimes the only solution for this is to recover the inportant files you have on that HD and do a reformat...
Posted on Jan 24, 2009
Install windows 98se
SE should boot on it's own without the use of the floppies. Try it by changing the boot sequence.
You may want to run chkdsk on the hard drive to fix any errors. Use the fix switch on syntax.
Nov 27, 2012 | Microsoft Windows 98 for PC
HAVE A CD WINDOWS 95, 98, 2000, NT 32bit application trying to install but I get a error message - component CSTEXT32.OCX or one of it's dependencies not correctly registered - a file is missing or invalid
The only time I usually see this is on copied CD's. Windows sets those in a special place that most copy software doesn't look as a protection against piracy. I am not saying you have bootleg disk but that is the only time I have seen that. If those are original CD/DVD's and you don't need the information on the HD saved, Try partitioning and them formatting the HD again then try an install. For Win 95 and 98 format to Dos, for 2000 and NT you can format to the more efficient and better NTSF format.
Oct 29, 2010 | Computers & Internet
War Front Turning Point in Windows 7 cannot find the original cd
download War Front Turning Point patch .this patch can running on any system include win7.This patch did not need original CD just Copy over the cracked executable located in the Crack dir on the DVD to
the \Run dir of your installation directory.
You can download from patch.ali213.net/showpatch/5004.html
This is chinese web site
Patch is 10.8MB. I'm not sure can mail if somebody need it.
Apr 05, 2010 | CDV Software War Front: Turning Point for...
Computer boots up then shows windows 98 scrren
you may face either harddisk failure, a driver problem or virus infection:
tools: original win98-cd (or a bootable image
version of it), antivir-software on cd!
- please check whether it is possible to boot from win98-cd, with cd-rom support, not from harddisk.
(such option should be availabe after bios-load is over)
if not:
leave the setup process without fully installing
(press F3 button when asked for repair or install option)
in both cases :
type at the dos-prompt:
c:\win98/win
(command for changing to harddisk, windows-folder, booting windows from harddisk, but without loading all the drivers as usually)
win98 should come up in protected mode or give error messages.
- access cd-drive and execute vir-scan.
- delete and/or repair infected files
- turn down, attempt to reboot from hd
- if still impossible reboot from win98-cd,
run repair of installation and try once again
standard boot
problem solved? if not, take down error messages consult fixya again!
Jun 13, 2009 | Dell XPS M140 Notebook
I can use the recovery cd
Hello
First you need to make the computer to boot from the CD ,when the computer starts first time look for something that says to change boot order press F8 or similar.
If it's not there then look for another message that says to enter Setup press Del (or F2 etc) ,then scroll to Boot sequence or settings and change CD drive to first device then save settings and exit.
May 07, 2009 | Computers & Internet
I have a compaq evo n600c laptop which just crashed running windows 98se and now i get error message 1782 disk controller failure followed by non system disk error.I do not have the op disk so i tried to...
Sure, no problem, http://download.cnet.com/Microsoft-Windows-98-SE/3000-18513_4-12296.html - 64k try this site and other related in order to create a system disk and reboot your system. Good Luck
Fehdi
Apr 12, 2009 | Computers & Internet
Error installing windows xp
hi! there,set up exe. that was when your setting up win 98 you have to install that came from floppy disk before you can install win 98.there is an os win 98 in your system you have to delete that previous os before installing another win xp.restart ur computer. press F2 to open your bios set-up . then select bios set-up priority your cd-room drive second,your hard drive. last, quit and save set-up. and then your computer will restart. insert your cd windows xp then reinstall your window xp. delete the previous os then follow the set up on your window xp until you install your new window xp.
Apr 01, 2009 | Compaq Presario S4020WM PC Desktop
Installed Fontographer 4.1.5 WIN from original CD. Tried to open programme. Error message appears: "Could not initialize the program, because there is not enough memory available to run. Code =...
shalomodoo,
  • Windows NT 4
  • Windows 98
  • Windows 95
  2. Make re-install.
Thanks
Iqbal
Apr 16, 2008 | Computers & Internet
Microsoft Windows 98 for PC Problem is there any software driver for pen drive so that my win98 o.s. computer can detect any type or companies pen drive plz tell me
wow, the 90's are a calling... sure their is a roumor of a usb pen driver for win 98' ....
Windows 98, especially in it's second edition (also known as Windows 98SE), handles USB fairly well, however there are no generic/universal mass storage device drivers preinstalled in the operating system, so you will need to install some additional drivers for it. Some manufacturers do however, provide the Windows 98 drivers on CD, others have them available to download, and others simply do not have them available at all!!!!!!!
generic Windows 98SE USB mass storage device drivers:
http://www.technical-assistance.co.uk/drivers/nusb31e.exe
instructions?? :
  1. Download the exe file to the desktop
  2. Remove ALL drivers for USB flash drives in Device Manager
  3. Remove ALL drivers for any USB 2.0 controllers (many have an uninstall option)
  4. Remove ALL unknown devices from Device Manager (*carefull)
  5. Run the exe file you downloaded, and follow the instructions, rebooting after installation
  6. When the computer boots up again, it may detect new USB 2.0 controllers, in which case you may need to reboot again
as always good luck! now im going to go back to my windows 95 and play Bioshock on full graphics!! excuse me = )
Oct 13, 2007 | Microsoft Windows 98 for PC
How to install os
This is a little difficult but it can B done :) Firstly I dunno if ya need to re-format ya drive? perhaps first ya could try to "Repair" of Win98? If that doesn't work,then, perhaps ya may have to re-format. If the Win98 is on a SEPARATE drive or Partition this also makes a difference.... Basically ... repair/re-install win98, then do a repair of ya Boot menu for XP, as Win98 sets up an incorrect Boot up for XP, and thus must be "Fixed" so XP will boot & show a Dual boot menu.. here are some links to help you step by step... http://pcworld.about.com/magazine/2109p156id111652.htm http://www.thehindubusinessline.com/ew/2004/08/30/stories/2004083000250400.htm
Aug 21, 2007 | Microsoft Windows 98 for PC
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
