Question about Onkyo Audio Players & Recorders
The volume control only goes up to +18 on my onkyo t sv919thx. can't hear it
  • Travis Lunz
    Travis Lunz Dec 30, 2016
    Can someone please help?
  • Official Brand Answer
  • 333 Answers
Hi Travis, please make sure that in programming volume limits are not turned on. Thank you Onkyo USA
Posted on Jan 05, 2017
  • Onkyo Master
  • 19,693 Answers
Sounds like the volume controller is faulty. Did you use the master volume knob on the front to increase the power rather than the remote?
Here is your manual. It sure is a complicated piece of kit. They have three service centres on the last page.
https://www.de.onkyo.com/downloads/2/6/5/5/3/Manual_TX-SV919THX_En.pdf
Posted on Dec 30, 2016
Onkyo Amplifiers & Preamps
Hi ,try cleaning your volume control ,here is a video so you can DIY or contact your local service. :)
Dec 17, 2013 | Onkyo Audio Players & Recorders
Connect Sharp LCD tv to Onkyo TX8011 Receiver
The Onkyo TX8011 is a Stereo Receiver. Two ways to connect:
1) The HD Cable box should have an audio out (typically red and white). Connect this to the Obnkyo CD input (red and white). The volume may be controlled with the Cable box remote or Onkyo remote. The TV volume may be muted or ON.
2) Connect LCD TV's audio out to Onkyo TX8011's CD input.
This is not a great way to set up, as the TV volume, when moved high, will attenuate (over load) the amplifier, leading to a jarring sound on the speakers. To avoid this, the TV volume should be ALWAYS FIXED low.. say about 30%. Only the Onkyo's volume should be adjusted while watching.
Hope this helps.
Nov 20, 2013 | Onkyo Audio Players & Recorders
Hi there, I have been experiencing problems with my Onkyo TX-SR 703e receiver. Lately, the volume from my right font speaker appears to be lower than usual. i.e. as if there is something blocking the...
Manual is here
http://www.intl.onkyo.com/downloads/manuals/pdf/tx-sr803_703_manual_e.pdf
Assuming you are in the USA
ONKYO U.S.A. CORPORATION 18 Park Way, Upper Saddle River, N.J. 07458, U.S.A. Tel: 201-785-2600 Fax: 201-785-2650 http://www.us.onkyo.com/
probably a bad capacitor
Look here
https://www.badcaps.net/index.php
Nov 07, 2017 | Onkyo TX-SR703 Receiver
My onkyo tx-8222 suddenly stopped amplifying on both speakers and headphones. I can hear music faintly with the volume at max (just the pre-amp?). Time for a new amp?
Never use maximum volume for troubleshooting. The errant switch or control that you eventually find and flip will suddenly release the amp's full power and you'll destroy your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Look for a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Feb 21, 2011 | Onkyo TX-8222 Receiver
My onkyo tx-ds838 motor fan do not move
The fan in those Audio System only turns at about 1/4 to 1/3 of the ride of your volume control.
It had been intentionnaly designed like that, to achive a quiet operation at low hearing volume.
But if the fan don't move by cranking up the volume at 1/2 to 5/8 of the volume control (with speakers on). You need to have the fan or the fan power circuit checked by technician.
Spider Guy
Mar 15, 2010 | Onkyo TX-DS838 Receiver
"protect" display when volume is high and volume cuts in and out.
you should have it repaired.the audio circuit is malfunctioning because of the sudden burst/surge of current.
May 15, 2009 | Onkyo TX-SR502 Receiver
Onkyo av amp goes to protect mode
There's a fre service manual here, you need to join tte site (free)
Onkyo TX SV727 Manual AV Control Receiver HiFi Engine
Sep 06, 2017 | Onkyo TX-SV727 Receiver
Onkyo TX-DS777 goes straight to protection mode
Hello.You have shorted audio outputs. One of your channels has shorted output transistors. If your unit uses output ICs then one of them is shorted. Both types ( individual transistors or ICs ) are located on the large finned heat sink. The parts are available from http:\\www.tritronicsinc.com. good luck
barneyluc
Oct 19, 2008 | Onkyo TX-DS777
Volume Control
How do you have it hooked up to speakers (are you using a center channel)? What listening mode are you in (dolby digital, stereo, pro-logic...)? It sounds as though you're not getting center channel info....
Jan 09, 2008 | Onkyo TX-SR605 Receiver
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
