I have an Asko W655I front loader and need to clean the filter but it won't pull out. How do I take the cover off to access the filter inside.
SOURCE: cleaning the filter
Yes to get the clean filter light to go off, you have to clean filter, put back in the machine, and hold down the power button for 3 secs to reset it. the clean filter light will go off!
Posted on Sep 17, 2008
  • 949 Answers
SOURCE: Where is the pump/filter located on my Kenmore Front Loader Washe
It is just behind the lower panel. Remove the 3 screws from the lower panel (the panel just below the door), the screws are on the lip on the bottom of the panel facing the front of the machine. Pull down and toward you to get the panel off. The filter and clean out are in the center. Unscrew the cap to remove and clean out, but have lots of towels ready, there will be water coming out.
Posted on Apr 21, 2010
  • 119 Answers
SOURCE: How do i clean a filter of a whirlpool awm 5080 front loader
If you are talking about the drain pump strainer, you need to remove the lower front panel. should be 3 screws on the bottom facing forward. Once you have that off, the pump strainer is almost in the center, facing you. unscrew it counterclockwise to remove.
Posted on Apr 26, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Front loader washing machine stinks really bad
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
FitzOriginal
  • 842 Answers
SOURCE: GE front loading washing machine
The filter is hidden below the lower front panel (3 screws hold this in place) Turn the pump cleanout knob counterclockwise about 2 turns and be ready to mop up any water that leaks out as you remove it. To avoid spillage, you can pull the machine out and tip it backwards 45 degrees.
Posted on Jul 12, 2011
Testimonial: "Thank you so much! This washer has not been used because of not draining for over 6 months. Your advice solved the problem perfectly. THANKS SO MUCH!"
How do you replace the pump cover with attached needle trap? On ASKO front loader washing machine W6231?
it usually unscrews anticlockwise, but check to make sure there isnt a retaining screw that needs removing first. they can be a bit on the tight side
May 02, 2014 | Asko W6021 Front Load Washer
The detergent draw won't pull in and out easy. You've really got to 'pull' to get it open and 'push' really hard to make it close.
theres is probably soap inside the track where the drawer slides, just clean it out and you should be fine.
Jul 09, 2011 | Asko W6761 Front Load Washer
I have a Whirlpool 9500TC Front Loader Washer. Can't wash garments due SUDS Display. Can't use any washer functions due to SUDS display.
Run a cycle with white vinegar this will clear the suds. Make sure you are using HE soap if not the unit will over suds.
Another common issue is the drain pump filter. If it gets clogged the sud error will come up as well. If you have water inside the pump may need to be cleaned. Simply remove the three screws ont he bottom of the lower access panel and then twist the handle on the filter. If water is inside the washer, it will come out when the filter is pulled out.
Good luck with your washer repair friend.
May 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have an asko quattro front loader washing machine it wont spin out properly leaving my clothes wringing wet can you help?
Hi, Welcome to FixYa. Have you checked the pump to insure the filter isn't clogged, or do you know where it is and how to check it ? If its clogged it won't allow the clothes to spin out enough due to water extraction being prevented. The insert/filter is located on most Asko washer below the main basket door behind a toe panel or square access door. Once found, turn it counter-clockwise to remove it and clean inside thoroughly. Let me know how you do or if you don't understand or even needing more assistance. Thanks for choosing Fixya and good luck. Regards, Macmarkus :)
Nov 01, 2010 | Asko Washing Machines
Our front end loader stinks and we have to leave the door open. We have the exact same problem where I work. How do you get the smell out?
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 21, 2010 | Kenmore 44042 Front Load Washer
I was given a kenmore quei pack 2 washing machine.
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
Where?s the filter on my GE WSXH208A Front Loader? Thank you beltronic205 (GE WSXH208A Front Loader won?t drain). I drained the tub by lowering the drain hose as suggested. But where is the filter, what...
There is no acutal filter on this unit...You cab remove the back panel to access the drain pump ...Or tilt the washer back and access it from the bottom...Remove the drain hose from tub to drain pump...(careful of flow of water from tub)...Check the hose for any blockage...If no blockage then your pump is bad..
Apr 20, 2010 | GE WSXH208A Front Load Washer
My clothes smell musty after they have been washed. I was told to replace the rubber gasket in our Kenmore front loader he4T by the sears repairman for quite an expense. How can I replace this gasket...
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use quite hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Dec 30, 2009 | Kenmore Elite 45986 Front Load Washer
Moldy smell from front-loader Asko washer.
Hi
First check to make sure that the machine is draining properly and that the pump filter is clear of any debris.
On a frontloader a common place for mold to build up is the rubber seal around the door. Clean this out as well as you can with ordinary kitchen cleaner then place a heaped cup of baking soda directly into the drum and run an empty hot/boil wash on a full cycle.
Baking soda has a cleaning and neutralising effect and will help remove any build up of mold or gunge within the machine. You may need to run two of these washes before you see a solid result.
Thereafter I recommend you run a monthly 'maintenance wash' with the baking soda to prevent the problem arising again.
Hope this helps. Thanks for using FixYa
Nov 15, 2009 | Asko W6461 Front Load Washer
Asko w6761 front loader
you can remove the grey drum paddle to get access to the inner drum stick a small screwdriver in the middle hole of the paddle and pull towards you other wise you would be better getting an ako tech to do it because ther are three panels to remove plus a clamp band.if you havent done one before it can be difficult,also check the pin trap it may have gone in ther(filter bottom left corner)
Oct 10, 2007 | Asko W6761 Front Load Washer
Open Questions:
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
