Re OTT android tv box - menu comes on then goes off but comes back on to the same spot - I try selecting and it goes a little further then the screen goes black again
    Top Expert:
  • Televison & ... Master
  • 74,459 Answers
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Posted on Dec 30, 2016
I have a TH-50PY700H TV linked to an M8S KitKat 4.4.2 Kodi TV Box but the top & bottom of the display is cut off. Can anyone help pls.
If the signal is a product of the ott box than go to settings and find display. It will tell you how to make screen size to fit your screen.
Aug 19, 2017 | TV Box Televison & Video
My 4K kodi ott android tv box keeps kicking out of wifi
I had a similar problem with a roku box so I went to wired connection and solved the problem
Mar 18, 2017 | TV Box Televison & Video
I having a problem with my ott tv box and l'm not sure how to fix it
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jul 09, 2016 | Televison & Video
Ms8 ott box by kodi video stops goes to home page almost like screen saver but setting for screen saver is never
check the kodi settings. Kodi is just an app that runs on your android TV box so youll be dealing with 2 types of settings....setting within the box and the settings within kodi. I am thinking one of those sets of settings has the screensaver checked on
Apr 23, 2016 | Computers & Internet
Coby 8127 forgot pattern pass code S/N 043130000741
1. With the pad OFF depress the "-" key on the volume control and the power button at the same time and HOLD them down until the "Coby" splash screen comes up. 2. KEEP HOLDING THE "-" key down and RELEASE the power button until an android is displayed lying on its back. 3. RELEASE the "-" key and press the " " key on the volume control You should see the Android system recovery options on the screen. 4. After the menu appears, select the "wipe data/factory reset > Yes " menu item by pressing the "-" key until the cursor is on the line 5. Press power button to select 6. After it goes through resetting, using the volume key to navigate to the "reboot system now" menu item 7. Select the menu item by pressing the power button to select 8. Your mid9042 will now boot to an unprotected screen, BUT you will have lost any applications you downloaded. You will, however, save all pictures, etc. you have loaded. .
Mar 09, 2015 | Coby MID7036-4 - Kyros MID7036-4 7 4 GB...
I have a Sharp Aquos LCD TV Model LC-32BX6M , when I try to connect a new generation Android TV Box HDMI Out to TV's HDMI input the Android Logo appears and after sometime the screen goes blank t
im not sure but could it be a comparability issue with the device and the wake up signal from the device to the tv? android systems use a Linux based file system, so the problem may be in the tv's input settings. hdmi input from the device to the tv. and then go to tv input mode and see if putting the device in another hdmi port doesn't work.
Oct 15, 2012 | Sharp Aquos Televison & Video
Can't get rid of black box
You have your TV in the "Teletext" mode. Go into the TV menu and select the closed-captioning menu and turn off the text function. What you are seeing is the result of the TV's captioning circuit latching onto a false text pilot signal and then throwing up the black box on the screen.
michtech
Feb 17, 2009 | Hitachi 50UX57B 50" Rear Projection...
No TV "Select Source" Menu Option
Had the same problem and found on the back of the tv on the black box that the cable hooks to there is a plug at the top of that box on the left side came loose. If you slide that box to the right you can completely remove it from the tv. Reinstall it and make sure it's plugged in tight your tv setting should come back.
Nov 08, 2008 | Philips 17MD255V Combo
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
