Question about Mattel Matchbox Stinky The Garbage Truck
Why will stinky the garbage truck not raise up.
What causes the rpm in a 2000 pontiac bonneville to raise up to 4 rpm before the car shifts gears?
check fluid level in tranny sounds like its starting to slip dont leve it to long or you will burn the clutch pack inside n your tranny will be junk. it may already be to late smell the fluid if its dark n stinky its burnt
Sep 08, 2014 | 2000 Pontiac Bonneville
Odor in garbage disposal-- in hose?
follow the hose coming from the dish washer and make sure there is a raised section of hoes higher than the drain pipe
Jun 11, 2012 | Whirlpool Dishwashers
Please can I download the instruction manual?
Hi there!
Yes you can download instructional manual online. Try searching for the information that can be found in the product's label if there is. Or you can views videos on how to fixed things online.
Apr 08, 2012 | Mattel Matchbox Stinky The Garbage Truck
STINKY, STINKY, STINKY It smells bad
check base for proper seal ie:wax ring and or caulk at base of bowl
Nov 01, 2010 | Saniflo 013/003/005 Sanibest Toilet with...
Stinky water sitting in bottom of dishwasher
it's stale water growing bacteria, you can get a dishwasher cleaner at grocer that you dump in and run a cycle without dishes in there,....cleans and disinfects it,.....as always, read instructions, ask an employee at the store about it,....good luck, cracklin joe
Jan 07, 2010 | Dishwashers
Duet washer is stinky.I leave the tub door and the soap dispenser door open when not in use. Even so, epecially after doing several loads in a row I have a very stinky machine There is mold growing on the...
are you on a well??
do you use bleach in with your whites??
some well water untreated can cause exceptionally stinky machines, especially if no or very little bleach is used during white washing..
usually if you use bleach in with your whites in normal amounts and leave the door open in between uses there should be very little stinky odor or mold growth.
the mold growing on the gasket is a sign of to little bleach or none being used, and/or a really damp environment for the unit to reside in.
they do make several cleaners designed just for stinky front loader washers..
they might help..
i've been using a front loader for 13 years, leave the door ajar between uses, and use bleach in every white load and have had no issues with stinky unless i or someone else doing wash forget and close the door for a couple days, then it gets stinky but goes away after white load with bleach and hot water..
hope this helps,
best of luck,
ttfn
Oct 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stinky water from frigidaire side by side.
Check your outlet line, probably it is jammed. Thanks
Oct 04, 2009 | KitchenAid Superba KSRS27CN Side by Side...
How to remove filter on beam model 2775
Remove the bucket and look up inside the tank. There will be a finger loop to help pull the filter from it's track. You can shake it clean by wrapping a garbage bag around the tank, squeezing the air from the bag ( so it doesn't puff dust back at you)and then wrapping the bag over your hand and reaching up towards the filter.
This filter has a flat metal spring in it and will snap back into place. It is not normally removed unless it has gotten damp or stinky from pet odour. It is weighted in the middle with heavy beads in a sewn pouch.
Aug 16, 2009 | Beam Industries 2775 Serenity Plus Central...
Drain won't work?
sometimes this happens to me when the garbage disposal has not been run for a while
Feb 08, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Mattel Matchbox Stinky The Garbage Truck Logo
73 people viewed this question
Top Mattel Toys Experts
thegtw
Nikki  Mclean
Nikki Mclean
ray gallant
Are you a Mattel Toy Expert? Answer questions, earn points and help others
