Question about Mattel Matchbox Stinky The Garbage Truck
Stinky will not raise up at all - Mattel Matchbox Stinky The Garbage Truck
Is there something to clean out for waste? Dishwasher is stinky
Method 2 Removing Smell with Vinegar and Baking Soda
  • Place one cup (8 oz) of distilled white vinegar in the top rack of the dishwasher. ...
  • Run the dishwasher for a full cycle. ...
  • Sprinkle a cup of baking soda over the bottom of the dishwasher. ...
  • Run an additional cycle.
3 Ways to Clean a Smelly Dishwasher - wikiHow
www.wikihow.com/Clean-a-Smelly-Dishwasher https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=Dishwasher+is+stinky
Dec 02, 2016 | Dishwashers
What causes the rpm in a 2000 pontiac bonneville to raise up to 4 rpm before the car shifts gears?
check fluid level in tranny sounds like its starting to slip dont leve it to long or you will burn the clutch pack inside n your tranny will be junk. it may already be to late smell the fluid if its dark n stinky its burnt
Sep 08, 2014 | 2000 Pontiac Bonneville
Elextrolux smell stinky
Good Afternoon Anonymous, thank you for your inquiry!
I see that your Electrolux appliance has a stinky odor. Please help me understand if you are speaking about an Electrolux refrigerator? If so, where is the smell coming from? Is it located in the crisper drawers? Also, may I please have your model number? You can typically locate the serial tag (which provides your model number) inside the cabinet, on the left or right side wall. With this information I can assist you better in pinpointing the problem. Thank you! - Z
May 24, 2014 | Electrolux Refrigerators
STINKY, STINKY, STINKY It smells bad
check base for proper seal ie:wax ring and or caulk at base of bowl
Nov 01, 2010 | Saniflo 013/003/005 Sanibest Toilet with...
Stinky water sitting in bottom of dishwasher
it's stale water growing bacteria, you can get a dishwasher cleaner at grocer that you dump in and run a cycle without dishes in there,....cleans and disinfects it,.....as always, read instructions, ask an employee at the store about it,....good luck, cracklin joe
Jan 07, 2010 | Dishwashers
Is there a filter on the model KSBS20QEBL0? The ice has a terrible smell - have cleaned with baking soda, with no results.
i stinky piece of fish or any thing stinky in the frig side will smell up the Ice. Dump all ice wash out the bin with bleach and water.
Some frig's have a filter , some do not.
Nov 21, 2009 | Ovens
Same problem. Stinky, moldy, gunky. Clothes won't clean.
First take a gallon o bleach pour it in on hot and run,then from know on after washing leave the door open so it can dry out and not mold between loads.
Nov 15, 2009 | Frigidaire GLTF2940ES Front Load Washer
Duet washer is stinky.I leave the tub door and the soap dispenser door open when not in use. Even so, epecially after doing several loads in a row I have a very stinky machine There is mold growing on the...
are you on a well??
do you use bleach in with your whites??
some well water untreated can cause exceptionally stinky machines, especially if no or very little bleach is used during white washing..
usually if you use bleach in with your whites in normal amounts and leave the door open in between uses there should be very little stinky odor or mold growth.
the mold growing on the gasket is a sign of to little bleach or none being used, and/or a really damp environment for the unit to reside in.
they do make several cleaners designed just for stinky front loader washers..
they might help..
i've been using a front loader for 13 years, leave the door ajar between uses, and use bleach in every white load and have had no issues with stinky unless i or someone else doing wash forget and close the door for a couple days, then it gets stinky but goes away after white load with bleach and hot water..
hope this helps,
best of luck,
ttfn
Oct 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stinky water from frigidaire side by side.
Check your outlet line, probably it is jammed. Thanks
Oct 04, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Stinky Ice
You could try using ice aid, http://www.partadvantage.com/store/showpart/10127281. However there is nothing on a fridge that causes an odor only things that are put into the fridge i.e. food, water quality.
Nov 07, 2007 | Refrigerators
Mattel Matchbox Stinky The Garbage Truck Logo
Top Mattel Toys Experts
Nikki  Mclean
Nikki Mclean
ray gallant
Are you a Mattel Toy Expert? Answer questions, earn points and help others
