Question about Tanita Health & Beauty
How do I program my Tanita 2202 UM BATHROOM SCALE TO READ POUNDS
SOURCE: I have a tanita tbf-612
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Posted on Mar 14, 2009
fitnessbalan
  • 59 Answers
SOURCE: somehow my tanita ultimate scale has been switched
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Posted on Mar 16, 2009
SOURCE: Tanita Ultimate Scale 2001 - no user manual -how to set it?
does your scale have an orange SET button and a button with a triangle (or arrow) below the display?
Try this... make sure the scale is turned off. (and you are not standing on it)
Now press the SET button.
2 arrows should appear on the display. use the arrow/triangle key below the display to make changes and the SET key to choose.
If you have the same scale as me, you are prompted to chose Adult/Child followed by Male/Female, and finally input your height in feet/inches by pushing the arrow/triangle key until the display shows the desired height.
Press SET to finish and step on the scale like you usually do. It will now show your weight followed by your body fat %.
Hope this helps you!
Jacob
Posted on Jul 14, 2009
SOURCE: need to reset scale bf-681 tanita scale
I have a tanita body composition scale BC-534. It suddenly stopped working. I have new batteries. Is there a way to reset the digital disolay?
Posted on Jan 20, 2010
  • 5 Answers
SOURCE: Weight Watchers bathroom scale, Model WW60X
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
Posted on Mar 26, 2010
Our tanita HD351 scale not working
It is possible the replacement batteries are defective, the wrong type, or not installed correctly.
Jul 14, 2016 | Tanita HD 351 High Capacity Bathroom Scale
I have a Tanita Digital Scale with no user manual. Is there a web site where I can download the user manual?
Hi yokoone...
You did not say which model Tanita scale you have, so I will send you to the following webpage and you can download a free user manual for your scale.
Please take time to rate me
http://www.tanita.com/en/digital-scales/
Aug 18, 2011 | Home
Change settings. model #2202/UM-016 I have lost the directions and can't figure out how to change my persona settings. In an attempt to change my age I changed my *** and can't change it back.
I searched into this site with the same problem, how to update/reprogram the UM 016.
I figured out how to do it, shame there\'s no mention of updating memory data in the Tanita literature.
Assuming scale has batteries and old settings.
Press \'set\' button instead of memory or guest. The \'1\' memory should appear and blink. If you want to reset the \'2\' memory, press up key until the \'2\' appears and blinks, then press \'set\' again.\'
When you press \'set\' while the memory location is blinking, you should be able to page through and change the age/height/sex settings for the scale memories. When you are done, the scale will eventually shut down, saving your new settings, which you access with the \'up\' button when you want to use the scale.
Oct 19, 2010 | Tanita Digital Body Fat Scale with 2...
TANITA UM-016 BODY SCALES
Try downloading the um-80 manual. It's equivalent.
Apr 08, 2009 | Tanita 2204 Body Fat Scale
Scales show weight in kg. How to get them to show lbs.
Mar 13, 2009 | Tanita 2204 Body Fat Scale
I have a tanita tbf-612 scale and the measurement changed to metric instead of pounds when the batteries died. How can I change it back as I don't see anything on the back to re-set the scale.
Jan 01, 2009 | Health & Beauty
Setting is in metric instead of pounds
On my model, there is a button on the bottom that slides back and forth to choose the wanted setting. My scale is about 5 years old.
Nov 10, 2008 | Tanita Digital Body Fat Scale with 2...
Conair WW36GD bathroom Scale
This link allows you to ask questions and request a users manual....I hope this helps. http://www.conair-store.com/cc_contactus.asp
Sep 22, 2008 | Health & Beauty
Health & Beauty Logo
74 people viewed this question
Top Tanita Health & Beauty Experts
Tre Elkins
Ankit Chandel
Ankit Chandel
Tom Chichester
Are you a Tanita Health and Beauty Expert? Answer questions, earn points and help others
