Question about Konica Minolta Bizhub C451 Printer/scanner/finisher
Please help, my c451 cyan developer always short within two days of refilling it, it last the next two days
  • Konica Minolta Master
  • 6,696 Answers
YOU DO NOT REFILL C451 Image units REPLACE IT WITH OEM CART.
Posted on Mar 11, 2017
4 Suggested Answers
Avwrexit
  • 47 Answers
SOURCE: Cyan Ink not printing
The important part of question is the word "refilled" Remember that the cartridges come pressurized from the factory so when refilling you are taking a chance as to whether the cartrige will preform as expected. That is not to say that it should not work but I am sure if you replace the cartridge with a Lexmark approved cartridge the cyan will work.
Good luck! Dont forget to rate my response!
Posted on May 30, 2008
  • 62 Answers
SOURCE: Cyan Toner always prints faded.
It is the developer. All colours should be changed at the same time. This can be accessed via the right hand side of the machine, when you remove the cover. (where the output tray is)
Posted on Apr 01, 2009
ehsanziyadp
  • 192 Answers
SOURCE: konica Minolta Bizhub c451 is printing only cyan and black
error with the cartridge, try changing the cartridge
Posted on Jul 18, 2015
I have c451 giving me heavy cyan background at the edges that suppose to be white after printing. What's the cause and what's the solution pls
First check the Laser window cleanliness,
Then check the IU-Cyan and its charging grid cleanliness.
also try in service mode-Image Processing Adjustment-
Background voltage value can be increased.
Dec 30, 2016 | Konica Minolta Bizhub C451 Copy-print-scan
Hi Vinay kumar kuchipudi , I tried using refillable cartridges and my CYAN is always flashing . rest of the cartridges is reconised. Can you please advice me what to change. I tried the second new ref
Sorry for the delay.,
As you know each cartridge having memory chip, the chip keeps the estimated level of ink inside as per the out put print volume . But there is no contact or any internal circuit to link up with the chip.. Once its empty, even refilling the ink inside chip wont recognizes the ink level, results printer detects that cartridge running out of ink & printer warning appears on panel. You need to replace the chip while refilling the ink. Now a days universal re-settable chips are available in the market, get the set of chips replace with existing chips..
Nov 05, 2014 | HP DesignJet 500 InkJet Printer
Bizhub c451 error code c2259?
Black developer motor failure to turn. You mite try pulling out the Black image unit and shake it to spread the toner and developer along the whole unit. The image unit mite have been stored standing up image units should always be laid flat. All the developer may be sitting at one end of the image unit an so the motor is having a difficult time turning.
Nov 27, 2012 | Konica Minolta KONICA BR BIZHUB C451...
MFC-CW490 does not detect Magenta Cartridge
hi clean the contacts of the cartridge slot or you just adjust the contact of the cartridge holder use a twizzer and pull out the pins a little bit...so that you can have a good contact on the cartridge and the holder..
Jun 06, 2012 | Office Equipment & Supplies
Instead of Bule print DC12 prints Violet
Hi there! The blue color is becoming violet because the Cyan and the Magenta toners are not getting mixed in the proper 100:100 ratio (100% Magenta and 100% Cyan make CMYK Blue). Since the print is violet, the culprit is the Cyan toner. Now, first, get the Cyan Developer Assy checked if there is enough developer in it. If no, get it refilled by a proper tech and manually mix about 50 grams of the Cyan Toner with the developer. Also get the tech to check the trimmer gap on the Developer Assy with a metering gauge. If yes, next check the Cyan dispenser motor located on the backside of the Toner Housing Assy. It is probably broken and not dispensing any toner to the Cyan Developer Assy . Additionally, check for the Cyan Dispenser Auger blockage or jam. It is located under the Cyan Toner Cartridge in the Toner Housing Assy and also check the auger under the Cyan Developer Assy. After sorting these out, you should get proper CMYK blue from the 10th or 12th page once you resume printing.Let me know. Regards
May 26, 2011 | Xerox DocuColor 12 Color Copier
I have a SHARP al-1661cs copier/printer. i keep getting a "replace TD cartridge" message. I have replaced the cartridge and it still come on every couple of days. i take the cartridge out, shake it and the...
Are you having your cartridges refilled?
By "replace TD cartridge" message do you mean the little stack of 6 red dots on the control panel?
The sensor for this condition is contained within the toner cartridge. The sensor reads the mixture of developer to toner ratio and tells the machine to add toner when needed. If you are having this problem with 3 different toner cartridges then I would suspect the toner add drive system. If you are having just the 1 cartridge refilled and have had the problem with the last 3 refills then the cartridge itself may be the problem.
I'll let you repond then we will see if further info is required.
Thank You for using Fixya.
Mar 29, 2010 | Sharp AL-1661CS Laser Digital Copier
Large Toner Streak... Bad Imaging Unit?
Check to see if you waste toner recycling for the cyan is working or being blocked. Check the transfer bias roller next to the cyan drum. Return you cyan imaging unit for a warranty replacement. Check for obstructions to the cyan developing unit. Check that the cyan IU was put into the machine properly. Check for toner leaking from the entrance to the developing unit or from the toner cartridge.
or, call a qualified KonicaMinolta tech to check out and service your machine.
Sep 12, 2009 | Konica Minolta Office Equipment & Supplies
Toner not detect
If you refilled it then yes, you would need to purchase this chip as it is telling the printer that it is out of toner.
Aug 09, 2009 | HP Color LaserJet 2550n printer + HP Color...
Feb 06, 2008 | Xerox DocuColor 12 Color Copier
Konica Minolta Bizhub C451 Printer/scanner/finisher Logo
60 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
